Indesit 24 in. IDL500 Built-In Dishwasher
Problem for Indesit 24 in. IDL500 Built-In Dishwasher
Dishwaher not working
By sjames1947 on Jan 09, 2009
When I switch on my Indesit IDL 500 dishwasher all that happens is that the prewash light flashes rapidly. Any ideas?
Same Problem
Mar 28, 2009
-   I put the dishwasher overnight as I always do and in the morning the kitchen was flooded, and the inside had water upto the door, (hense the flood!). Once the water was cleared up I put the dishwasher on to drain the water inside the machine. Now the machine drains and the pump stays on, and the first light blinks after about 10 seconds. This just continues. I can't go back to washing dishes can some please help!!!!-   Brudie
Feb 12, 2009
-   my dishwasher has two green lights flashing the 2 and 4 what is happening. andy -   Guest
Feb 04, 2009
-   It sounds like its trying to fill with water then the 1st lights starts flashing. -   Guest
Jan 09, 2009
-   Problem seems to prevent water going in though water is there at the macine end of the hose. The machine tries to start then first light starts to flash and the usual noise stays on - is it pump buzzing?-   cbeebie
Jan 09, 2009
-   Exactly the same problem started today! -   Guest
Solution #1
posted on Feb 08, 2009
Not Helpful)
shejay1994
Rank: Apprentice
Rating: 68%, 5 votes
switch on water appears to run in after a few minutes second and forth green lught comes on and machine stops it is a IDL500 indesit machine
Was this helpful?
Yes
No
Solution #2
posted on Jun 14, 2009
Somewhat Helpful)
ralphcarlmag
Rank: Guide
Rating: 92%, 3 votes
hi from italy, well it happened to me and i fixed it yesterday 14 june 2009. the washer pulls the water and then light 2 and 4 blink. check the heating element under the machine. if you ohm this it should show about 100 ohms or less. the maching dies a system check and if it diesn't see the element it goes into alarm. the element will cost about 28 euro. this element if good for the following machine on the box ariston,indesit,hotpoint,scholtes unplug the machine and take it somewhere to work on ,some water will spill out. you will have to replace the clamps once you pry it off. hope this helps ralph
Was this helpful?
Yes
No
Popular Solutions for Indesit 24 in. IDL500 Built-In
Questions and Unsolved Problems for Indesit 24 in. IDL500 Built-In
Do you recommend Indesit 24 in. IDL500 Built-In Dishwasher?
Answer
Answer
Where do i find instructions to change the heater element (IDL535S) and Thermostat?
Answer
1st an 2nd lights flash machine full of water The machine will start cycle but does not empty
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Indesit 24 in. IDL500 Built-In...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 470-7119
All the parts that you need for your Dishwasher...
appliancehelp.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
