Question about Samsung Digimax S500 Digital Camera
My camera won't switch on!
Erm, my camera wont switch on. when i press the power button, the 'camera status lamp' (or so it says in the manual) just flashes but nothing comes on on the screen, as if it was turned off. I've tried changing the batteries, and trying it without the memory card (Fujifilm 128mb SD card) but nothing seems to work. Is there a simple solution to this problem and I have missed something massive, or is it something bigger?
  • Anonymous Mar 25, 2014
    When power button is pressed, the camera status lamp only blinks
    Novelist:
  • 198 Answers
Hello, There are 2 possible problems with your camera. Either the lens assembly can't be initialised properly or you have a problem with the main board's power circuitry. The first situation, a lens assembly problem happens because of some shock received by the camera or some small components in the actual lens mechanism that can get loose and therefore jam the lens or some servomotors. Even if a small error or calibration problem is detected (the camera will run these tests allways when it's being powered on) the main board processor woun't allow the camera to initialise. This is a fairly common problem with digital cameras and will require a service intervention to either check the lens mechanisms or to attemt to rewrite the camera's firmware in order to bypass this problem. The second situation will occur if some components on the power circuitry block (on the camera's main circuit board) are damaged or don't make a proper electric contact. Any digital camera uses about 8-9 voltage values to power on different components. A flash will require about 300Volts in order to charge, but as the battery provide only about 3 volts an inverter circuit will be used to raise the voltage value. If this or another circuit aren't responding properly your problem may occur. In both situations you will have to send the camera to a service center in order to have it examined. If your camera is in warranty it will be good to send it to an authorised service center for repairs. If not, try instead the smaller generic "camera service" centers. They will be more cheaper with the diagnostic. Then you may choose if you want to make the repairs or not,depending on the price tag. Just remember to ask them for a price estimation before they actually diagnosticate or repair the camera. Good luck, sorry for not being able to provide a quick fix for this, but feel free to ask further questions.
Posted on Jun 04, 2007
How to reset the lamp time in Panasonic projector model vex 500
  1. Press the Power button so that a picture is projected onto the screen
  2. Press the Menu button to display the "Main Menu", and then press the F or G button to select "Option"
  3. Press the Enter button to display the "Option" menu, and then press the 5 or 6 button to select "Lamp Runtime"
  4. Press and hold the Enter button for approximately 3 seconds
  5. The "Lamp Runtime" will change to "Time Reset [Power Off]"
  6. Turn off the power and disconnect the power cord
Get A Quote for a Panasonic Projector Lamp or to Replace your Existing Projector Lamp now.
Here are some links that will help you.
Change the Panasonic PT AR100U projector lamp in 3 easy steps DLP Lamp...
How to Reset Panasonic Projector Lamp Timer Projector Lamp Services
May 29, 2016 | Panasonic Office Equipment & Supplies
Replaced XD300U projector lamp. Need to know how to reset lamp timer. Won,t turn on because lamp timer has expired to 0. Needs to be reset. Lost our manual. Please help.
"Reset the lamp counter
i. Press and hold Exit on the projector
for 3 seconds to display the total used
lamp time.
ii. Press Menu on the projector or on
the remote control to access the lamp
hour timer. An adjustment message
will appear.
iii. Press or to reset lamp hours
and press EXIT to leave."
Apr 21, 2008 | Televison & Video
Why does my Mitsubishi XD221U projector click and blink red/green on the power light when turned on?
All projectors run a self diagnosis when you press the power button. This does a kind of "pre flight check". If some component isn't working right then the projector won't fire up.
There's no mystery to these status lights. The answer to what they show is written in the manual. Sorry to be blunt, but if you had bothered to read your manual then you would know that red green flashing power light means that the lamp housing cover isn't closed properly. If it is the status light, then it means that the lamp has gone past its due time for replacement. I only know this because I read the bit in the manual just now about the Status Lights.
Sep 03, 2014 | Mitsubishi XD221UG DLP Projector
NEC lt240 lamp light stays off and power light is orange, no Image
COULD HAVE HOUR COUNT LAMP LOCKUP YOU WILL NEED TO RESET HOUR COUNTER BY USING BUTTON CONFIG AND MAINS.
john
www.jvsvisual.com
Apr 15, 2013 | NEC LT 240 Multimedia Projector
I need to reset the lamp timer after replacing the lamp. Red status light.
Some of the NEC units have a standby status when the lamplife has exceeded its safe limit, the unit I had needed the off button pressing for up to 20 seconds to reset the lamplife and allow the unit to be switched back on. There should be info for this in your manual. (It could have been the on button, can't remember now)
Good luck
Dec 30, 2010 | NEC (MTLAMP8101000) Projector Lamp for MT...
My NEC MT1060R will not turn on and the status indicator is flashing red four times, before and after I changed out the lamp.
Good luck
Nov 30, 2010 | NEC MT860, MT1060, 1060R and 1065...
My Acer Aspire 5920 won t turn on The battery light blinks but it is plugged up
try pressing on fn+f5 or fn+f6 a couple of times each. Maybe the screen got switched to projector status by mistake.
Jan 07, 2009 | Acer Aspire 5920-6727 Notebook
Not powering off
lights flashing like that usually means something is wrong in the shut-down procedure. my guess (and is quite common ) is that the lens doesnt retrack all the way hitting a clitched gear spline or something, maybe just weak motor,....as your retry it it settles in proper and tells the micro its ok now to shut down. good luck
Sep 01, 2007 | Sony Cyber-shot DSC-W35 Digital Camera
Whatever button i press the status light flashes and nothing happens?
hi 1) Check that the power cable is plugged in and that the power button on the projector cabinet or the remote control is on. See pages E-16 and 17 in the manual http://www.fixya.com/user-guide/p155892,m5221,gm34/NEC-VT460-Multimedia-Projector.aspx 2) Ensure that the lamp cover or lamp housing is installed correctly. See page E-30. 3) Check to see if the projector has overheated or the lamp has reached the end of its usable life. If there is insufficient ventilation around the projector or if the room where you?re presenting is particularly warm, move the projector to a cooler location 4) You have pressed control panel key when Control Key Lock is enabled good luck
Apr 20, 2006 | NEC VT460 Multimedia Projector
Samsung Digimax S500 Digital Camera Logo
96 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
