Question about Polaris 380 In Ground Pool Cleaner
Polaris 380 wheels not moving
Can you tell me what to look for, or what to replace?
Thanks,
Louis
  • lgwjr Jan 14, 2009
    I will try to find and replace the belt. I've never taken it apart so I may have to find a schematic before I try to do it.
    thanks.
  • 3 Answers
Here are some things to check: 1.  There are belts inside the unit that drive the wheels.  These belts often fail (shred) and must be replaced. 2.  There is a paddlewheel that drives the turbine that turns the wheels.  If the jet that drives the turbine is clogged, then the paddlewheel will not move and the wheels will not turn. 3.  There is a water management system inside the bottom of the unit.  It looks like a bunch of little hoses.  If one of these hoses comes loose, then the water pressure will escape inside the unit and will not be sufficient to drive the wheels.
Hope this helps
Posted on Jan 12, 2009
Change belts on polaris 380
open case then remove vertical tube then then remove paddle wheel assy then you have to remove wheel screws to change belts take pictures as you take it apart
Jul 29, 2012 | Polaris 380 In Ground Pool Cleaner
Polaris 380 wheels won't back up
open up unit check hoses on inside if they are off put on and zip tie
Jul 21, 2012 | Polaris 380 In Ground Pool Cleaner
Polaris 380 wont run when vertical
The drive belts are loose. Replace the drive belts are at least take the cover off inspect and tighten. The adjustments are the axle blocks. Tighten to where there is about an 1/8" tension while lightly pushing on the belt.
Aug 27, 2009 | Polaris 380 In Ground Pool Cleaner
Wheels on polaris don't turn. Is there a way to tighten belts
Replace the belts.($30) Tighten with an 1/8" play. Also check the wheel bearings. If the wheels wobble they also need to be replaced
Jul 23, 2009 | Polaris 380 In Ground Pool Cleaner
Polaris 380
polaris has belts in side it if your handy you can replace them your self if not any pool place can do it but it is a belt i have a 380
Jul 21, 2009 | Polaris 380 In Ground Pool Cleaner
I installed a booster pump. Attached a one ince
1. debris in the water management system (hoses inside the cleaner)
2. black gears in cleaner need replacing (360/380)
3. belt kit (polaris 360/380) or drive shaft need replacing (180/280)
4. teeth on inside of wheels are worn out (polaris 180/280 only)
Jul 16, 2009 | Polaris 380 In Ground Pool Cleaner
Having problem with polaris 380 not moving. just replaced back-up valve and having a different problem. there are three small devise on hose that are spraying water.
If the wheels are spinning independently you have broken drive belts. The hose swivels are leaking also which could lower the pressure to the head.
Jul 08, 2009 | Polaris 380 In Ground Pool Cleaner
Polaris 380 In Ground Pool Cleaner Logo
2,728 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
David Spradling
David Spradling
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
