Question about Dell 1710n Laser Printer
Dell 1710 Laser Printer
The Toner error light is on after changing the toner and drum. I've tried turning it on and off / reseting the drum count but its not working. Please help?
  • myclassic55 Dec 26, 2007
    My printer is just out of warranty with the same problem. Toner/drum light on and error light on. New Dell drum, not so new toner, but I have a new cartridge that I am not willing to open just to see if it helps. I've put about a hundred dollars into this printer in supplies and now it seems it is a printer problem.
    I should have sent it back when I got it and it made unusual noise upon startup. Don't know if it was related, but I should have gone with my instincts.
  • Anonymous Mar 25, 2014
    how to reset low tone light from flashing?
I had the same issue, but i fixed it. For whatever reason the contacts that are inside the printer were not making contact with the PCB ( printed Circuti board ) on the underside of the drum... i fixed the issue by cleaning the pcb and re-aligning the contacts inside the printer.
Posted on Jan 25, 2008
    Problem Solver:
  • 19 Answers
John here, customer advocate at Dell headquarters. The first question I have to ask, is did you refill the cartridge or actually by new Dell branded cartridges. If the answer is the latter, then try the following: Locate the drum contacts on the underside of the drum and clean them off with a lint free cloth. If you notice they are damaged, well, that would be the problem. If they are not damaged, there is probably a problem with the electronics of the printer. In that case, you'd want to call us up and get the thing exchanged if it's under warranty, or replaced if it isn't. John Dell Customer Advocate
Posted on Jun 12, 2007
I have Dell 1710 Laser printer. Toner and Error lights are on and the printer doesn't go online. Can anyone help?
You need to replace the toner. Printer shuts down when print counter reaches it's limit on the toner cartridge
Apr 24, 2009 | Dell 1710 Laser Printer
After replacing toner cartridge, error/toner lights stay on
Open the front of the printer then hold down the cancel button. When the lights flash close the front and it should Reset.
Apr 02, 2009 | Dell 1710 Laser Printer
Dell 1720dn toner error
You have to reset the drum count on the printer after you replace the drum. Call dell tech support they will not charge you for help resetting the drum even if you are not in warrenty.
Nov 16, 2008 | Dell 1710n Laser Printer
Dell 1700 laser printer has Low toner and error lights flashing
Leave the printer on. Open the front and hold down the cancel button until all the lights are flashing in sequence. Close the front while still holding the cancel with the lights flashing and then release the cancel button. This should reset it.
Thanks
Nov 07, 2008 | Dell 1700n Laser Printer
Help
There is no setting on the 1710 printer to clear the error of a non Dell branded toner being inserted. Some higher end Dell printers do have a setting for Non-Dell branded toner. Not all Dell printers have this setting. Resetting the drum count will have no effect on a non dell branded toner error.
Nov 07, 2008 | Dell 1710n Laser Printer
Need advice urgently
Try to search for this part numbers: H3730 or J3815 or K3756 or N3769 on http://ebay,com.my
I'm sure you'll find a lot of ink toners to buy....
Error light on and toner low/ replace drum light on
I was talking to dell and they said it was because of my toner. Guess I will try a new dell toner.
Feb 21, 2008 | Dell 1710 Laser Printer
Dell 1710 lights
You need to replace the drum and toner to correct the issue. That's the sign of the drum at its end of life.
Nov 02, 2007 | Dell 1710n Laser Printer
Dell 1710n Laser Printer Logo
2,760 people viewed this question
Top Dell Office Equipment & Supplies Experts
David Patricia James
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
