GSA-T40L Lightscribe Error
Brand New GSA-T40Linstalled on Dell Laptop E-1705,WinXP svc Pack3. Recognized all ok in Device Manager, Can Copy and Burn,but when i try to use Lightscribe Feature i get Error :A Communication Error Has occured with the LightScribe Drive,Please Restart Your PC And Try The Label Again. I've tried Nero 6 Ultra, Roxio 9, Sure Thing CD Labeler Deluxe Brand new Boxed Version. I Have an HP-Lightscribe External USB that works just Fine. I Set this New Drive to Region code for USA. I'm not sure WHY i have this error or how to Fix it? I Can't find any Support sights either. New Drivers maybe or Newer Firmware? This drive is Dated Nov. 2008.Thanks in Advance for any help.
  • rayny2e Jan 27, 2009
    Fixed it Myself. Had to re-install the Lightscribe Software.
  • 31 Answers
Try a firmware upgrade by downloading it from the internet but make sure the serial numbers match exactly. If that fails then it my need replacing.
Posted on Nov 06, 2009
LG (GSA-5169D) is not being recognized at all as a drive by Win XP SP3. How can I solve this problem?
It may be the operating system has not recognized all the ports, if you operating system is now ok, go to my computer>properties>hardware>device manager, and look to bottom of the list to USB Controllers.
right click on them, and Uninstall all controllers and restart pc and see if all the ports are recognized and installed automatically.
Hope this helps,
Feb 25, 2011 | LG (GSA-5169D) DVD RW Dual Layer Burner
Dvd drive not detect in IDE secondary
Go to the BIOS settings and in the main menu and set the first boot device as cd rom. Then reboot ........
Apr 24, 2010 | Computers & Internet
I can't print label to cd dvd from my dvd unit
Before you can use a lightscribe facility, you must have 3 things, which are, A DVD Drive thats has a lightscribe capability/function, a lightscribe software, and a lightscribe compatible CDDisk.
From what I can see, your drive is not capable, or does not support lightscribe functionality. I tried to check everything about your system model and I discovered that the capability of your DVD Drive is this :
  • Writable DVD formats: DVD-R (6x, DL [double layer]), DVD-RW (6x), DVD+R (DL [double layer]), DVD-RAM
  • CD formats: CD-R (24x), CD-RW (16x)
Which means your DVD Drive does not support Lightscribe facilities.
You can also check everything about your system from this link :
http://gdgt.com/toshiba/satellite/a305-s6857/specs/
Hope this helps you out.
Jul 13, 2009 | Computers & Internet
HL-DT-ST DVDRAM GSA-T40L ATA DEVICE has run problem error code 39
1. Using Device Manager
To fix this error, first try to update the driver from the Device Manager. To open Device Manager, right-click My Computer on your Desktop, and then on the Hardware tab, select the Device Manager button.
In the Device Manager window, identify the CD or DVD drive item (with Yellow exclamation mark), right-click on it and select Update Driver. Follow the screen instructions to update the device driver and restart your PC.
if can't try this:
2.To fix the error by editing the registry, perform the following
steps:
1. Exit and close all applications currently running on your PC.
2. On Start > Run type Regedit and press the Enter key.
3. Next, navigate to the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\ Control\Class\ {4D36E965-E325-11CE-BFC1-08002BE10318}
4. Delete any of the following registry entries if they exist under this key:
* LowerFilters
* LowerFilters.bak
* UpperFilters
* UpperFilters.bak
5. Restart your PC and open My Computer to ensure that the CD-ROM drive is visible.
6. Also, open the Device Manager again to ensure that the yellow exclamation mark and the error code is now gone.
7. Restart your PC and open My Computer to ensure that the CD-ROM drive is visible.
8. Also, open the Device Manager again to ensure that the yellow exclamation mark and the error code is now gone
Jan 02, 2009 | Computers & Internet
Cd/dvd writer
reinstall the dvd-ram by right-clicking on the dvd-ram icon then update driver and search the driver manually wait until it is finished
Sep 21, 2008 | Computers & Internet
No Lightscribe
This could be a driver issues or is it software .
Remove device and software first reboot then reinstall
if you have the disk then reinstall should be straight forward.
Try plugging in the device ,
and use the device manager for the drivers update install.
(while in device manager-select device rightclick and update)
This should fix your issue,
If problem persists,
refer the problem to the retailer you purchased from,
should be still under wanrantee if its a new one,
there supplier should honor the warantee no problems....
You may need to provide proof of purchase for warantee.
Jul 19, 2008 | LG GSA-E10L (8801031212552) DVD±RW Dual...
GSA-2166D recognized by computer but does not recogniz media?
Try removing the device from device manager, then reboot. Windows should then re-detect the device and re-install the drivers for it. If that doesn't work, try the device on another computer. If it still doesn't work, it's probably defective.
Jan 27, 2008 | LG GSA-2166D DVD RW Dual Layer Burner
LG DVD burner model GSA-H42LK "code 10 cannot start"
hey try updating your os if winxp try updating with servicr pack 2 or 3
Oct 28, 2007 | LG Electronics GSA-H42LK LightScribe 18X...
Computers & Internet Logo
771 people viewed this question
David Payne
David Payne
