Question about Roper RAX4233PQ Top Load Washer
Tub is off balance
Roper washer RTW434OSQO, washer worked fine until it was moved from one residence to another. Everything else seems to work (fills and drains) ok as far as i know except now when put on the spin the tub really wobble's really bad. i need to know if there is a way i could have messed it up or if it unfixable. thanks
    Master:
  • 413 Answers
The tub usually does "wobble" quite a bit. If the whole machine is moving what you will need to do is adjust the leveling feet on the bottom of the machine. And whenever you load the machine make sure you load it as evenly all way around as possible.
Let me know if all four legs are touching the ground and if not usually if the front cannot be adjusted the rear can. If they are not all touching adjust as needed and let me know what happens.
Posted on Jan 09, 2009
    Sniper:
  • 62 Answers
Check the tub casting under the agitator or it the gearcase.
I would also try calling Roper and see if they have a solution to this for you because there may be other customers having the same issue.
Roper is owned by Whirlpool so here is the support information:
To contact Whirlpool Corporation by phone about Whirlpool appliances , including answers to product operating questions and new product literature. 1-800-447-6737 For parts and accessories sales and information. 1-888-222-8608
  • Roper Master
  • 19,396 Answers
If the tube is wobblig, and oscillating, then you need to replace the drum bearing.
Enter model number here to find diagrams and replacement parts.
    President:
  • 373 Answers
It Is fixable.All you need to is try to balance the load or a perfect concrete flat surface for the machine.
If the problem still persists, then during the previous vibrations, the shocks might have been damaged, you might have well replace them to avoid further problems.good luck.and please post your comments.
    Genius:
  • 3,422 Answers
HI,
Please let me know if the washer makes sort of a humming noise?Also does the washer spin?
I will be waiting for your reply.
Washer filling problem
Check to hose to the water level control. It goes from the outside of the tub up to the control which is located in the same area as the timer. It's usually round with the end of that tube and at least 2 wires connected to it. Disconnect the hose and blow air through it. Reconnect and try again. Still no fill, try filling with that tube disconnected. Watch it the entire time as with the tube off the water should not stop. If it fills all the way with the tube off the water control unit has a problem.
Jan 07, 2014 | Roper Washing Machines
Top loader Maytag washer cannot balance load
The shock absorbers that hold the tank are broken. Then the load will move the washer all over the place.
Look online for an exploded diagram and order the new shocks for it
Nov 12, 2009 | Dryers
The washer's springs configuration
They are hooked from the bottom frame to the carriage that holds the tub. Not sure of the model you have but most Whirlpool (They make kenmore, roper, magic chef and others) There is a ring around the top of the outer tub that is filled with water from the factory. Make sure it still has water inside. It acts as a damper helping to balanced the tub also.
Oct 13, 2009 | Roper Washing Machines
My washer fills the tub, but when it goes to next cycle just hums
Your motor has failed.
Remove it from the washer to have it repaired or replaced.
Thanks
:D
Jul 20, 2009 | KitchenAid KAWS850L Top Load Washer
Roper rtw434osq0 not spinning/draining water
Set the timer to spin manually and turn it on.
Does it spin?
If not,
Your lid switch is bad and must be replaced.
If yes it does spin.
The timer is bad.
Mar 12, 2009 | Roper RAX4233PQ Top Load Washer
Roper Top Load Washer Does Not Fill To The Top on ''Extra Large''
the water level switch can be adjusted to raise the water level but is not recommended. The level you have is normal.
Jan 24, 2009 | Roper RAS8445KQ Top Load Washer
Tub off balance
Pick up the back of the machine a few inches then drop it. It has self leveling legs it will level everything and it should work fine after that.
Jul 29, 2008 | Roper RAS8445KQ Top Load Washer
Washer
There are only springs that balance the machine. An even amount of clothes inside the washer keeps it balanced. But on the ropers the tub is designed to be very loose like it is. Load the machine evenly and you should be fine.
Apr 26, 2008 | Roper RAS8445KQ Top Load Washer
Roper(whirlpool) washer will not spin
check the tub casting under the agitator or it the gearcase
Mar 17, 2008 | Roper RAX4233PQ Top Load Washer
Washer leaks when running full loads
This could mean the fill level is not working properly and there is an overfill situation. Generally[I don't know 'Roper'] the fill level is controlled by a 'bottle' like device at the fixed to the outside of the drum at the bottom with, with a fine tube leading to a disk like thing near the top of the machine- with wire coming from it to the controller. The 'disk' thing is the pressure sensor. and the bottle thing is supposed to fill with water and the air pressure in the tube actuates the switch in the 'disk' Overtime the 'bottle' will get clogged with crud and need cleaning out. This will mean taking it off and giving it a good cleaning. Hope this helps.
Jul 07, 2007 | Roper RAS8445KQ Top Load Washer
Roper RAX4233PQ Top Load Washer Logo
35 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
