I have a canon copier mf5550 and the alarm which says supply paper tray will not turn off so I can copy, does anyone know what I could do?
  • 100 Answers
Take they out and look in there for a black flag hanging down. This is the paper sensor. If its broke you will have to get estimate or repair at a repair center.
Posted on Jan 09, 2009
Machine won't print, copy or receive a fax
With red button stop the copy, or switch off and on.
If you print on this unit make sure that you did choose a right format of paper (A4,A5,...)
You can change the format ap printer properties or preferences
May 21, 2009 | Canon imageCLASS® MF6550 Laser Printer
MF5500 Paper Jams Everywhere
check the paper ,from cassete tray to the drum and exit,on every section you have a sensor,check it ,
Feb 29, 2008 | Canon imageCLASS MF5550 All-In-One Laser...
Canon Image Class D320 does not copy entire page. New toner has been installed.
Has anyone changed the paper size in the paper tray to another size by accident? Have you tried the manual feed tray? If that copies the whole image then the problem is with the paper size input of the paper tray.
Apr 15, 2009 | Canon imageCLASS D320 Digital Copier
Supply Rec. Paper tray will not clear even with a whole ****
Ok try this - switch the machine off at the mains, empty the paper tray. Push the paper tray back in and switch on the machine with no paper in it. When it's finished warming up it should tell you the tray is empty. Then put paper in. This will usually clear it.
Jan 24, 2009 | Canon imageCLASS MF5550 All-In-One Laser...
Alarm will not clear "Supply Rec. Paper Tray: LTR, their are no jams and the cartridge is installed properly. MF5550
Check paper size
If it is ok go to print job cancel and cancel all jobs
if the error comes while computer connected printing
before click ok go to peinter properties and change input paper size to A4 and out put as match paper size then click ok .
Mar 07, 2008 | Canon imageCLASS MF5550 All-In-One Laser...
Cannon imageclass mf5550 troubleshooting
The document feeder on this machine uses a separation and a feed roller ,the pad is on the bottom and the roller sits on top . in most cases the pad will be white if it is not it must be cleaned .use isopropyl alcohol. then clean the roller using water on a paper towel. On the tray issue if the paper is torn or nicked the sensor flag may be damaged if it is you will need a service call . if the paper is not nicked check to see if the default paper size has been programmed into the user settings on the copier [ read the owners man.] When you send a print to the printer go to printing preferences and check on the paper size being sent to the printer it must match the paper size loaded into the machine
Jan 02, 2008 | Canon imageCLASS MF5550 All-In-One Laser...
Canon imageclass printer 5550
I have crazy feeding/paper jam problems with my MF5650.
Oct 06, 2007 | Canon imageCLASS MF5550 All-In-One Laser...
and PLEASE HELP
Make sure you check both paper sources, the side tray going empty will cause your alarm to go on
Apr 25, 2007 | Canon imageCLASS MF5550 All-In-One Laser...
Won't feed the paper
the problem with your machine maybe that the default paper size programmed into your machine. My guess is that it is set to legal size{ 81/2x14} Get your owners manual out and see how to program the paper size in the user settings sections.
Jan 18, 2007 | Canon imageCLASS MF5550 All-In-One Laser...
22 people viewed this question
k24674
jasbo
jasbo
