Question about Philips MC-105 CD Shelf System
Power Supply transformer failed
The Philps product that I have is the MC-108/05. Inside there is a voltage dropping transformer that has burnt out. Do you have any idea about the output voltage. could it be 6 volts?
  • 8,596 Answers
2 x 5 Watts RMS Stereo
5 watts continuous RMS power output per channel, at 8
ohms, from 120Hz to 15kHz, with no more than 10%
Total Harmonic Distortion (THD).
Posted on Apr 08, 2008
Will a 6 x 8 norlake freezer with cold pack unit above operate with 202 volts
The compressor will most likely not go on if the compressors capacitor does not get enough power to kick start the compressor motor. It sounds like one of the 120v lines is loose, burnt or corroded some where from the inside the panel to the connections inside the unit causing a voltage drop. If it is, you are looking at a fire hazard.
Oct 03, 2014 | Dryers
22" monitor screen went black and power button blinks from orange
More likely to have failed power supply (not feeding 12~18vdc to the inverter circuits), failed inverter circuits (shorted transistors, failed inverter transformers), failed back light assemblies (burnt wires). You will have to open it up and inspect the inside. Pleasen look through my pictures of failed monitors and components if yo decide to DIY repair.
May 10, 2010 | Acer 22" X223w LCD Monitor
Hello i have a Sony Vaio PCW-W2 that i brought to canada from uk. how do i switch voltage to 110?
u can find voltage converter connectors......try using that....u can ask for travel adapters....hope u find them
Mar 08, 2010 | Sony Computers & Internet
I get spark then it quits but keeps feeding all terminals are tight all grounds cleaned and checked
Sounds like transformer has failed. Have you checked INSIDE the welder for loose / corroded terminals??
Also circuit board may have fault.
Check plud that plugs into power supply for loose / burnt connection.
Jan 08, 2010 | Miller Welding Tools
Amp MC-D80. No Indication of power on.Checked power supply board(no schematic). No + or - 12v. All other voltages seem ok. Any known common failure? Thanks Art
Simply follow the 12v supply back to where it starts, which should be where the transformer wires join the PC Board. If you don't have 12v AC there the transformer has gone. If you do, then follow it with your multimeter till it goes. That will lead you to the culprit.
Jan 07, 2010 | Audio Players & Recorders
Dimension 3100 Won't POST, getting amber flashing amber light at front panel and on the mother board getting steady light near the cmos battery note under the light says cr3h1 re-seated cpu and cards,...
I concur with your diagnoses.
Weak power supply due to a weak, or failed, voltage power rail.
There are three main voltage power rails for your Dell Dimension 3100 power supply.
1.The 3.3 Volt rail
2.The 5 Volt rail
3.The 12 Volt rail
Newer computer power supply's are doing away with the 3.3 Volt rail.
Your power supply has,
16 Amps on the 3.3 Volt rail,
21 Amps on the 5 Volt rail, and
21 Amps on the 12 Volt rail.
These are the main power voltage rails.
Voltage times Amperage = Wattage.
You have a power supply, that is rated at a maximum output of 400 Watts.
1) ALL the lights use less than 1 Watt.
2) EACH fan uses 2 to 3 Watts
3) A typical processor uses 55 to 125 Watts.
(A typical Intel Pentium 4 HT processor, Model 640, (3.2GHz), uses a maximum of 84 Watts,
With a weak, or failed voltage power rail you don't have enough power to turn on the processor.
No processor running there is nothing to run the operating system. (Windows XP is an example of an O/S)
The harddrive just sits there, and spins, or will spin a few times, and stop.
What causes this?
1) Cheap quality power supply, (SMPS), installed by computer manufacturer. Cheap components are used in the power supply. (Electrolytic Capacitors, gauge of wiring, rectifier bridge, and so on)
2) Inside of computer, and power supply hasn't been cleaned on a regular basis.
Causes havoc inside the computer.
The processor fan builds up with dust, dirt, hair, etc, and the cooling capacity drops tremendously. Eventually the processor turns off. (BIOS turns it off)
It's a Fail safe feature that is built-in, to keep the processor from burning up.
Before it get's to the stage of overheating, and turning off, it calls for more power from the power supply.
The power supply works overtime to keep up.
When the inside of a power supply, and it's cooling fan are clogged with the above mentioned gunk, the cooling capacity of the power supply also drops tremendously.
The heatsink's inside the power supply cannot get rid of the heat. The fins are clogged, and air cannot rush through them to disperse the heat.
When the blades of the fan, and it's center hub become clogged, the cooling capacity drops due to not enough air is passed.
Heat = Wasted Energy, and the power supply strains to keep up. Eventually components inside the power supply start to fail, or fail.
(Electrolytic Capacitors are usually the first to go. They are the weakest link)
Dec 26, 2009 | Dell Dimension 3100 PC Desktop
Not booting up showing green light wont show on screen
Try to reinsert the RAM! Remove it, clean it and insert it back!!!
hope it will work!!
Dec 19, 2009 | HP Compaq Presario SR1610NX (ED865AA) PC...
A Marshall 100w amp that lacks heater voltage on all tubes
Yes, it is the power transformer that has failed. If you are comfortable with replacing it then do so just be careful. If you could though I would be careful and check to see what power you are getting at the transformer just to make sure
Feb 06, 2009 | Marshall 82 WTS LITHIUM BATTERY, 3 LED...
Philips MC-105 CD Shelf System Logo
215 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
