Question about Whirlpool LSR6232J Top Load Washer
Whirlpool agitator not working!
I have a 2 year old whirlpool Ultimate care-II washer. It just stopped agitating and spinning and make noise when i start it, looks like the draining part is fine. I would really appreciate if you could help me fix this problem.
Thank you in advance
Roger
  • mainepharmac Jan 09, 2009
    hello Sunny16,
    How do i test motor? but when i start the cycle, the machine starts making squeaking noise till the whole cycle is done and the agitator does'nt respond.
    Thank you
    Roger
    President:
  • 373 Answers
Hello Roger.
Please do the following checks for they might just help.
Check that the water supply valves are turned on
Inspect the filter screens
Test for overheating
Inspect the water pump
Test the water inlet valve
Test the motor
Most probably this case may be due to a faulty motor.Good luck.
Posted on Jan 09, 2009
  • Suresh Thrithandam Venkata Lakshmi Narayana
    To test the motor, you have to disassemble it if you are experienced or call a repair guy to do the same. He will use ohm meter to test the motor resistance.
  • 3 Answers
The machine has no water if I turn the knob to wash or spin is the agitator shaft suposed to be turning?
Posted on Jul 07, 2013
I have a whirlpool ultimate care 2 washing machine commercial use. it its making a lot of noise I believe when spinning cycle changes as if the brakes are coming on noise gettting worse other than that...
here is one trick to do. put the timer on spin and pull out the timer knob. open the lid and use a screw driver to actuate the lid switch. then with your other hand hold the agitator until the tub gets to a high spin. once the unit is at a high spin then let go of the agitator. let the unit spin for another minute then lift up you screw driver. it should come to a gradual stop and not a sudden stop. let me konw if that works.
Oct 14, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
My ultimate care II washer spin cycle stopped working. The motor makes a loud noise. The agitator no longer turns.
http://www.youtube.com/watch?v=WLPGs2UMUJc
Replace the direct drive coupling between the motor and transmission.
Jun 22, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitator on Whirlpool Ultimate Care II won't agitate
you can replacethe gears taht cause the agittion called agitator dogs part number 80040, probly $20.. reomveth efabric softener( swift smack with thepalm of you hand) and then remove the agititor with a 7/16 screw down the center shaft. the agitator will "split to reveal the "dogs" fairly easy repair
Mar 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Old Washer won't spin or agitate
You found a belt? Most w/p washer do not have a belt they are direct drive. take off the pump and motor to replace the motor coupling, 2 plastic pieces w/ a rubber in between
Feb 15, 2009 | Whirlpool Washing Machines
Won't spin or agitate
coupling.between motor and gearcase.
Nov 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer does not agitate after filling with water
does it spin?
sounds like your coupling is broke.It takes the place of the belt if it breaks it won't spin or agitate. it will still pump though.
Part # 285753A
Nov 04, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate care 2 (ABOUT 4 YEARS OLD)
Sounds like the clutch is slipping but sometime catching. Or maybe the transmission is almost gone. Is there a burning smell? If so, probably clutch.
Apr 14, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool LSR6232J Top Load Washer Logo
156 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
