Question about HP D4360 DeskJet Printer InkJet
Brandnew hp deskjet d4360 and it's not printing dark enough at all.
    President:
  • 8,637 Answers
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
Just installes new cartridge...blank paper comes out ..no print
Sounds like you did not quite click the new cartridges in correctly. Be very careful with what seems simple enough - changing ink cartridge.
On some HP models, you can very easily snap a tiny spring if you push/pull to hard.
Others have cartridges that seem like you put them in correctly, power up and say they are printing, and no ink.
Try re-powering after carefully removing and reinserting your new cartridges. It may do the trick.
Aug 05, 2011 | HP D4360 DeskJet Printer InkJet
My printer won't print in color
Check your color ink levels, the cartridge may need changing.
If they are fine check in the printer settings that you have both color and black cartridges are selected to print from.
Enter control panel, click on Printers (may differ for you), right click your HP D4360 and select properties, you will see a maintenance tab, select the tab and search for Ink Cartridge Settings. In there you can choose what cartridges to print from.
The names of the tabs may differ slightly as its not the exact model I have previously worked with.
Jan 09, 2011 | HP D4360 DeskJet Printer InkJet
I can't get labels to print within the label boundries with my HP Deskjet D4360 printer. It is a printer problem, but I thought you might have the solution. I love the printer, but I use a lot of...
All printers have a "non-printable area" at the four edges of the sheet. If you labelling program doesn't allow you to specify how wide this area is and subtract it from the layout, you'll have difficulty printing inside the boundaries of the first and last label across the sheet. Similarly the top and bottom labels might not be complete.
Cantaflex
Oct 14, 2010 | HP Deskjet D4360 InkJet Printer
I need to reinstall my printer but I can't find my
Here you go bud:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3374281&lc=en&cc=us&dlc=en&submit.y=0&submit.x=0&lang=en&cc=us
Jan 28, 2010 | HP D4360 DeskJet Printer InkJet
When i try to print from microsoft 4.5 i get an out of memory (deskjet d4360) if i switch to my other printer canon it prints fine
Issue : The solutions in this document address the issue of print jobs getting stuck in the print queue need to restart to get the print
Solution :
Check this link
Step one: Download and install the Print Diagnostic Utility
Step two: Run the Print Diagnostic Utility
Step three: Resolve diagnosed printing problems
Solution two: Resolve the issue manually
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01851354&cc=us&lc=en&dlc=en&product=3374281#Solution1
Jan 03, 2010 | HP D4360 DeskJet Printer InkJet
My computer can not find the printer - Windows Vista
If your printer is wireless you will still need to hook it up to the computer using a USB wire. You also need the printer install disk, called a driver that came with the printer. If you don't have the disk, don't worry. You can download it for free. Just google the name of the printer followed by the word driver. Then follow the prompts to down load it and load it into your computer..
Nov 16, 2009 | HP D4360 DeskJet Printer InkJet
Printing fades during the print job. Dark at beginning, gets lighter to unreadable.
Is the ink cart. good? If not, replace.
Are the Print Heads cleaned? If not, run the diag to clean.
Does this happen on all print jobs? (documents, images, etc..)
If not, then try to adjust the properties of the print driver to a lesser quality.
Sending higher quality print jobs takes up memory, try to increase your page file.
Aug 07, 2009 | HP D4360 DeskJet Printer InkJet
HP D4360 DeskJet Printer InkJet Logo
168 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
