Question about Estate TAWX700JQ Top Load Washer
Washer leaking when washing cloths water comes from the bottom of the washer,i checked around the hoses and nouthing is wet,how do i fix this?
  • 1 more comment
  • katrina Jan 09, 2009
    there is no cracks or corrosion that i can see,do i need to take the lid off to check and if so how? also when i was checking i noticed the tub itself was loose and wobbley,is it suposed to be?
    do u know a site where i can find how to disassemble it?
    it dosnt make any loud noises while spinning and thank you for all your help
    President:
  • 373 Answers
Check for cracks and corrosion on the outer tub. Water might be leaking from there. Please do comment. Good luck.
Posted on Jan 09, 2009
  • Suresh Thrithandam Venkata Lakshmi Narayana
    Thanks for the rating.When you said wobbly and loose; does the washer make sounds or heavy vibrations during spinning?If no, then it is fine for it to be loose.differs in different machines.
    Well you may not notice the cracks(in case there are few) while looking at the machine,you might have to well disassemble it. For this purpose you can find free online diagrams for the model.
    Check this link that has three diagrams of the same model.Will help you with the diagrams and also the assembling and clearer understanding of the parts.Also you can use this website for later use in case you need replace any parts.All the best.
    click here for the diagrams
    please do comment in case there is anything else i can do regarding this,am glad to help.
Kenmore Washer only leaking from one area
Ive never worked on a Kenmore but it may just be the overflow outlet. All washing machines have an overflow which will dump water out from the top of the tub if it overfills but sometimes on high fill water level, clothes can splash around and cause a "wave" of water to splash out over the overflow outlet. Check to see if the leak only occurs when you have selected high level fill.
Nov 23, 2017 | Kenmore Energy Star 44092 Front Load...
My washing machine does not empty the water from the hose, i have checked the hoses when the machine is on its spinning cycle, it only seems if a little bit of water comes out of the machine leaving the...
You need to clean the filter.
Remove lower rear panel of washer.
Locate and remove large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Reassemble and test.
Dec 22, 2010 | Hotpoint Aquarius WF000 Front Load Washer
The water splashs around and is wetting the floor. help
Water splashing is due to the selection of the program, use low water level wash when the clothes are less or the water might be more than the clothes.
So the spillover is what you would have got from the washer.
Also if there is any leak ,it can be from a hose joint , drain valve pump. Might need to tighten the clips of the drum to the valve/pump.
Sep 18, 2010 | GE Profile WPRE6100G Top Load Washer
Heavy water leak during when washing clothes
disconnect the hose on the bottom and see if the seal is good.If it is good, then remove the back panel, start the washer and watch and see what seal is broke and you can visually see the exact spot the water is leaking from.
Feb 04, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Water leak
Remove the lower panel under the washer door and inspect the interior. The panel is removed by loosening and removing the screws under the bottom front edge. With the screws removed the panel will drop down, then off. Inspect the following areas:
- Check all hoses for leaks, cracks, holes and loose connections. Check the seal where the drain hose from the bottom of the wash tub connects to the intake of the drain pump. Make sure the drain hose from the pump to the standpipe is connected snug to the pump and is not leaking.
- Check the drain pump to ensure it is not leaking. The clean out reservoir cap (if not fitted properly) can leak around the seal.
- Check the door bellow (gray rubber boot) to ensure it is not leaking. HINT: A tale-tell sign of bellow leakage is wetness showing up on the front washer counterweight. This is a concrete block mounted to the front of the wash tub. It is not supposed to be wet.
- Check the pressure switch air hose to ensure it is connected to the air dome on the side of the wash tub. This is a small rubber hose that runs from the pressure switch in the top left rear of the washer (viewed from the back, with the washer top panel removed) to the bottom right hand side of the wash tub. However, if this hose were to come off the air dome fitting, the wash tub would continously try to fill and water would begin to pour from the bottom of the wash tub. If this does not sound like your symptoms, disregard this step.
- Check the seam where the wash tub shells meet. There is a rubber tub gasket that seals the two tub halves together. If the seal is bad, water will begin to collect and drip along this seam.
- Check the tub for cracks. This is NOT common, but it can happen.
The following link explains the step-by-step process of checking and cleaning the drain pump:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
I mention this link, because it gives you some guidance on how to access the pump and how avoid the possible mess involved with water pouring out of the pump.
If you discover the door bellow as the the cause for your leak, please refer to this link:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
I hope this leads you in the right direction and helps you resolve your problem. Please post back if you have any further questions.
Aug 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Clothes are soaking wet at end of rinse cycle
Awesome website, fixed my problem. Thank you, especially in these times where I can't afford to just call the repair man:)
Jul 09, 2008 | GE Energy Star WCVH6260F Front Load Washer
When cyle is finish clothes are still soaking wet
Sounds like a slow drain. Recheck the drain hose if it looks ok get a bucket to put the hose in to see how fast it comes out. If it comes out slow the drain pump impellor may be broken.
Apr 17, 2008 | Frigidaire GLWS1233A Top Load Washer
Washer leak in an estate washer
i have Had 3 estate washers leak on all four corners....there junk went with ge instead......estate washers are horrible
Mar 20, 2008 | Estate TAWX700JQ Top Load Washer
Hotpoint Aquarius WMA56 wont drain properly water leaking onto floor
pump is working water is only a trickle coming out so wont final spin
Nov 07, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Water leaking from wash machine
It is probably a seal that is on or near the bottom of the tub. Dirt and grim wears at this seal over time. The leak is slow so it is hard to visually see.
Dec 09, 2006 | Frigidaire MWS939Z Top Load Washer
Estate TAWX700JQ Top Load Washer Logo
213 people viewed this question
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
Justin Duby
Justin Duby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
