Question about Memorex MVD2042 DVD Player
Remote control will not work new battery installed
  • 2 more comments
  • Susanb22 Nov 22, 2007
    My remote does not work and I cannot use the DVD. I installed new batteries and tried to take off the top.
  • MEDAHO Jan 20, 2008
    Same thing goes for me. I called Memorex. They won't replace the remote control under the terms of the limited liabilility. What a piece of junk.
  • DEC1 Dec 07, 2008
    Deacon:
    My remote does not work despite multiple changes of batteries.
    I have yet to contact Memorex directly.
  • ljdema7 Jan 16, 2009
    My remote control will not work with my memorex dvd player model#MVD2022. I can watch movie straight thru by plugging unit in wall only. This unit has no on/off switch on front of player. Have also tried new batteries without success.
I had this problem too and fixed it. It wasn't the remote control but the sensor on the actual unit itself. There was a wire blocking the senor. To fix it I moved the wire so it ran underneath the dvd tray instead of running along the front of the unit.
Posted on Feb 26, 2008
No solution: DO NOT BUY THIS DVD PLAYER!! It isn't worth the money I payed .... at all.
Posted on Jan 31, 2008
SOURCE:
My remote won't work
Many remote controls freeze up and appear "Dead", but some can be instantly brought back to normal operation by following 4 simple steps.
Use these steps on OEM (original equipment) remote controls for TVs, DVDs, Audio Systems, Satellite and Home Theaters.
Note: If you follow these steps on a universal remote control, you will need your universal's owner's manual to reprogram it.
1) Remove all batteries from the remote
2) While the batteries are out of the remote, push and release every button on the remote control one at a time, until all buttons have been pressed and released at least once. This action drains the capacitors in the remote's circuits and causes the remote's brain to go back to factory defaults.
3) Re-install the batteries, taking care to insure each battery is installed correctly. Use new batteries if you are unsure about the batteries you removed.
4) If this Remote Re-Start procedure is going to work, your remote should now be back to normal. Try it.
If your remote works, Great. If not, you can shop for a new OEM remote control at Remotes.com 1 800 Remotes Factory original replacement remote controls
If you need codes for Universal remotes REMOTE CODES COM
Feb 29, 2016 | Televison & Video
Swann dvr4-950 remote control not working
If new batteries, properly installed, did not get it working again it may have to be replaced.
Dec 15, 2014 | Televison & Video
My rmt-05 remote is not working after i put in new batteries
have you checked the polarity one the new batteries you installed? (flip the batttery updside down)
Aug 29, 2014 | Westinghouse RMT-05 TV Remote Control for...
I changed the batteries in my rca remote and now the indicator light will not turn off and the remote does not work
The new batteries may have been installed incorrectly. Check the polarity marking inside the battery compartment.
Nov 11, 2013 | RCA New Original CRK76WB3 Remote Control
My remote control does not get the light on with batteries brand new...remote control does not work
Check the battery contacts in its battery comparment for any rust or dust accululated. Clean them well before insrting batteries. If all are OK, the fault should be with its internal circuit board. If so, you have to open the remote control to rectify it. If you wish to get more details about how to check a remote control, check this link.
http://electronicshelponline.blogspot.com/ Pull up older posts there, either by its left side bar, or see it in 'Timeslide' window. One among the posts have details about how to check and repair a remote control.
Jun 19, 2013 | Televison & Video
Remote control for vmb070 does not work
There should be a clear indication on your remote where the battery compartment is. Usually there is a slideoff cover that has to be removed. Some remotes have covers that are difficult to remove. Once you have the compartment open, you can remove the batteries. Check for signs of corrosion inside the compartment and clean it before installing new batteries. Be sure to observe proper polarity when installing new batteries
Mar 17, 2013 | Televison & Video
My remote control won't work even with two new batteries installed. No light flashes at all. What should I do?
i've read two things about this they sound stupid but they worked. remove batteries from remote and press all buttons and hold down for 1 min. and tap on signal eye 2 to 3 times good luck
Dec 25, 2010 | Toshiba CT-877 Remote Control
My remote control does not work suddenly
Try installing new batteries such as Duracell batteries. Make sure they are installed properly in the remote with positive to positive nodes and negative to negative node. If you own a digital camera, you can test the remote to see if it is working. Point remote at camera (powered on) and press a button on the remote. If you see a blue / purple light on the remote's led, then the remote is working. If not, then the remote is probably broken and you need to buy a new one.
Aug 09, 2010 | Sony RM-PP404 Remote Control
Sony RM-Y180 remote control
Did you install the batteries correctly?
Some remotes (Universal) need to be re-programed when you install new batteries.
Go to remotefinder.rca.com/default.aspx?site=rca for proper codes.
Oct 30, 2008 | Sony RM-Y180 Remote Control
Memorex MVD2042 DVD Player Logo
229 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Steve Allison
Steve Allison
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
