Question about Kodak EasyShare One Digital Camera
Memory card wont read
Using Kodak 2GB SD memory card that has been slightly bent and cracked. It will not read in camera or reader now. I would like to recover pictures.
  • cptbryant Apr 14, 2009
    cracked memory card will not read.
    Novelist:
    Champion:
  • 200 Answers
To recover your deleted files from the Memory card ,you should stop adding new things to the card and then choose the best photo recovery software to recover.
http://www.goshareware.com/resource/recover-formatted-memory-card.html
This article will be useful to you.
Posted on Jun 06, 2013
    New Friend:
  • 12 Answers
The pictures should be in the memory card. You may try some photo recovery software to rescue the files on your memory card, here are some for your options.
Photo Recovery (for Windows)
Photo Recovery for Mac
Be careful: Before your pictures are recovered, do not attempt to save more files to the card in case the original files(your pictures) are overwritten.
Posted on Dec 14, 2010
SOURCE:
MY CAMERA IS A Z650 KODAK EASYSHARE, MY DAUGHTER LOST MY OLD MEMORY CARD SO I WENT OUT AND BOUGHT A NEW MEMORY CARD BUT MY CAMERA SAYS IT NEEDS FORMATTING AND IT WONT LET ME ALSO IT SAYS INTERNAL MEMORY IS...
Just as I suggested. The Z650 works with SD cards, not SDHC cards. Most likely your old card was 2GB or smaller and your new card is 4GB or larger. Try using a 2GB SD card.
You can clear internal memory by deleting the pictures it contains. Download them to your computer first if you want to preserve them. You can get rid of all of them in one shot by using the "Format" command in the Setup menu.
Apr 27, 2012 | Kodak Cameras
I have a Kodak EasyShare C330. I have a new memory card Kodak SD Card 128MB. When I insert it in the camera, a message displays stating memory full. When I try to format the card to the camera I received...
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card.
Try to format the memmory card using a card reader and the PC this should solve your problem if not you have to replace the memmory card.
Mar 11, 2011 | Kodak EasyShare C330 Digital Camera
Hi, got new kodak camera and 4gb memory sd inside. i only took 8 pictures so far and said internal memory full. i dont understand why? i want to keep 8 pictures and it should be plenty as using 4gb and...
4GB "SD" cards are almost always actually SDHC (high capacity) cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC cards. SDHC is not backwards compatible.
So your camera is not able to use the 4GB card, and is ignoring it and using internal memory only. That memory is tiny and won't hold many pictures, and when it is full, the camera cannot work at all. You need to delete the pics in the internal memory and get a memory card your camera can understand (2GB or less).
Jan 27, 2011 | Kodak Cameras
Need to know what memory card can i purchase and where for kodak easy share c530 my camera is old haven't used much I have a 1.0gb sandisk can i use a 2gb sandisk.
I had a look and it seems 1GB is about the Maximum? yes Sandisk is a good brand. Frankly anything that works well is OK.
Buy a good brand of card ... SanDisk is my favorite.
Kodak would certainly be a good choice too.
Don't buy it on eBay, as there are too many counterfeit cards available on eBay.
A Tip:
If you use a card reader, you will need a SDHC card reader if you use a SDHC card.
Most older card readers can not read a SDHC card.
Tip number 2:
Always format a new card with the Camera before taking any pictures.
You will find how to format with the camera in the camera User Manual.
Feb 05, 2010 | Kodak EasyShare C315 Digital Camera
Kodak EasyShare DX4530 Digital Camera Digital Camera Cannot format memory card After I inserted new card, it says that memory card required formatting....I hit Continue...it warn me that formatting will...
If your using more than 2GB of SD card or if yous using the SDHC card it will not format the Memory card.
Try to used the recommended Memory card 2GB or 1GB SD card It will reformat your card. Too Much or too High SD card is not compatible on DX camera series
Nov 08, 2009 | Kodak EasyShare DX4530 Digital Camera
Kodak EasyShare C633 not reading any SD Card
yea pls do check with the card reader.....as u tell above criteria the problem will surely be with the card reader.... but in the mean time pls use some other memory card to check whthr its working or not....before using it format n try,.....gud luck thnx fa usin fixya!!!!!
Nov 02, 2009 | Kodak EasyShare C633 Digital Camera
My computer can read the Lexar 1GB SD. But Kodak wont.
I suggest formatting the card using the utility in the camera. This will delete any data that is currently on the card.
Sep 16, 2009 | Lexar Professional High-Speed 2GB Secure...
I bought a 2GB SD card for my Kodak EasyShare C330 Camera
Buy a 1GB card (or 2). The spec for the SD card format is going to 2GB but the Kodak C330 not compatible with 2 GB SD memory cards.
Click
Jun 01, 2009 | Kodak EasyShare C330 Digital Camera
Memory cards wont format, says card is full
Is the write protection enabled on the cards?
Which size having the cards?
Click
But try an firmware upgrade.
Why download firmware version 1.07?
This firmware version improves memory card compatibility and provides general performance updates.
KODAK EASYSHARE C330 Zoom Digital Camera Firmwar
May 17, 2009 | Kodak EasyShare C330 Digital Camera
Hello i have the kodak easyshare c330 digital camera . i just purchase a kodak sd 2gb memory card the camera is stateing that the memory card is full can you help me with this problem please
Click
But try an firmware upgrade. Maybe the supporting now the 2 GB memory cards.
KODAK EASYSHARE C330 Zoom Digital Camera Firmware
Dec 02, 2008 | Kodak EasyShare C330 Digital Camera
Kodak EasyShare One Digital Camera Logo
133 people viewed this question
Top Kodak Cameras Experts
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
