Question about HP OfficeJet 7310 All-In-One InkJet Printer
HP Officejet 7310 carriage jam
I just got this printer and it 's always popping up that it has a carriage jam.
I opened the door to see inside the printer and I don't know what's wrong with it. Please help me!
  • mgraziano Jan 19, 2009
    can someone post a way to unjam the service station, as that appears to be my issue (7310)
  • wilxsmith Jan 21, 2009
    Thanks for the great informative explanation. I tried the steps to solve. It didn't fix it, but I did notice a couple bends in the encoder strip. There are also a few abnormal looking gaps between the black lines at some spots.
    Do you think it's worth buying a new encoder strip?
    Will
  • 1,031 Answers
I'll start by explaining some of the components you need to understand to troubleshoot the carriage system.
The Carriage is the thing the cartridges are mounted in, it slides on the carriage rail, the bushings in most newer carriages are made of plastic, (or maybe it would actually be called a polymer, or composite material). The bushings are the pieces that wrap around the carriage rail.
The carriage rail is a shiny round rod that the carriage rides on, it is driven across the rod by the carriage belt, by the carriage motor, at the opposite end of the belt there is an idler pulley, ".
In a HP printer the device where the carriage parks, (sits at), when the machine is not printing is called the service station, it is responsible for cleaning the print heads, and for capping the heads when you are not printing, (so they won't dry up). The bottom of the service station is the "Spittoon Base", ink is spayed into the base before printing to prime the heads, there is an absorbent pad in the base to soak up the ink. Note that the pad does not always soak up all the ink, so if you tilt an HP printer you can spill the ink out of the service station, (especially if it is a heavily used printer). The piece that moves back and forth in the service station is the "Sled", it was wipers to clean the heads on it, and the caps that keep the heads from drying out are also part of this assembly. The sled is moved back and forth before the carriage leaves the service statio to wipe the heads, this happens after the heads are primed, then the carriage is moved off the service station and the sled is again moved back and forth to clean the wipers.
The encoder strip is a plastic timing fence that looks clear at first glance, but has black lines painted on it. The strip is threaded through an optical sensor on the back of the carriage.
When the printer initializes the carriage has to leave the service station, or, if the machine was powered off when the carriage was somewhere else, whatever spot it is sitting in, and travel the way to the other side of the printer, and then return to it's home position which is the service station.
When the carriage reaches the side of the printer away from the service station it sets that as a reference, then it counts lines on the encoder strip as it travels home, if it doesn't see enough lines before it gets all the way to the other side and can't move any more then the printer decides the carriage must have something blocking it.
Sometimes a service station will fail in a way where the sled does not retract fully, if that failure happens when the carriage is parked then the carriage will usually not be able to leave the service station. If the service station binds when the carriage is off of the station, then the station may not be able to move all the way to that side, and will detect a carriage jam. When the service station binds you might hear a grinding noise as it's motor tries to drive the sled back and forth.
If the encoder strip is dirty the printer may not see all the lines and detect an error, often when the strip is dirty the carriage will move too fast and slam to one side of the printer.
I use water to clean the encoder strips in HP printers, water works well on water based inks, if your printer uses ink with another base you might use alcohol, but "ONLY" if the ink is not water based.
One end of the encoder strip is attached to a spring mount, if you wipe the strip starting at the end that is attached to the frame, and wipe only towards the spring mount, then the strip will stay attached to the printer.
A dry carriage rail will cause the carriage to bind, if the carriage does not move fast enough a carriage jam will be detected. Some newer HP printers use grease on the carriage rail, many models use a liquid lubricant, Use "ONLY" light synthetic or silicone based lubricants on printers that use a liquid lubricant, Petroleoum based products may melt the plastic bushings and ruin the carriage. (YES, Petroleoum based means WD-40)
some HP printers have a timing disc on the service station, and if the service station binds, or the timing sensor fails they report a carriage jam, but as far as I've seen that jam always occurs before the carriage moves.
You can use a synthetic lubricant on the carriage rail :hope this helps
Posted on Jan 09, 2009
  • Starnley Johnwells
    Starnley Johnwells Jan 10, 2009
    hope this helps pls appreciate by rating as fixyaa
Carriage jam
cannot print, msg shows Error carriage jam, Open door, clear carriage jam, and then press o.k. to continue.
paper has been cleared , opened door and even took off back compartment
Dec 22, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Paper Jammed. Have appeared to remove all paper. But I keep getting "Carriage Jam, open door, clear carriage jam then pres OK" message. Message on my computer screen says "The print cartridge carriage is...
HP support has extensive documentation for both paper and carriage jams for your model:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00304007&lc=en&dlc=en&cc=us&lang=en&product=391182
I hope this helps!
Dec 10, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Carriage jam
Copy and paste the above website in the adress bar of your explorer,if this does not work then call in to hp at 1800-474-6836 and we at hp will replace your printer free of cost as it will/should show in warranty.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00304007&cc=us&lc=en&dlc=en&product=391182
Jun 28, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Carriage Jam
If you can get the covers off. push down on piece that is blocking the cartridges. Otherwise, it is uneconomical to repair.
Jan 15, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Hp 7310
Find the stuck piece of paper and remove it.
Dec 21, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Paper jam in carriage
There is a latch at the back of your printer that opens so you can remove paper jams from the back. You can start there and then slowly peel away the rest of the paper that jammed...
Mar 10, 2008 | HP OfficeJet 7310 All-In-One InkJet...
HP OfficeJet 7310 All-In-One InkJet Printer Logo
2,212 people viewed this question
Seeker5211
Seeker5211
