Question about Mitel Lands Phones
Twinning a phone
I have a phone that has been twinned. How do I remove the once it has been done?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 112 Answers
You can access the Telephone User Interface (TUI) from any
touchtone phone. Voice prompts assist you to set or change the
following profile settings:
• Enable/Disable Mobile Extension
• Configure mobile phone number
• Set password
Use the star key to access previous menu.
Logging In
1. Dial the TUI access number supplied by your Administrator.
2. At the appropriate prompts, enter your desktop extension
number and numeric password. (Use the same password
in the Web Interface.)
Posted on Jan 11, 2009
What are twinned units?
Twin units can be two airconditioner condensers and/or two furnaces. Most manufacturers make a twinning kit that will wire two units together to operate simultaneously by one thermostat. At times, one may operate as a first stage of heating (cooling) and then the other unit can operate as second stage. Twinning unit are beneficial in commercial buildings where the load conditions vary constantly. For instance, if you twin two 4 ton units together. On a nice cool day, you may only need 4 tons of air conditioning. So, the thermostat will only turn on one unit. On a hotter day, you may need 8 tons of air, so the thermostat will turn on both units. In case you are thinking about doing this, the biggest mistake in twinning units together is using a common return air for the furnaces. Make sure you separate the return air cavities and ductwork for both of your furnaces If you don't have separate returns, you have the possibility of one of the blowers starting backwards. (talking form experience LOL)
Aug 13, 2011 | Heating & Cooling
How do you put twinning on this phone ? I cant
You will have to have the Admin add this feature to your phone. It is a licensed feature and the button can only be put on with the Manager application.
Jul 09, 2010 | Avaya 5610 IP Phone
Can i install two furnaces w/refrigirated air into the same duct system w/ 1 thermostat
It's called Twinning. And as long as the furnaces can communicate with each other and the duct system can handle the combined cfm, yes. You will probably need two thermostats but have a heating professional look at it.
Mar 03, 2010 | Heating & Cooling
Goodman heater "twinning" problem
Hi inhave been looking for solution for this cannot find one all i can find is web address for goodman www.goodmanfg.com see if this helps , all i can find is reversed polarity but cannot see this as the problem hope this helps
Feb 21, 2010 | Goodman GMS90703BXA Heater
Furnace locks out because of twinning polarity
Usually a polarity problem is fixed by reversing the wires that run to the power supply to the unit.First, shut off the breaker that feeds power to the furnace. Most of the time, there will be one black, and one white Unhook those, switch the wires around, use new wire nuts to wire them back together. Hope this helps.
Nov 08, 2009 | American Standard 40 G Natural Gas Water...
Twinning problem
Switch the leads and also make sure that you have a good ground.
Mar 30, 2009 | Goodman Heating & Cooling
Model # GMPN100-4 Furnace will not start...
when you remove the panel there reset button press on it
Jan 18, 2008 | Goodman GMS90703BXA Heater
Lands Phones Logo
153 people viewed this question
Top Mitel Lands Phones Experts
Shehu Pro
Shehu Pro
Andrew Taylor
Andrew Taylor
Are you a Mitel Lands Phone Expert? Answer questions, earn points and help others
