Question about Nikon D50 Digital Camera with 18-55mm Lens
Problems with taking pictures of horizons and buildings
If anyone is out there please help me. Sometimes when I take pictures of horizons, buildings and structures or even objects near by, the images comes out crooked. What I mean is that the image does not look as if it is horizontally balanced in the middle. It slants to a side, or it looks slanted. This same problem occurs when I take pictures of objects and there are vertical straight lines. They tend to slant to a side along with the object. When I take pictures of building the vertical line of the buildings appear bent, instead of straight. Some times to rectify this I also slant the camera and the lines appear straighter. Sometimes it doesn't work though Is there something wrong with my camera or is it just my technique that needs fixing. Please kindly advise me. Regards Anthony lakdasn@gmail.com
    Genius:
  • 2,985 Answers
This Nikon's expertise to fix - contact customer support- they may repair or offer a replacement.
Posted on Aug 03, 2007
I purchased the tv in 2007 and it has been great until now. The picture went out a few months ago around the time we had all of our plug outlets replaced by an electrician. I initially had audio but no...
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Aug 16, 2017 | Panasonic TH58PX600U 58 in. Plasma HDTV
On my HD1080 Mitsubishi projection flat screen the picture is bowed on top and bottem and it look as if the projectors themselves are offset, but the picture is clearer as you come toward the center. If I...
You have poor contacts and or dry joints. Resoldering on the convergeance panel and powersupply/line timebase board will probably fix it.
It should take less than an hour in labour terms.
Feb 20, 2011 | Mitsubishi WS-65809 65" Rear Projection...
How do i reset to factory settings on my pc
First check beneath your mouse and make shore there is no build up of ****, dust, etc.
Then go to control panel and restore the computer back to earlier day before the trouble started.
If it still persists its software problems so refer to your customer service 1 800 number so that they may direct you to how to fix a glitch issue.
Nov 06, 2009 | Acer Aspire 5500 5570-2609 Laptop
Exilim z600 Static on viewing screen. Sometimes won't turn on/off
More than likely, you've just got a bad camera. I've helped with several problems with P/S cameras where the screens are either noisey or records a static like image. 9 times out of 10, it's the processor. Unless the camera is new or still under extended warranty..,
Feb 04, 2009 | Casio EXILIM ZOOM EX-Z600 Digital Camera
Code displayed over my ps3 xmb, affects gameplay
video rsx cpu maybe partially damaged..i can probably fix it.
Nov 10, 2008 | Sony Playstation 3 (PS3) Console
Tried turning on my Sony and no picture no sound, just a black screen
Sony is known for having problems with the picture tube. Sometimes it will blink on and off. also bad connections on the main board. A CRT restorer will sometimes help with picture tube problems but this must be done by a tech that has one.
Apr 11, 2008 | Televison & Video
Horizonal line
I think you have a fault on the picture frame board. If you can check for this yourself or find a competant technician. Hope this helps.
Apr 02, 2008 | RCA F32650 32" TV
Picture is blurry, but perfect sound
Sounds like a ground leg on the distribution block has loosened up and is not properly grounding the screen drive. worst-case scenario is that ione of the tubes (3 picture tubes) has started to short out and is causing the blur.
Nov 08, 2007 | Toshiba TP61G90 61" Rear Projection...
Mitsubishi hdtv1080 projection tv
picture decides to go out , sometimes for 2 or 3 days then turns back on its own.....what could this be?
Sep 30, 2007 | Mitsubishi WT-42311 42" Rear Projection...
Nikon D50 Digital Camera with 18-55mm Lens Logo
131 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
