Question about Equipex PZ-330 Electric Single Oven
Kenmore stove surface unit light stays on
Light stays on when all control knobs are off
  • Anonymous Mar 13, 2014
  • Anonymous Mar 26, 2014
    knob is loose and burner won't turn on. do the knobs pull straight out?
    Sergeant:
    Champion:
  • 262 Answers
YOU HAVE A SURFACE UNIT SWITCH GOING BAD take off the back and look at the switches if you have a volt ohm meter you can check for power to the light if you dont have a meter you can unplug the stove and pull each wire 1 at a time and see which one is sending power when plugged back in once you find the one replace it and problem solved
Posted on Jan 09, 2009
Need knobs for Lady Kenmore free standing stove. do not have model # stove was installed when home was built in 1990
parts need to have the model number sometimes the part with have the number etched on to it
Feb 01, 2015 | Kenmore Ovens
After cleaning the outside surfaces of the stove, the oven door is locked and does not unlock if we push the stop button. Display reads LOC. No self cleaning cycle was initiated. The stove is a Kenmore...
What about child lock? Read user manual or try holding button for 10 seconds, might be two at once.
(I bought a $200 control board and travelled 150 kilometers for that one....)
Oct 15, 2013 | Kenmore 49043 Electric Single Oven
My electric oven & broiler elements are not heating up when the they are turned on. kenmore model # 790.94422300
IF it is a electronic control look at the control panel when u turn it on see if it is flashing a F12 IF IT IS YOUR CONTROL IS NOT WORKING may need to call an appliance guy if its a clock style stove with a couple of knobs u turn for the time u may be in manual mode push the knob in to put it back on automatic also check your fuses
Oct 02, 2013 | Kenmore 40494 / 40495 / 40499 Electric...
My oven wont turn off from the knob it keeps turning
You didn't say whether you have a gas or electric oven, or oven & stove. I'll assume you have a stove, just to cover all bases.
First, you should shut down the oven: a gas stove will have a valve on the gas line behind the stove. The valve will either have a red handle or a flat stem that usually has a hole in it. Turn either valve 1/4 turn to shut off gas, use a wrench on the flat stem. An electric stove should be shut off by flipping off the double circuit breaker for it in your electric panel. Do not unplug an electric stove when it is on; this can damage the plug &/or electrocute you.
Most likely the inside of the knob has stripped out. Look at the knob for a hole that has a setscrew in it: a small allen wrench or screwdriver will loosen the setscrew, most knobs don't have them and will pull off. Be careful to use even pressure on two sides of the knob; if you can't pull it off, use two butter knives or flat screw drivers to pry it up enough to get a grip on it.
Look at the center stem on the back of the knob, it will likely be cracked or stripped. Some stems have a D-shaped metal insert that strips out inside the plastic stem. If you have one, pull off a burner knob and compare the stems in the back, if they are the same size, put the burner knob on the shaft for the oven control, and use that knob to turn the oven control off.
If the burner knob won't fit, use your fingers or a pair of pliers (gently) to turn off the oven control shaft. If the shaft stops normally, you can turn the stove back on using either the gas valve or the circuit breaker. If you have a gas stove that doesn't have electric ignition (a clicking noise when you turn on a burner) you may need to re-light the pilots for the burners. Lift the covers off the burners to re-light the pilots.
If you have succeeded in turning off the oven, you need a new knob -- you can get one at an appliance parts store or maybe a hardware store. If the oven control did not turn off normally, I would leave the oven/stove turned off: the control itself will need to be replaced by a qualified repair person.
Mar 03, 2013 | Ovens
I have a Frigidaire model FCG30B6Q0JWI-5A gas stove (Made in Costa Rica) and can't get the oven to stay lit. There is no electronic ignition, no pilot, it's just a regular run-of-the-mill light a...
While your holding in the knob after lighting the pilot,their is a thermocoupler that is heating up and will hold automatically what your pushing in, that thermocoupler is defective
Jul 28, 2011 | Ovens
Kenmore electric stove with glass/cermanic top. Element on light indictor light stays on all the time even though no burners have been turned on for 5 hours. None of the burners are hot when you run your...
Tony, this sounds like you may need to have a new burner switch installed, it is called an infinite switch. If it is for the dual burner, make sure you tell the appliance parts store this so they can order you a dual infinite switch.
Nov 08, 2009 | Kenmore Ovens
Hotpoint Glasstop Stove - Burner turns on by itself
I have a GE stove which I purchased in 2004, and it is doing the same. I heard beeping coming from the kitchen in the middle of the night . I went to the kitchen and the oven was on by itself. I have been unplugging it when not using it. Maybe this could be a recall.
Oct 08, 2009 | GE Profile JKP18 Electric Single Oven
Kenmore ultrabake lights up when stove top is on but wont heat up
Hard to know...First thing I'd check is the power supply to the unit.  Turn off both breakers.  Check wiring all the way through for tightness.  Turn both breakers on.  Next, you'll need to check the elements for continuity...with the power off.
Nov 28, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Display is blank, no heat no bake
The oven control panel has failed. For more tech help with this issue and a place to order parts I suggest you go the link below, it is where I go for parts and help. You will need to model number available. Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Jun 28, 2017 | GE Monogram ZET3058SHSS Stainless Steel...
Stove works, oven does not
in repairing Kenmores there is a relay well 2 small black an square in the head unit of stove one for stove the other is for oven anyway they go out alot a setback to the kenmore digital controls take upper panel off where controls are look at the green board an you can see them some green some red or blue to tell if one is bad be careful an turn the stove on u will hear the relay click then try oven if you do not hear a click its bad do not i repeat do not touch it while its on
Aug 31, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Equipex PZ-330 Electric Single Oven Logo
295 people viewed this question
Top Equipex Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Equipex Oven Expert? Answer questions, earn points and help others
