Question about Dell OptiPlex GX520 PC Desktop
Darn Power Button Ain't Turning It On
Bought a Re-furbished Dell OptiPlex off of eBay. Got the thing ... unpacked it ... hooked it up ... turned it on. Everything worked fine. 'Bout an hour later, tried to turn it on again. Now ... NOTHING. Pulled the power plug out and re-plugged it in. Face of the computer flashed green, fan turned on, then ... nothing.
I must say that the power button on this thing seems junky. Doesn't have that nice "click" feeling to it - something I've always experienced with other PC's. eBay seller hasn't gotten back to me. Thanks!
  • chrismcmorro Jan 09, 2009
    Thanks, Robert, but it's definitely not sticking. I forgot to mention that this is a Optiplex GX520. Is this indicative of a major problem, or can this be fixed for a reasonable price - under $100. What do you think?
    Thanks!
    Chris
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, if there is a reaction on the monitor when the power button is pressed and the fan turns, then it is not a switch failure. Possibilities are:
  • loose component/card internally. You may want to open and visually inspect. Pay particular attention to the memory and video card;
  • are there any beeping sounds;
  • are there any light/LED indicator that lit up when power is pressed;
  • are you referring to a toggle type switch at the rear (on the power supply itself) or the push button power on in front;
  • check for loose video cable connection.
Pls post back result(s). Good luck and Thank you for using FixYa.
Posted on Jan 09, 2009
    Sergeant:
    Champion:
  • 435 Answers
I think the power button is fine since the power fan is turning on. But Green screen and nothing tells me that something is wrong with the motherboard. You may have to replace that...
  • 15,935 Answers
You are right, it is probably the switch that has broken. A tech repair center should charge you about $75.00 to replace.
  • blueextc3221
    blueextc3221 Jan 09, 2009
    if there is a "reset" button on the PC, you can also swap it for the power button on the motherboard.
    Plug the little wire harness labeled RST or RESET in to the PWR or POWER pins, and you can tell if it is the switch that is faulty.
    To take this a step further... find someone (or eBay) with a spare case and/or power button. (autozone or similar automotive parts store has 12V momentarty pushbuttons too that you can splice onto the broken button's wires)
    Trill the proper size hole on the removeable side of the case, and plug it in to your motherboard where the current switch is.
    This solution MIGHT cost you $10 in parts and take 10 minutes to install.
    If you want more help, let me know.
    Genius:
  • 1,239 Answers
HI
I THINK A large voltage would cuse that problem,,,,but no chips are damaged.leave unplugged for a night.and do a hard reset and it would definitely work.......for tommorow if no contact me
  • 679 Answers
Checkout the processor fan is working or not.and let me know
    Sniper:
  • 62 Answers
If the computer turns on still, but the screen only flashes green, it is probably a graphics card issue. If the computer does not turn on at all, it is a power supply issue. When you bought the computer off of ebay, did it come with a guarantee? I am assuming, if the computer still turns on, that graphics card has died and you would need to replace that.
If there is any further details you can provide about exactly when it flashes green or if the computer actually gets power to it when you hit the power button, that would be great. This will help me further diagnose your issue. If you have any more questions at all, please let me know and I will get back to you right away.
  • Logan Margulis Jan 09, 2009
    If it flashes green, it is most definitely a short in the motherboard. You will need to open up your computer and check to make sure everything is connected tightly to the motherboard. If all the connections are tight, than you will probably have to replace your graphics card.
  • 505 Answers
I doubt it is the power button but likely another failure. refurbished items were typically once used or broken so sometimes you get a bad new one. hopefully you have warranty and can just swap it out. there is definately a hardware failure, power supply or mother board likely. If the computer boots up and hardware is good you get the POST beep sound indicating that, which you don't get. if the power button does anything (ie start it to turn on) then the button is ok, might be flaky but not the problem here. If you have no warranty let me know and we can troubleshoot further internally. Thanks
  • 89 Answers
I think that it has something to do with a crapy refurbishing job they probable just made it look good and didnt actually fix it hence the seller not responding your description is really ro vague for anyof us to help you if possible pleases send pictures to dragon_rage27@att.blackberry.net and ill see what i can find
    President:
  • 2,110 Answers
If the fan is moving after the power button press...then ur button is fine...u need to check all connection on the motherboard if anything loose..
  • 916 Answers
    Genius:
  • 3,422 Answers
HI,
If it isn't turning on then the problem is with the SMPS.You will have to get it repaired or replaced.
  • Priya darshan Jan 09, 2009
    A switched-mode power supply (also switching-mode power supply and SMPS) is an electronic power supply unit (PSU) that incorporates a switching regulator. While a linear regulator maintains the desired output voltage by dissipating excess power in a pass power transistor,
    the SMPS rapidly switches a power transistor between saturation (full
    on) and cutoff (completely off) with a variable duty cycle whose
    average is the desired output voltage
    Brigadier General:
  • 5,158 Answers
Check to make sure the power button is not sticking as that will cause it to start then shut down
Robert
  • Roberta Smith
    Roberta Smith Jan 09, 2009
    because it was working before it shouldn't be anything major... any beeps when you turn it on... as well you may want to take the cover off and reseat the memory as well
    Robert
Dell optiplex 380 won't turn on
steve it can be many things.3-4 but you don't give enough information
Apr 03, 2013 | Dell OptiPlex 380 MT Desktop Computer...
Blinking amber power button light on Optiplex 990
It seems you have a problem with your Processor regulator that is why your computer sending an amber message.
This problem always happens to Dell Optiplex mostly and there is no solution for this except replacing your Motherboard.
To verify this problem unplug yellow (2 yellow and 2 black cables) cables near the processor and then try to turn it on when you see the fan processor can run smoothly and the power light getting green that is the sign that your processor regulator having some sort of problem.
Hope this will answer your problem
Apr 30, 2012 | Dell OptiPlex 990 SFF 1 x Core i7 2600 34...
HiI have a dell desktop and won't start. for a second the fan spin than the power button turn yellow. help
hi,
Does your desktop is making any beap sounds? Are you able to see the dell logo on the startup on the screen? Please do let me know these things.
Mar 08, 2012 | Dell OptiPlex GX280 PC Desktop
Dell mini computer power button blinks orange whats the cause?
A blicking power light and no boot indicates one of two things. First, an error on the motherboard caused by failed capacitors or two a power supply that is not putting out all of the correct voltages. To check the motherboard look over this article:
http://www.ccl-la.com/blog/index.php/dell-optiplex-745-repair/
If you don't see any bad capacitors then the power supply will need to be changed.
I hope this helps, if so please rate my solution.
BuddyMc
Nov 29, 2011 | Dell OPTIPLEX 745 PC Desktop
Hi my desktop dell gplex520 not booting when i on the power button showing red light and cpu fan is working
I have written a tip entitled My Computer is not turning on!!! Is it dead!!! No POST!!! it is a very good read if I say so myself. You will be able to get your PC going again just by reading it and following the steps/instructions.
Nov 13, 2010 | Dell OptiPlex GX260 PC Desktop
My pc won't give signal
The first thing that I would check is that the cable to the power switch is plugged into the mother board correctly. It almost sounds like the plug is backwards or offby 1 pin.
Ron
Dec 10, 2008 | Dell Optiplex GXA PC Desktop
I need help hooking my mother board up
See here below and let me know if you need more help.
Oct 01, 2008 | Intel Desktop Board D845WN Motherboard
Possible hardware conflicts when installing a new monitor.
No, i was running windows xp professional edition. I finally got so fed up I went and bought a new computer. i would still like to have any suggestions about how to fix it since i have three of the darn things and would like to find a use other than paper weight for them.
Apr 27, 2008 | Dell OptiPlex GX270 PC Desktop
Dell OptiPlex GX520 PC Desktop Logo
15 people viewed this question
Alun Cox
