Question about Dacor ED24 Built-in Dishwasher
Dacor dishwasher doesn't get dishes clean Model MDW24S
I live in a rural area with no service for Dacor. Dacor is sending new sprayer arms for me to replace the old ones with. They suspect cracks or plugged holes but I don't see them. I should add that this is a brand new DW. I have checked the water temp. >120F out of the tap but only 80F in the bottom of the DW. I have it set to "high temp" but when I check the temp it is still 80F. I cannot find a schematic drawing to find out where the heating element is as it is not inside the dishwasher cavity. HELP
  • beachave Jan 16, 2009
    I have a newer Kenmore and the agatation wand at the bottom dosent send to turn when the washer is going.
  • 1,891 Answers
Sagegril you have a good dishwasher and your problem is not new / you belong to a very large club .ans. is 120 deg at the tap iwon't get the job done . and any higher tempt is child abuse .. your d/w probley and a pot & pan setting . and hi tempt wash/ and rinse . set these to work . run the long cycle / this raised the water tempt in tank . always use fresh dergt. ( not liq ) and not what is on sale . and your dw will start working for you . m.m
Posted on Nov 20, 2009
Top rack not cleaning dishes. model # FDB1050RES2
Hello, check the sprayer arm on the top of the dishwasher inside and to see if it spins. Don't block this spray arm with glasses or dishes that could block the operation of this sprayer cleaning arm.
Now, if it not spinning, check out the fitting arount hing bolt. If this wore out then you will have water pressure lose. Replace if need be. Also, check the feeder water spout that runs the upper spray army, it could be pluged. GB...stewbsion
Aug 31, 2011 | Maytag Dishwasher
Your sprayer arms may be clogged.
The upper arm attaches to a tube in the back of the dishwasher. If the support clamps come loose, the upper spray tube will not be flush with the tube and can't carry water to the sprayer arms. Also the sprayer arms can become clogged with paper remnants, bone fragments, or pieces of peeling. You'll need to remove the sprayer arm and flush it at your sink. If there is a jet that is clogged, tweezers will help remove the residue.
Finally, the bottom of the door INSIDE the washer often get covered with gunk. Be sure and gently wash the bottom of the door INSIDE. You can open the door, spray some window cleaner on the bottom and then gently brush away the 'gunk.' Rinse with hot water from a pitcher or your sink sprayer and this can eliminate some of the residue that is showing on your dishes.
I hope this helps. If it does, please come back to Fixya and rate my answer
Jun 11, 2011 | Kenmore PRO 24 in BuiltIn Dishwasher with...
I have a ge quietpower 3 dishwasher. Lately it has stopped cleaning the dishes. Sometimes the dispenser tray doesn't open. Sometimes it does open and the soap pac hasn't disolved.
Make sure your water temperature is hot enough to dissolve the soap. Generally, the water temp. should be 140 degrees. Run some hot water at the tap before you turn on the dishwasher. This will assure that hot water is in the dishwasher as soon as you start it. Be certain that there aren't any large pieces in front of the dispenser tray. Sometimes casserole dishes, frying pans or baking pans can block the door and prevent it from opening.
Also, the sprayer arms might be clogged with bone fragments, peelings, bits of paper, etc. If this is the case, you'll need to remove the sprayer arm, flush and then check the jets. If you see "stuff" in the jets, they can be remove with tweezers.
Finally, make sure the upper sprayer arm hose is securely seated with the tube in the back of the dishwasher that carries the water up to the sprayer arm hose. If these two are not seated correctly, the water will not travel into the sprayer arm hose, the sprayer arm will not turn and your dishes will not get clean! I hope this helps. If it does, please come back to Fixya and rate my advice.
Jun 10, 2011 | Maytag Dishwasher
Top sprayer is not cleaning dishes. No water is coming out on the dishes.
There may be one of two problems here and you're going to have to stick your head inside the dishwasher to solve either of them by yourself. First, in the back of the washer is a tube that goes up to the top shelf. The sprayer tube fits OVER the mouth of the other tube and then carries the water to the arm. Sometimes the support brackets for this tube become dislodged and the sprayer tube just droops but doesn't connect with the water tube. Check this first and reattach the brackets.
If this is not the problem, you might have to remove the sprayer arm (should be a screw or bolt under the arm) and flush it at the sink. There may also be pieces of paper or fragments of bone or fruit and vegetable peels stuck in the spray openings. If these won't slush out, you'll need to remove them with tweezers.
I hope this helps. It always works for me. If I have helpee, please come back and rate my suggestion!
Jun 07, 2011 | KitchenAid 24 in. KUDI01ILBS Stainless...
I own a GE Profile Trition quietpower III GSD5940F00SS dishwasher. The dishes, particularly the mugs and cups, are not getting clean.
Your sprayer arms may be clogged. You can remove them by loosening the screws holding them in place. Flush them with the sprayer at your sink. If you can SEE residue (parts of paper labels, bone fragments, fruit peel pieces, etc) remove them with a tweezer.Reinstall the spray arms and see if that works.
Three more ideas:
(1) run a cycle without dishes OR detergent and use 1/4 cup of white vinegar instead. This will break down soil and "gunk" and help your dishwasher run more effectively.
(2) use an old toothbrush and clean the underside of the door INSIDE the dishwasher. The door will be open and you just brush the bottom of the open door on the INSIDE of the dishwasher. A lot of "crud" gathers there and can be redeposite on your dishes. We seldom think to check that area.
(3) the pipe that carries water to the upper sprayer arm MUST fit against the outlet in the back of the dishwasher. If it is dislodged or not seated properly, the water won't flow to the upper sprayer arm.
Hope one of these suggestions helps. If it does, please rate my suggestion. Thanks.
Jun 03, 2011 | GE Dishwashers
My dishwasher is leaving a lot of residue on dishes
I had the same problem and fixed it by disassembling the lower spray arm and return filter, and cleaning all the junk out.
Most dishwashers have 'risers' that bring the water up to the top sprayer or arm located under the top rack. If the recirculating pump is plugged even a little there won't be enough volume or pressure to get the water up there.
Test this by putting a dry muffin pan in the top rack, flat, and running the dishwasher for a bit. If there is no water on the top (or the bottom) either the top sprayer or the sprayer arm underneath the top rack is not getting enough volume.
To fix this you need to clean out the screen and filter, where the water returns to be recirculated. If you don't have any confidence to remove the parts and clean it out yourself, get an appliance repair person to do the job.
Aug 26, 2009 | Dishwashers
My kenmore dishwasher model66516034401 does not
do you have a sprayer on top portion of dishwasher? if you do make sure it turns when dishwasher is running. check to see if holes in sprayer are open and not colgged up. you can clen it by pacing it in vinegar.
Aug 20, 2009 | Kenmore Dishwashers
Dishes in top rack not getting clean
If you live in an area with 'hard' water (having more than 5 ppm) you may require a whole-house treatment system to eliminate the mineral content that will wreak havoc with any water-related system (including your water heater).
If that is not the case I would have a service call to check the upper level service arm, which must be pushed in to a hole in the back of most units in order to get the water to flow in.
Oct 01, 2017 | GE 24 in. Profile PDW9880JSS Built-in...
Dishes not getting clean in GE Triton XL Dishwasher
Step 1: Remove the cap that holds the sprayer arm on.
Step 2: Remove the sprayer arm, the screen, the pump housing, a bolt, the upper impeller, the food disposer blade, a spacer plate, the impeller hood, a flat plate, an O-ring, and the lower impeller. Lay the parts out in order as you disassemble them so that you'll be able to reassemble them properly.
Step 3: Clean the parts thoroughly with a mild detergent solution. If any parts are worn, replace them with new ones made for the dishwasher.
Step 4: Replace any seals, such as the O-ring or other washers, with new ones.
Step 5: Reassemble the pump, keeping the parts in order.
To reach the water pump, remove the sprayer arm and screen and then the pump housing. Remove the bolt, and the pump components can be disassembled.
On some dishwashers, the lower impeller serves as a drain pump. This type of system usually has a reversible motor; machines with nonreversible motors have drain valves, as detailed previously. If your machine possesses this impeller pump system, and the water will not drain from the dishwasher, clean the lower pump impeller. This may solve the problem. Otherwise, call a professional service person.
Oct 12, 2008 | Dishwashers
I have a maytag mdb4000aww dish washer. The dishes aren't getting consistently clean. I wanted to clean the trap/filter. There's two ports towards the front side. The one on the right i was able to...
The port on the left is the float it has no filter don’t try to remove it. To get your dishes cleaner: step one, each time you wash run the tap water in your sink till it’s hot. Step two, buy what’s called “dishwasher magic” use that every 2-3 months. Three, use rinse aid. Four, check the sprayer arms, make sure all the holes are clear and that they spin freely when the dishwasher is loaded. There is the possibility that the interior motor area needs to be cleaned, if you’re handy you can remove the lower spray arm and the cover, lift that up to expose the interior motor area, this is fairly involved, if you’re not comfortable you should call for repair, it shouldn’t cost too much.
Apr 01, 2008 | Dishwashers
Dacor ED24 Built-in Dishwasher Logo
167 people viewed this question
Top Dacor Dishwashers Experts
Are you a Dacor Dishwasher Expert? Answer questions, earn points and help others
