Question about Mabis Health & Beauty
Mabis mist II not making mist
I have had nebulizer for 1.5 years. Used several times per week for that time.
Last time I plugged it in and red light came on and then it appeared to go dead. I could not turn on nebulizer.
  • 40 Answers
Have you checked the wall plug to which you have tried to plug it in or maybe the cord to your nebulizer has a short in it somewhere and last maybe you need a newer model. Good Luck!
Posted on Jan 24, 2009
Omron vibrating mesh nebulizer quit working
You must be having trouble with the battery. Also please keep the nebulizer properly cleaned as instructed on the pack. Check the connection properly or replace the batteries if needed. Also check out for more information about Omron Nebulizer on the web. It would help you a lot.
Aug 06, 2012 | Omron Health & Beauty
My ne u22v is not making mist
You should check if the battery is working fine. I don;t think Omron U2 nebulizer can have any other problem as it works really good for me. Also it is important to clean the Nebulizer properly and please check out the manual for more info. which you would have received while purchasing the Nebulizer.
Aug 06, 2012 | Omron Ne U22V Microair Vibrating Mesh...
40 270 000 Mist II Ultrasonic Nebulizer With Recharge Battery: Have Model MABIS MIST 11 Ultrainsic Nebulizer Mod...
I, too, am looking for a manual for this product. I get a green light, but it does not appear to have any airflow coming from it.
May 17, 2010 | Mabis 40 270 000 Mist II Ultrasonic...
How often should the Micro Mist Nebulizer be discarded and why?
Every two weeks. If you wash in a solution of one part distilled white vinegar to three parts water once a day it can last much longer. Vinegar is a great disinfectant and will reduce the chance of infection. Most people are slack at this cleaning process hence the normal disposal of the kit at two weeks.
Apr 28, 2010 | Hudson Rci 1 OF MICRO MIST Nebulizer...
Compressor works ,but does not put out enough pressure to make a mist from the pulmicort 5-1/2 years old used 2 times a day
You probably need a new diaphragm in the pump. Contact your insurer, they might replace the entire unit for you. In a pinch, you can use a vibrating style fish tank eirator pump, since there isn't any real positive pressure coming out of the facepiece.
Oct 12, 2009 | Inspiration 626 Compressor Nebulizer...
Routine cleaning Mabis XP.
If your unit is the one pictured, he cup with the medication can be taken apart to be cleaned... the top unscrews and the nebulizer comes out....and should be done so after every use. Do not use house hold chemicals to clean the unit. Use a water/distilled vinegar mixture to clean, then rinse with clean water.
Apr 07, 2009 | Mabis Neb Xp Portable Handheld Cmpressor...
Omron nebulizer will not mist. All tubing is intact. What to do?
You'll read a lot about making sure that the filter is clean and that the medicine cup is cleaned and that hard water can effect the operation of the nebulizer. However, the problem is most likely in the pump. Even though the pump is running, it is not pushing enough air into the medicine cup. You may even feel air coming out of the tube. When unrestricted, the air will come out, but, once restricted by the medicine cup, the air may not be fast enough to nebulize the liquid. If you want to confirm this, take the tube and hold it to the end of a bike pump, if, while pumpung, you successfully see mist, then you know for sure.
Fixing the pump is not too difficult. Over time, the chamber where the air is compressed becomes dry and, just like a dry bike pump, the air escapes from the chamber due to poor seals. The pump is pretty simple. Make sure it is unplugged from power and remove the screws holding the housing together. Inside you will see the motor, a fan, a power switch and the intake and outtake tubes. Follow the outtake tube to the pump. The junction where the tubes meet the pump is the location of the air chamber. You may need to remove the screws that secure the tubes to the chamber. Once apart, take some grease and lightly coat all of the interior surfaces of the chamber. When finished, reassemble and you're good to go!
Mar 23, 2009 | Omron Healthcare Omron NE-C25 COMP-Air...
Hudson nebulizer leaks
If tap water is used, you may have a buildup of lime deposits; allow it to dry and then look for any white deposits.
Using distilled water will avoid this.
Feb 13, 2009 | Hudson Rci T UPDRAFT II NEB MOUTHPIECE...
Health & Beauty Logo
452 people viewed this question
Top Mabis Health & Beauty Experts
Md Fazlurrahman
Md Fazlurrahman
Level 1 Expert
Dan Webster
Dan Webster
Are you a Mabis Health and Beauty Expert? Answer questions, earn points and help others
