Question about Motorola Mobility RAZR V3
Voicemail Malfunction I just put my sim card in a different phone and now when i call my voicemail, it says "Call Failed: Network Busy". How do I get my voicemail to work again?
    Sergeant:
  • 290 Answers
If you are using a different phone and using the press and hold 1 for voicemail dial the new phone might have the wrong number programmed. Dial your actual number from your phone (call yourself) and see if it works
Posted on Jan 09, 2009
How do I delete the voicemail option on my phone? My phone is a Dterm Series E NEC
Your phone is call forwarded to the voicemail pilot when busy or not answered, so just cancel the call forwarding. NEC uses these phones on several different systems so I don't know what your code is.
Jun 13, 2014 | NEC Dterm DTP-2DT-1 Phone
I earsed my voicemail number andnow i cant access my voicemail
To get back your voicemail enquiry number, check on another sim card of your network. You can also check the information pamphlet that came with your sim starter pack when you initially purchased the sim card. If these dont proove helpful, then call your customer care and as them for the number.
Please let me know if that was helpful.
Have a nice day.
Jul 03, 2011 | Nokia Cell Phones
How do I set up voice mail
Call services From your phone, you'll be able to access and change the settings of various call services for your phone.Contact your mobile operator to find out about the availability of call services. From the Home screen, press MENU and then tap Settings > Call. Fixed Dialing Numbers Restrict outgoing calls to a fixed set of numbers. To enable this feature, you must know your SIM card's PIN2 code.
Voicemail service Shows the current voicemail service being used.
Voicemail settings Specify another voicemail number aside from the voice mail number on your SIM card.
Clear voicemail notification If you have a notification of a new voicemail, you can clear the notification with this option.
TTY mode Enable this mode to connect and use a compatible TTY device with the phone.
Hearing aids Enable HAC (Hearing Aid Compatible) to amplify in-call volume.
Phone settings Edit the call reject message, choose whether to open the message editor when you reject a call with a message, and choose whether to allow automatic saving of an unknown contact number when a call with that number ends.
Cell broadcast Enable or disable receipt of cell broadcast messages from your service provider.
Cell broadcast settings Configure channels and language for cell broadcast messages.
Call forwarding Select how you want your phone to handle busy, unanswered, and unreachable calls. You can also set the call forwarding option for all incoming calls. Call barring settings Choose whether to block various categories of incoming and outgoing call.
Additional settings Enable or disable operator services such as caller ID and call waiting.
Jun 28, 2011 | HTC Inspire 4G Smartphone
How do I forward my phone (DKT-2020-SD) to voicemail?
This does depend on which Toshiba phone system your phone is connected to
Here are a couple possible methods
Press button
Dial 601(all calls) or 602(busy) or 603(no answer) or 604(busy/noanswer)
Dial voicemail access code(extension number of voicemail)
Press button to end
Press button
Dial #601(all calls) or #602(busy) or #603(no answer) or #604(busy/noanswer)
Press button to end
Dec 08, 2010 | Toshiba DKT-2020-SD telephone
Calls wont go to voicemail,call voicemail and get a busy signal
are u dialing ur voicemail by using direct dialing icon?
If so, u need to contact ur service provider and get the voicemail number , put that number in again. Enjoy direct dialing.
Jul 25, 2010 | Motorola Cell Phones
Nokia 6131 Voicemail symbol but no voicemail!
The solution is to take your sim card out of the phone, insert another sim card and switch on. After a few minutes remove this sim card and re-insert your original sim card. The voicemail symbol will now be removed.
Apr 30, 2009 | Nokia Cell Phones
No issue, just a question. Looking at RCA 25425RE1 4 line business phone system. If all four lines are busy , will the caller of the 5th call get a busy signal or does the phone have "busy no answer...
ANY phone system will have this problem.
If 5 people call in, the first 4 will be answered, but the 5th will get busy, as there are no lines available into your phones voicemail system.
IF, you have voicemail through the phone company, you can get their voicemail feature for extra.
THEN, if 5 people call in, the first 4 go to the phones, and the fifth gets the voicemail greeting.
It would be dependant on the line provider how many calls their voicemail would handle at one time. SO if 500 people call in, 4 get through, and MAYBE 5 go to voicemail, the rest get busy.....
Jan 13, 2009 | Lands Phones
MY G1 won't dial from the contacts list.
you probably had the sim card in a phone that had text messages stored on it.....might be time for a new sim card.....
try turning off the handset and turning it on again. eitherway, if you replace the sim card that should update the voicemail number in the network fixing that error. or just call t-mobile at 1800-937-8997 and they should be able to gix it from there. this is a network malfunction that cannot be fixed from your end if the powercycle fails. good luck!
Dec 02, 2008 | HTC G1
I saw your reply phone lock
Your pin number is probably your sim code!
Check PUK
SIM pin code:
This is a pin code that locks the sim card until you enter the correct code. This protects your account, even if your sim is put into another handset. To reset it, you need the PUK code:
Pin Unlock Code (PUK)
If you miss key (or forget) your SIM pin code, and enter the wrong one 3-5 times in a row, the SIM will lock up, and you’ll need to enter the PUK unlock code to release it. You should ask your Network Service Provider for this code when you need it. Don’t try to guess it, because after a few wrong guesses, the SIM card will be permanently disabled.
Phone Security Code:
This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a “new” sim if the phone security code is entered. To reset it, you need the Master code code:
Master Reset Code
Sometimes known as the Master Code, this allows you to unlock a handset if you have entered the Security Code wrongly too many times.
Are you sure it’s the Master code you need. Which is the one that you want?
Special Code/Service Provider Lock Code:
This code is required to allow a phone locked to a particular network's SIM cards to be used with a SIM card from another network. Orange and T-mobile lock handsets in this way, though O2 and Vodafone are beginning to lock PAYG and WAP handsets. The unlock code varies from individual handset to handset.
Blacklisting:
This is not a security code, but it works like one! To help combat mobile phone thefts, the networks share a database of the IMEI (International Mobile Equipment Identity) of mobile phones that have been reported stolen. Once a phone is on this list, it will not be allowed to use any of the networks.
This can be a risk if you buy a second-hand phone, because if it has been stolen, or if an unscrupulous seller makes an insurance claim after selling, the phone you bought in good faith may be permanently disabled.
Be very careful to check the source of a second-hand phone!
Voicemail Pin:
This is a code that you choose to secure the voicemail/answer phone service on your mobile phone account.
If you do not set a voicemail PIN, you may not be able to access voicemail from anywhere but your own mobile phone. In some cases, leaving the voicemail PIN at the default can let other people listen to or delete messages left for you. There may be a default code (3333 on Vodafone), but you should change it straight away!
Jun 29, 2008 | Sony Ericsson W200i Cellular Phone
RAZR V3 voicemail problem
have you set your voicemail yet? you need to set your voicemail in order for it to work.
Jan 24, 2008 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
115 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
