Question about Canon PIXMA MP160 All-In-One InkJet Printer
Ink cartridges I cannot even put the cartridges into the scanner. I really am not ignorant but this scanner cartridges won't slide in.. Please help
  • christina101 Jan 13, 2009
    hmm.i have tried every which way to be honest. I will try upward again.
  • christina101 Jan 17, 2009
    Thank you for your time. I believe this scanner is defective and i'm going to take it back, but i appreciate your help.
Are you snapping them upwards when in correct position ?
Posted on Jan 10, 2009
  • aboy24 Jan 13, 2009
    Cartridges slide in then snap upwards to lock in place
Ink cartridge in Z705 will not move to center of carriage for changing when top is lifted Even though the Belt is moving. Help !!!!!!!!!!!.. >:( :( :'(
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
I hope this helps.
Oct 24, 2011 | Lexmark PhotoJet Z705 InkJet Printer
I am trying to change my ink, when I open the scanner the cartidge do not come to the middle so I can change it what can I do to correct this problem.
Sep 06, 2011 | Lexmark X2350 All-In-One InkJet Printer
How do i install mt inks
Please follow the steps below on how to install/replace ink cartridges on your model:
  1. Make sure the All-In-One is on.
  2. Lift the scanner unit until the scanner support keeps it open. The print cartridge carrier moves and stops at the loading position unless the All-In-One is busy.
  3. Grasp the tabs on the cartridge lids, and then lift the lids.
  4. Remove the old cartridges. Store them in an air-tight container or dispose of them.
  5. If you are installing new cartridges, remove the stickers and transparent tape from the bottom of the cartridges.
  6. Insert the new cartridges. Make sure the black print cartridge is secure in the right carrier and the color cartridge is secure in the left carrier, and then snap the lids closed.
  7. Lift the scanner unit and push the scanner support back while lowering the scanner unit until it is completely closed.
Aug 30, 2011 | Lexmark X1270 All-In-One InkJet Printer
How do I change the ink cartridges on a lexmark 5495
Please follow the steps below on how to replace ink cartridge on the Lexmark X5495 printer:
  1. Make sure the printer is on.
  2. Lift the scanner unit. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
  3. Press down on the cartridge carrier latch to raise the cartridge carrier lid.
  4. Remove the used print cartridge.
Aug 14, 2011 | Lexmark X5470 All-In-One InkJet Printer
Do not know how to change ink cartridge x2650
Lift the scanner unit, and then press down on the cartridge carrier latch to raise the cartridge carrier lid. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
Remove the used print cartridge. Insert your new cartridges.
Apr 28, 2011 | Lexmark C533DN InkJet Printer
How to change printing cartridges
Here's how to change your cartridges: 1 Make sure the printer is on. 2 Lift the scanner unit. The print cartridge carrier moves and stops at the loading position, unless the printer is busy. printmastert_25.jpg
3 Press down on the cartridge carrier latch to raise the cartridge carrier lid. printmastert_26.jpg
4 Remove the used print cartridge. Note: If you are removing both cartridges, repeat step 3 and step 4 for the second cartridge.
You may also refer to this link: How to Set Up the Lexmark X3600 or X4600 Series All-In-One
Apr 04, 2011 | Lexmark X3650 Printer
Where can i put lexmark ink?i can't see the place where should i put the new ink for lexkmark x2650
Make sure the Lexmark X2650 printer is on. Lift the scanner unit to access the cartridge area. The cartridge carrier will move to the center automatically for the loading position.
Press the down the carrier levers to open and remove the used cartridges. Load the new cartridges and close the cover. Close the scanner unit.
Sometimes the ink cartridge carrier won't position automatically to the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the carrier to the middle of the printer. Load the cartridges. Close the cover. Plug the printer back to power source. Thanks.
Nov 06, 2010 | Lexmark X2650 All-In-One InkJet Printer
I can't figure out how to replace the ink cartridge. How do you remove the old ink cartridge and put in a new one?
Here's an article in the Lexmark website that will guide you on how to replace the ink cartridges on your Lexmark X5150 printer. Just click on this link: http://bit.ly/bKZ15F. Follow the instructions carefully. By the way, in some cases, the ink cartridge carrier doesn't move in the loading position even when the printer is on when you lift the scanner unit open. If that happens, unplug the printer from the power source. With the scanner unit open, hold the solid white tape you see in the printer. Slowly slide the cartridge carrier to the center for easy access. Replace the cartridges. Close the cover, close the scanner unit. Plug the printer back to the power source. Hope this helps. If you need more assistance, just place a comment so I can get back to it.
Apr 19, 2010 | Lexmark X5150 All-In-One InkJet Printer
Canon Pixma MP 240 keeps blinking E4
E4 just says the ink is empty, Either your ink is gone , or you have a defective cartridge.
Aug 03, 2009 | Canon PIXMA MP240 All-In-One InkJet...
My printer can't read the new ink level after refilling
The ink level indicator is only an estimate to give you an idea when it's time to buy a new cartridge. You cannot reset the ink level indicator so simply ignore it if you refill your cartridges. See pg 72 of the user manual which you can get here: http://h10032.www1.hp.com/ctg/Manual/c01374711.pdf
Dec 06, 2008 | HP DeskJet F4280 All In One Printer InkJet
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
19 people viewed this question
old marine
old marine
