Question about Frigidaire GLRT186TA Top Freezer Refrigerator
Freezer not cooling
Model GLRT186TA freezer not staying cold enough. The refrigerator is working fine. Everything has melted in the freezer. The fan is working, I can hear it running in the freezer. We cleaned all the coils. What can the problem be?
  • 51 Answers
There is an external fan near the compressor usually at the bottom of the unit on the back side and if this fan does not run the freezer will not freeze. u can also look for a defrost timer located near the bottom of the refrigerator with the door open or just under the freezer in the refrigerator compartment. It will look like a plastic screw that can be turned only one way with a flathead screwdriver because of its design. Some times these timers just get stuck and will work again if u rotate it with a screwdriver one revolution or two. Allow an hour to see if freezer works after tuning. Please rate me
Posted on Jan 09, 2009
Freezer side not cold enough, similar temperature as Refrigerator side
It could be many things. My first guess would be the defrost. The coil that gets cold in your freezer builds ice on it and the only way to get the ice off is to run a heater near the coil long enough for the ice to melt. All freezers have something built in to defrost and domestic are typically just an electric heater on a timer. When your freezer stops working again, you may want to pull open the panel of your freezer and see if your coil (a heat exchanger that probably looks a lot like your car radiator) is covered in ice. If it is, it could be the timer or the actual heater that is bad.
Nov 12, 2013 | Refrigerators
Freezer stays cool but bottom stays warm.
I agree with your analysis, and recommend that you replace that fan between the two sections.
May 20, 2008 | Kenmore Refrigerators
Not freezing
This unit has issues with the evap fan freezing up. If you heard a grinding noise coming from freezer, fan froze up. Unplug unit, open freezer door and if you have a box fan, point it into freezer for a couple hours. Be sure to unplug fridge
Aug 18, 2012 | LG LSC26905TT Side by Side Refrigerator
Refrigerator not cooling-Freezer Coils Freeze Up & Don't Defrost
check the fan assembly theres not enough air flow going over the coils
Feb 11, 2010 | Maytag MBB2254G Bottom Freezer...
Model gss20iepcbb freezer side works fine ...fridge
on most units they have two controls refrigerator control is electric t-stat that runs compressor freezer control think of it as a door colder freezer door is barely open warmer freezer door all the way open all cooling coils are in the freezer and a fan moves the air to refrigerater side possible problem fan not running
door freezer control all the way closed
light switch broken light staying on door gasket not sealing tight find door switch press verify light shuts off and fan starts
look for torn or damaged door gasket can look from outside with light and see if gasket contacts case on all four sides
freezer is cold enough so compressor is ok hopr this helps good luck ron
Dec 10, 2009 | Refrigerators
My kenmore refrigerator side by side
All the cooling takes place in the freezer and is blown over to the frig side so the frig side will start to warm up soon. Possible cause is the starting device to the compressor is faulty, compressor motor locked up or cold control faulty and not closing.
Feb 19, 2009 | Kenmore Refrigerators
Frigidaire glrt186ta, the freezer is not cold enough, everything melted. The refrigerator seems ti be fine. All the coils were cleaned and I can hear the fan running in the freezer. There appears to be no...
there is another fan under the refrgerator usually near the compressor. if this fan is not running then your freezer will not freeze. If this fan doesnt work your fan or your defrost timer is bad. please rate me
Jan 09, 2009 | Refrigerators
Fridge is not cold enough, freezer is working fine, but has frost
Just had the same problem with my side-by-side.
In my case, the solution was to empty the freezer side, to access a back panel INSIDE the freezer covering the fan and cooling coils. Two screws held the back panel cover on, and when I removed the panel cover I found the cooling coils to be totally iced up, preventing the flow of cold air into the fridge side. I left the freezer open for a few hours until all the ice was melted, before replacing the inside panel. (I used a blow dryer to help speed up the ice melting).
Everything's working fine now for me - good luck with yours!
Nov 17, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Bottom freezer not staying cold
One of two things. When you open the freezer drawer, do you hear a fan running? If not, that's the problem. The Evaporator fan. Its' job is to circulate cold air throughout the entire cabinet. Without it, things get toasty. If not the Evap Fan, it'll be the sealed system... meaning that it's developed a leak and freon is escaping (not harmful for you or your Family). If it's just under 5 years old, this will be a warranty repair. Over 5? Bad news... it'll cost ALOT to have it repaired.
Jul 29, 2007 | Amana ABB1927DE Bottom Freezer...
Frigidaire GLRT186TA Top Freezer Refrigerator Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
