Question about Plantronics CS50 Wireless Headset
Head set beeps 3 times, can't connect
My headset beeps three times. I've replaced the battery with a new one (that works in a different headset.)
The orange light is flashing to indicate that the battery is charging but it still doesn't work after more than a day of charging.
The red light never illuminates.
  • Anonymous Feb 23, 2009
    I have the very same problem with my headset. I also replace the battery but nothing changed.
    Tj
  • 32 Answers
SOURCE: Plantronics cs50 head set with lifter has STATIC
Try a system reset:
1.  Lift the headset off of the charging cradle, but make sure the headset is turned off.  It will be off if the green light on the front of the base is not lit.  If it's not, push the call answer button once to turn it off.
2.  Push the call answer button and the mute button at the same time and hold them down.  The mute button is the black little wheel at the top of the headset.  Use the tip of your finger to push it straight down and hold it while holding the call answer button.  A green light on the headset will flash for 2 series of flashes.  Wait until the end of the second series then let go of both buttons.
3.  Put the headset back on the charging cradle and wait 30 seconds.  Lift it back up and try to use it.  If this doesn't work, repeat one more time and then disconnect the power from the base and plug it back in.
Posted on May 22, 2009
Peter Denton
  • 16 Answers
SOURCE: plantronics voyager 510 headset
Make sure the headpiece is charged. Turn the headpiece off by pressing the little black button on top of the earpiece and holding for about 5 seconds. Turn the earpiece back on again the same way. You should have a slow flashing blue light on the mic boom. The base station will now try to find the earpiece and within about 20 seconds the red light on the base should be steady and blue light on top should be on.
If this doesn't work you may need to manually pair the earpiece to the base by pressing and holding the Listen Volume Adjust + Button and headset Call Control Button on the earpiece until the light on the mic boom flashes red and blue repeatedly. As above, the base station will now try to find the earpiece and within about 20 seconds the red light on the base should be steady and blue light on top should be on.
Posted on Nov 05, 2008
mp3stud
  • 15 Answers
SOURCE: Turn on head set light flashes blue then blinks red
I found a guide that tells you what the different colors and lengths of flashes mean. Have a look for yourself. It seems like you have a low battery by how you describe it. You'll be Bluetoothing again in no time! ;-)http://plantronics.custhelp.com/cgi-bin/plantronics.cfg/php/enduser/std_adp.php?p_faqid=1169&p_created=1047671477&p_sid=C4BU4zzj&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NjUsNjUmcF9wcm9kcz0mcF9jYXRzPSZwX3B2PSZwX2N2PSZwX3NlYXJjaF90eXBlPWFuc3dlcnMuc2VhcmNoX25sJnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9NTIw&p_li=&p_topview=1
Posted on Jun 05, 2009
SOURCE: I Can`t switch my headset on, and it stops charging after 20 secs
Move the call control button up or down, the indicator light will flash blue if it's paired or blue and red. If it flashes blue and red you need to pair phone with the headset. the passkey is 0000.
Posted on Aug 08, 2009
  • 5603 Answers
SOURCE: my headset will not hold a charge CS70VT
The only thing is to check the voltage output by the charger... usually 5 volts. The lights MAY blink even if voltlage is too low.
If it is OK, then battery in the headset has failed. Have the battery replaced or DIY if not under warranty.
The usual cause of this is to continue using batteries under load when one of the cells is totally depleted.
Posted on Nov 09, 2009
Bluetooth conecton faild
You need a new one, the batteries only last a couple of years.
Apr 17, 2012 | Jabra BT3030 Bluetooth Headset
Seems to be connecting, phone says it is connected, beeps like its connected, but yet does not work.....calls still go through the phone itself.....
Below are the steps for resetting the Bluetooth table in your cell phone and on the B150 headset.
1. Go into the device history / trusted device list of your cell phone. Delete / remove all the devices / headsets from the device history in the cell phone (highlight or move the screen cursor over the device and you should get an options choice one of which will be delete or remove).
2. Once all the devices / headsets have been deleted / removed, shut the cell phone off.
3. (If you have a smart phone with downloadable apps ie. I-phone, check with your provider before doing step #3 to insure battery removal will not clear applications you have purchased or downloaded). The purpose of step #3 is to clear any keep-alive memory the phone and headset were holding. Remove the battery from your cell phone for 15 minutes.
4. With the headset powered on (it does not have to be connected to the phone, just powered on) , hold the volume up and volume down button at the same time until you hear 2 beeps (easiest to do if you hold the set in front of you and use both thumbs). This step clears the Bluetooth table of the headset.
5. Place the headset back on its charger for the remainder of the 15 minutes the battery is out of the phone. It is not necessary to shut the headset off prior to placing the headset on the charger.
6. After the 15 minutes is up put the battery back in the phone and turn the cell phone on.
7. Turn the phone on and get it ready for paring. Consult your phones user guide or call your service provider for help with your cell phone.
8. Put the headset in pairing mode by holding the Multi-Function Button until the lights are flashing alternating Red and Amber, you will then release the Multi-Function Button. Please note the headset will continue flashing Red and Amber until the paring cycle times out (approximately 2 minutes) or completes the paring with the cell phone. If you only press and release the Multi-Function Button the headset will not go into the paring mode.
9. Pair the headset and cell phone together.
Once the headset is in paring mode, go to the Bluetooth menu / connections of your cell phone. Select add new / search for / find new device (different phones have different but similar names for the options). The cell phone should find a device called BTHS. Move the cursor over the BTHS and press (OK, select, enter, or whatever your phone uses for a prompt). If the cell phone asks for a passkey code you will put in 0000 (four zero's). The headset will then pair and connect to the cell phone. Your phone may ask you if you want to connect to the BTHS and/or add it to your trusted device list, press (OK, select, enter, or whatever your phone uses for a prompt).
Aug 29, 2011 | VXI BlueParrot B150 Wireless Headset
Blue Parrott Road Warrior B250XT, will not stay connected to my phone, The phone is a Motorolai335, it will connect and disconnect just when ever some times every 3 to 5 minutes and will reconnect within...
These steps are for a headset that is already paired to you cell phone and is stored in the phones trusted device / history list.
Look at the lights on the Multi-Function Button of the headset (the top / largest button of the three buttons); the light will be blinking Red if not connected and blue if connected (paired and connected are two different things). Push the volume up (middle button) 2 times, you should hear a beep each time you press it. If you hear the beeps go to the next paragraph. If you hear no beeps at all you will need to call 1-800-742-8588 for an RA # (Return Authorization Number) for warranty and non warranty repairs.
Look at the lights on the Multi-Function Button on the headset (the top / largest button of the three buttons); the light should be blinking Red if not connected and Blue if connected (paired and connected are two different things). Plug the headset into the power adaptor with power applied. Make sure your cell phone is on and the Bluetooth power of the PHONE is turned on. After 5 seconds unplug the headset from the charger and do not press any buttons. You should get a slow Red blinking light at first. Allow the headset to connect automatically to the cell phone, this may take up to 10 seconds. Once the connection has occurred the Blue light on the Multi-Function Button will blink once every second.
If after 10 seconds the light is still blinking Red once every 5 seconds you will need to press either the Multi-Function Button of the headset once to connect to the cell phone, or, your phone may be set up requiring you press a designated button or sequence in the phone to connect to the headset (meaning your cell phone is not set with or does not support automatic connect).
*NOTE* Most newer model cell phones have an automatic connect feature. Some phones have the categories of "Headset", and "Hands Free" in their Bluetooth menu. Some companies use the term Auto-Connect under the "Hands Free" category in their Bluetooth menu to indicate the set up for use with the Bluetooth system in an AUTOMOBILE.
Automatic connection under the "Headset" category and Auto-connect under the "Hands Free" category are not the same thing. When dealing with the headset you want to work in the "Headset" menu and make sure the Auto-connect of the "Hands Free" menu is turned off.
If this doesn't correct the issue I'd recommend calling VXi at 800-742-8588 for additional clear and reset instructions and the possability of warranty repair options.
Aug 29, 2011 | VXI Corporation Blueparrott B250-XT...
While the headset works frequently, it will suddenly stop. Nothing I do will allow it to connect again. I hear nothing through the headset after the initial beep that indicates headset mode was enabled. ...
It sounds like the battery is no longer holding a good charge. There is no replacement battery for this headset. If you are using the original 510 headset you can replace it or pair a different bluetooth headset up to the 500A base. Just keep in mind if you decide on a different style of headset you will not be able to charge it in your base. I have included the link for the 510 replacement headset below.
Plantronics Voyager 510 Replacement Headset
Good luck from Headsets Direct!
Jul 14, 2011 | Plantronics Voyager 500A Deskphone Adapter...
Have new headset, why is the base unit keep beeping at me
Here is an explanation of the beeps you are hearing:
• One beep every 10 seconds is caused by a low battery
warning. Recharge battery by returning it to the base charge
cradle for one to three hours until charge light stays lit or
quits blinking.
• Two beeps is an out of range warning. Move closer to the base.
• Three rapid beeps every 30 seconds indicates your mute is
on. Press the mute button once to turn mute off.
• When an optional lifter is connected, three repetitive beeps
indicate a call is coming into the headset. Press the call
control button on the headset to answer the call.
Plantronics CS70 User's Guide
May 19, 2011 | Plantronics CS70 Wireless Headset
There is a constant beebing in my ear every 3/4 seconds and sometimes my customer can here this too How can i stop this???
Usually, that's an indication that the battery is dying. You need to recharge it. If the headpiece is not holding a charge anymore, you need to replace the battery. Model of battery is CPP-512Q. If the unit is fairly new, you can try reseting the battery by taking off the cap on the headset and then unplug the battery and plug it back in. Good luck.
Mar 03, 2011 | Plantronics CS60 Professional Headset
Connecting bluettoth to playstation 3
there are two different places in XMB to change your headset settings. If both of these are not active then it will not work. One is accessory settings Manage bluetooth devices and make sure the headset has a blue dot by it, the other is accessory settings also and audio device settings. Make sure the input and output device settings are set to the headset
Jan 10, 2010 | Video Game Consoles & Games
Turn on head set light flashes blue then blinks red three times and doesn't connect
Jun 05, 2009 | Plantronics Hama Voyager 520 Bluetooth...
Camera will not stay on.....
the 3 beeping sound means that the camera has low battery capacity. the lens is stuck out because there is incorrect battery connection. there is an option on the camera setting for the battery type. try this one:
-turn the camera on
-click on Menu button
-select options using left/right, up/down button
-select Set up 2
-Select Battery type
-Select Alkaline for non-rechargable
or Ni-MH for rechargable
-click OK button
this setting should be done when using camera for the first time and whenever you are switching battery types, from rechargable to non-rechargable and vice versa.
Dec 04, 2007 | Samsung Digimax S500 Digital Camera
Plantronics CS50  Wireless Headset Logo
5,180 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
skiffy99
skiffy99
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
