Question about Canon PowerShot A720 IS Digital Camera
Canon A720 won't shoot
I have power - when i depress the button to shoot it has a clicking sound but will not take a picture.
  • mm_weinberg Jan 14, 2009
    I had already cleared the memory card.
    Re-seating the card worked! - Thanks!!
  • Canon Master
  • 19,396 Answers
That is not a matter of settings.
To reset settings you just remove the battery, ensure the wheel selector is on camera mode, and on restart use the camera Settings menu with reset to factory settings option.
When it does not shot like that it is likely an hardware fault.
A technician must take apart completely the external casing to get to the switch contact, test them , and solder back or replace switch button, that you can buy calling Canon.
If you do it yoursel you risk to transform your camra into a bunch of bits and screws. Better having the job done at a repair shop.
To give you an idea here is disassembly for Powershot A70.
Posted on Jan 14, 2009
    Sergeant:
  • 431 Answers
Try formatting the camera check ur settings of the camera
Posted on Jan 09, 2009
  • nematics
    nematics Jan 10, 2009
    Have you tried removing the batteries then putting them back in? Also reseat the memory card in the camera.
    Even still it sounds like physical issue with the camera
    Sergeant:
  • 367 Answers
Even still it sounds like physical issue with the camera. Eve the above does not work let me know.
  • Rob Houg
    Rob Houg Jan 09, 2009
    Good idea or try a different memory card.
  • 10,594 Answers
Please check does memory card has free space to store pictures.
  • Shahid Electronics
    Shahid Electronics Jan 14, 2009
    Please format memory card through camera menu format / erase option and try to take picture.
I need to download some pictures from my camera, Cannon Power shot A720
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Aug 04, 2011 | Canon PowerShot A720 IS Digital Camera
My camera won't flash no matter how many new batteries I put in it. It will take pictures that don't require a flash. I've reset everything twice and nothing has worked. Contacts are clean. ...
Some Canon cameras use some of the screws around the perimeter of the camera to serve as a safety switch to prevent activation of the flash if the case is opened. See this article for more info.
Jul 20, 2011 | Canon PowerShot A720 IS Digital Camera
I have a Canon Power Shot A720. Outdoor photos are beautiful. Indoor photos are always grainy/blurry...a lot of noise. I have tried the ISP feature but there are only two choices... 1. Auto or 2....
Hi Usually outdoor picture are good within small compact camera. They designed like that. But now your unit just have flash pcb defective. When flash function work, your picture will be good indoor. Regarding your flash unit would be brown fuse or replacement of flash unit. It is 50 and 50 chance. Your local repair shop would charge around $35 to 95 depend on what they really want to charge. Thanks and best regard!
May 24, 2011 | Canon PowerShot A720 IS Digital Camera
I changed the batteries in my Power Shot A720 IS recently when the low battery warning flashed, and had taken only two photos when the warning flashed again. I moved the mode switch to playback and the...
Hi, 1st you must use alkline bat or minimum 800 mhp bat....
and if problem is not solved then cheak the bat cap and connection clean with aomthing,,,,
If any thing else contact me
Khatricamera@gmail.com
Mar 27, 2011 | Canon PowerShot A720 IS Digital Camera
My less than 2 year ollld A720 does not have any image showing on the LCD display
Check whether your LCD is bad. To do this, shoot a picture and then download to PC. If the picture is ok, then LCD is bad. You need to replace it.
Jan 17, 2011 | Canon PowerShot A720 IS Digital Camera
How do I set my canon powershot a720 IS to take pictures in black and white?
Press the FUNC/SET button. Use cursor-up/down to select the fourth item along the left edge of the screen. Use cursor-left/right to select "B/W". The instructions are in the "Shooting in a My Colors Mode" section of the manual (page 107 in my copy).
In general, you're better off shooting in color and converting to black&white using a photo editing program on a computer. You get much better control over things like brightness and contrast this way rather than letting the camera do it.
Dec 17, 2010 | Canon PowerShot A720 IS Digital Camera
How do i shoot a video on this camera? I set it on Video and depress button but it only shoots a picture. I have no manual.
You have to push the button with the red dot directly behind the camera and you will see the record selection on the top right hand side of the screen and the time couner will start to progress on the bottom right side of the screen.
If you depress the shutter button you will only take one snapshot of what you are trying to video.
hope this helps
Jul 09, 2009 | Canon PowerShot S51S Digital Camera
How do you use the continuous shoot function on canon ixus 70?
These instructions are for the IXUS 70, even though the category is PowerShot SD500/IXUS 700.
1. Press the down arrow (bottom of main control button)
2. Press the up or down button until you see the icon for continuous shooting, which looks like three squares overlaid on each other.
3. Shoot your pictures. As long as you keep the shutter button depressed, the camera will continue to shoot until the memory card is full.
To return to single frame shooting, follow steps 1. and 2. but select the single square in step 2.
May 08, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Manual for my Powershot A720 IS.
Log onto www.powershot.com and in the canon consumer search bar at top type in a720. On recommended links, click the first one which will be the a720 homepage. Once you see the image of the camera and 7 tabs below, click on drivers and downloads.
Look under Guides and Manuals and you will find what you are looking for.
Hope this helps!
Mar 29, 2008 | Canon PowerShot A720 IS Digital Camera
Canon A720 IS self timer
i have no idea.. but i actually have the same camera and i cant even figure out where the self timer is so PLEASE can you tell me? thanks
Oct 24, 2007 | Cameras
Canon PowerShot A720 IS Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
