Question about Refrigerators
Frigidaire glrt186ta, the freezer is not cold enough, everything melted. The refrigerator seems ti be fine. All the coils were cleaned and I can hear the fan running in the freezer. There appears to be no leaks. What could the problem be ?
    Sniper:
  • 51 Answers
There is another fan under the refrgerator usually near the compressor. if this fan is not running then your freezer will not freeze. If this fan doesnt work your fan or your defrost timer is bad. please rate me
Posted on Jan 09, 2009
Freezer side not cold enough, similar temperature as Refrigerator side
It could be many things. My first guess would be the defrost. The coil that gets cold in your freezer builds ice on it and the only way to get the ice off is to run a heater near the coil long enough for the ice to melt. All freezers have something built in to defrost and domestic are typically just an electric heater on a timer. When your freezer stops working again, you may want to pull open the panel of your freezer and see if your coil (a heat exchanger that probably looks a lot like your car radiator) is covered in ice. If it is, it could be the timer or the actual heater that is bad.
Nov 12, 2013 | Refrigerators
My freezer is not cold enough and ice is melting
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 30, 2011 | Frigidaire Freezers
Freezer warm Everything melting....refrigerator seems fine
heatman101
Mar 17, 2011 | GE Profile PSW26P Stainless Steel Side by...
I came home today to find water on the floor by the the freezer side. Ice was melting. at first I thouht someone didn't close the door all the way. Unfort. that wasn't the problem. that was 9 hrs...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
heatman101
Oct 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
FREEZER AND FRIDGE BLOW COLD AIR BUT FREEZER IS NOT FREEZING EVERYTHING. SOMETIMES IT BLOWS THAT SMOKEY COLD AIR OHE TIMES NOT AND THE ICE CUBES SEEM WET AND AIR INSIDE FRIDGE IS MEDIUM COLD. CLEANED THE...
heatman101
Oct 19, 2010 | Frigidaire FRT15B3A Top Freezer...
Freezer and Fridge are both not cooling
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
hhsg
Jan 30, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Freezer not cooling
there is an external fan near the compressor usually at the bottom of the unit on the back side and if this fan does not run the freezer will not freeze. u can also look for a defrost timer located near the bottom of the refrigerator with the door open or just under the freezer in the refrigerator compartment. It will look like a plastic screw that can be turned only one way with a flathead screwdriver because of its design. Some times these timers just get stuck and will work again if u rotate it with a screwdriver one revolution or two. Allow an hour to see if freezer works after tuning. Please rate me
Jan 09, 2009 | Frigidaire GLRT186TA Top Freezer...
Refrigerator not cooling freezer working fine
Refrigerator suddenly not cold enough . Drip pan clean and dry. No dirt or dust.
Oct 05, 2008 | Randell 20072SC R-134a Refrigerator
Frigidaire frs24zrh refrigerator not cool enough
Check out partselect.com. need to replace defrost timer and defrost thermostat. good luck.
Dec 09, 2007 | Frigidaire Refrigerators
Refrigerators Logo
114 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
