Question about AEG 18 in. Favorit F54850 Slim-Line Free-Standing Dishwasher
Dishwasher runs full cycles but the water is cold each time.
Dishwasher runs full cycles but the water is stone cold
    Director Badge:
    Uploaded 100 video answers.
  • 96 Answers
It's probably the heater element that has gone, but it could be a simpler fault like the pressure switch not activating. See this video it should give you the general idea
Posted on Jun 29, 2016
SOURCE: dishwasher will not run. clean light flashes seven times
I had success with the "Hi-Temp Wash - Normal - Hi-Temp Wash - Normal" sequence of button selections. This must occur within 6 seconds and initiates an internal diagnosis of the machine. The process runs for about 19 min. and shuts off. During the process several LED's light up and several funtions start and stop. If the machine has no broken systems, you should be able to open the door add some soap and the usual dirty dishes and carry on with normal operation. Thats all I have done and the wife is no longer on the war path. Good Luck
Posted on Mar 01, 2007
  • 641 Answers
SOURCE: Water Sitting In Dishwasher after Completion of Cycle
An obstruction in the water-inlet valve may mean that it's no longer able to shut off properly. You can easily open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!! In case cleaning will not help, you should replace the valve. Good luck !
Posted on Sep 10, 2007
Dave Duff
  • 30 Answers
SOURCE: bosch dishwasher shu4302uc
Common problem with these. Control panel (behind all the buttons on the door) has a thyristor in the middle of the PCB for switching the heater element ON/OFF.
After many screws and a bit of fiddling about, get access to back of PCB (print side) to find dry joints. Clean and re-make joints and all should be well.
Caution, this is a high voltage area. Disconnect from mains.
Please see photos.
Cheers…..Dave
Posted on Mar 10, 2008
  • 1462 Answers
SOURCE: Whirlpool Dishwasher ADG7540/1
an ntc is very reliable. have you checked continuity thro the heater? other common fault is a dry joint devoloped on the control card - take it out and check for dry joints
Posted on Oct 03, 2008
lojacksdad
  • 121 Answers
SOURCE: dishwasher running on cold water
that will be the callrod heater at the bottom look at it in the bottom to see if you see any cracks
not an easy job
Posted on Apr 17, 2009
Dishwasher takes a very very long time to wash
It could be that it takes a long time for hot water to reach the dishwasher so it fills with cold water. the control may wait for the water to warm up before advancing. Try running the water at the sink until warm before turning on the dishwasher. This may fix the problem. Some models have a water turbidity sensor and will wash until the water is clear. Excessively dirty dishes will cause extended run cycles.
Oct 07, 2014 | Dishwashers
Bosch dishwasher actual runtime versus indicated runtime.
The usual discrepancies with run times is due to water heating time.
For example, your dishwasher may be estimating run time + time to heat the water from cold.
If your dishwasher is connected to hot water instead of cold, it will skip the majority of the heat cycle and adjust the time accordingly.
On the other hand for other people, their dishwasher brands may say "50 minute wash" but this does not take into account heating time, so wash can be anything up to around 70-80 minutes.
Jun 01, 2013 | Dishwashers
Dishwasher cycle never completes
This is a very common complait about dishwashers taking a very long time to complete cycles. More than not if you start your dishwasher cycle wait untill your washer fills with water. Reach in and feel the temp. of the water. If it is cold the dishwasher try's to heat the water. Most of the dishwashers are not design to heat water. And here is the delay. Try to run the water at your sink first until it is hot, Star your dishwasher and see if the cycle runs correctly.
http://www.on-timeapplianceplano.com
Jul 23, 2012 | Dishwashers
My Bosch Dishwasher is not drying my dishes now. The model number is SHE44C05UC.
Unfortunately, it seems that the heating element has failed. The dishwasher uses steam to heat the tub to dry the dishes. I suspect your dishes are also being washed in cold water.
To check this, please run a regular full wash cycle. Allow the washer to fill with water and run for about 10 minutes, then open the door and feel the water temperature in the bottom of the washer. If the water is cold, it's more than likely the heating element has failed.
There are other possible faults which would cause the element not to heat, but these often prevent the dishwasher from completing the cycle. If the water is cold but the dishwasher still drains the water at the end - and completes the cycle - the heating element has probably failed.
Please try this simple test for water temperature and let me know if you need further assistance.
Regards,
BElectric
Feb 18, 2011 | Bosch 24 in. SHE44C05UC Stainless Steel...
Asko dishwasher d3530. The water in the dishwasher is not hot.
Generally speaking, dishwashers don't heat cold water on their own. Be sure the dishwasher is connected to a hot water supply and that hot water is available to the dishwasher at the START of the cycle.
Often it takes hot water several seconds for house plumbing to deliver hot water to an outlet. If the dishwasher is connected to the kitchen hot water supply, run the water in the sink until the water runs hot before you start the dishwasher.
Dishwashers often have heaters to heat the water even hotter than most home water heaters, but they are not intended to heat cool or cold water. You MUST furnish hot water to the dishwasher from the time the cycle is started.
I've seen houses that take so long for hot water to reach a faucet, the dishwasher is already full (of cold water) before the first drop of hot water reaches it.
Good luck. Hope this helps.
Sep 11, 2009 | Asko 24 in. D3530FI Built-in Dishwasher
Lg dishwasher never heats water
The LG 7811 dishwasher is supposed to even support a cold water (vs. hot water) connection. Then it will heat the water up to 120 degrees upon each fill cycle. This is not optimal and it adds much time to the already long full cycle. When you run the hot water at the kitchen sink until it is hot and then kick off the cycle, is the water hot at the beginning? It should be 120 degrees minimum and well under 140 degrees maximum.
Do you get any error codes on the display? Troubleshooting is possible, but recommend you contact LG service at the number in the user guide asap. Press for fast, free resolution to this problem. Please reply when you have gotten this fixed, explaining what fixed this nice, quiet dishwasher. Good Luck!
PS: When you get it running, do not use ultra-cheap dishwasher soap. Recommend Electrosol powder or cascade. Never use gel or tablets on this water conserving dishwasher.
Feb 02, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Dishwasher
2 things will lead to soap not dissolving, first is cold water, so make sure you have hot enough water. second and more likely is the dispenser is not opening at the proper time , instead fully opens at end of cycle during the dry cycle never even getting wet, and washing dishes with no soap, id replace the dispenser or make sure your not stacking items in front of dispenser hindering the opening. also powder is best, tabs and gelpack put undo stress on the dispenser door not always allowing full operation...
Nov 06, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
LG LDF6810ST Stainless Built In Dishwasher
It is very common that high eficiency, low water using dishwashers take longer to finish all cycles. The best way to "hurry" the washing is to make sure that the water heater is providing hot water of at least 120 degrees. But no hotter then 140 degrees.
If the dishwasher runs even longer, check to see is the dishwasher is actually connected to the cold water line. This dishwasher can be run from cold water but the water heating phase in the cycles will add much time ti the entire cycle.
This unit has a sensor that detects the detects the water clarity towards the end of the wash cycle. Rinsing the dishes may speed the load a little, but encourage not to go crazy on the rinsing because the dishwasher actually counts on the food particles to help clean the dishes.
Also, note that the final (third) blinking light means drying. You can simply open the door anytime after the final draining and power off the dishwasher, allowing the hot dishes to air dry.
Hope this helps. Please resply with your findings. Thanks!
Sep 16, 2008 | LG LDF6810ST Stainless Steel Built-in...
Water won't stop running
It might have a small stone or something similar in the water soleniod valve or it might just be sticking open somewhat. I'd go ahead and change the cold water soleniod valve because it's not closing itself and shutting off the water flow.
Jan 08, 2008 | Maytag Performa PAV2200
Open Questions:
Hi, I have read all posts for fixing AEG Dishwasher not heating water problem. Most answers were about PCB heater relay. I have a Favorit 80860iW sensorlogic turbo, (turbo is car?) [IMG]http://i68.photobucket.com/albums/i29/savvaske35/AEG%20oko-favorit%2080860/JD800026-1.jpg[/IMG] and i treat it as a lady. Always best materials in, and dishes cleaned before input. Now, I removed door panel, also 2 PCBs inside, but couldn't find any relay to re-solder it. I am posting some photos here, if anyone please see any problem in my PCBs, or the famous relay, just send me an answer where to solder. 1. when removed fascia. [IMG]http://i68.photobucket.com/albums/i29/savvaske35/AEG%20oko-favorit%2080860/JD800038.jpg[/IMG] 2. back side of fascia [IMG]http://i68.photobucket.com/albums/i29/savvaske35/AEG%20oko-favorit%2080860/JD800047.jpg[/IMG] 3. PCBs removed [IMG]http://i68.photobucket.com/albums/i29/savvaske35/AEG%20oko-favorit%2080860/JD800039.jpg[/IMG] 4. PCB with red display panel [IMG]http://i68.photobucket.com/albums/i29/savvaske35/AEG%20oko-favorit%2080860/JD800043.jpg[/IMG][IMG]http://i68.photobucket.com/albums/i29/savvaske35/AEG%20oko-favorit%2080860/JD800040.jpg[/IMG] 5. PCB with power button [IMG]http://i68.photobucket.com/albums/i29/savvaske35/AEG%20oko-favorit%2080860/JD800042.jpg[/IMG] [IMG]http://i68.photobucket.com/albums/i29/savvaske35/AEG%20oko-favorit%2080860/JD800041.jpg[/IMG] 6. PCB on the bottom of dishwasher [IMG]http://i68.photobucket.com/albums/i29/savvaske35/AEG%20oko-favorit%2080860/JD800051.jpg[/IMG] [IMG]http://i68.photobucket.com/albums/i29/savvaske35/AEG%20oko-favorit%2080860/JD800055.jpg[/IMG] I am disappointed, its a 2000 expensive buy, told me it would last, and i fixed it 5 times already. The dishwasher program is working normal, it just won't heat no more. I replaced today the bottom sensor, which fixed this problem 2 times in the past, but now, no luck with new part, it don't heat. 7. sensor replaced [IMG]http://i68.photobucket.com/albums/i29/savvaske35/AEG%20oko-favorit%2080860/JD800049.jpg[/IMG] 8. where sensor goes in [IMG]http://i68.photobucket.com/albums/i29/savvaske35/AEG%20oko-favorit%2080860/JD800052.jpg[/IMG] thanks for your time.
Feb 05, 2011 | AEG 18 in. Favorit F54850 Slim-Line...
AEG 18 in. Favorit F54850 Slim-Line Free-Standing Dishwasher Logo
113 people viewed this question
Top AEG Dishwashers Experts
Oloyede Monsuru
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
