Question about Emerson MW8987B/W Microwave Oven
Emerson model MW8997w sparks when turned.
The cardboard looking think has a black spot on it. I moved it around and it now works. Do I just need to replace that piece, or is there something else wron.
I bought a piece of mica from an appliance repair business and cut out a new piece. Microwave is working fine. Apparently food carbonizes on the mica and causes the microwave to spark. If anyone has this problem, call around and find a repair shop that buys mica by the sheet, rather than paying for a piece from the manufacturer.
Posted on Jan 12, 2009
Emerson microwave oven 1100 watts model mwg911s52 this is the second one that I have bought within thelast 18 months, that shoots out sparks and then quits. Now it will hum if I leave the door shut on
The magnetron is on the verge of failure, or if a plate with metal compound or tin foil will cause arcing if food is warmed up. But I think it would be a good idea to have it checked especialy if warranty applies.
Jul 03, 2012 | Emerson Microwave Ovens
My emerson microwave #mw8999rd shoots out fire from a silver piece of cardboard thats on the righthand inside of my microwave oven. whats with that?
There is electrical problem in your microwave heating circuit. This is a fire hazard and you should stop using this microwave and unplug from the outlet. This is not something you can fix and the fuse does not protect your system anymore. The best choice is to purchase a new one and throw this away.
Dec 06, 2011 | Emerson Microwave Ovens
Hi I have an Emerson microwave oven MW8998B. The turn table will not rotate while cooking. The smaller bags of popcorn just burn the bag. Does this need a repairman or can I fix it myself. Also, I am able...
Hi, I had the same problem with my Emerson microwave. As I rent out the house, and the turntable stopped working while I was away, my rental agent bought another Emerson microwave. On my return I tried using the new (brown) plastic turntable on the old microwave, and found it worked perfectly. Maybe it would be possible for you to order a replacement turntable part. Hope this helps. Good luck, Rosalind
May 13, 2009 | Emerson Black Microwave Oven
I need the little cardboard piece that hangs on the top of the microwave for my Emerson. Where can I get this that fits there?
Take a piece of cardboard and cut one out. You probably won't be able to find what you're looking for.
Jan 19, 2009 | Microwave Ovens
Need to find turntable mount for Emerson MW8117W Microwave
Go to repairclinic.com and type in your model number. I suspect you may be talking about item 1063610, Turntable Coupler. You may also try searspartsdirect.com. If this isn't the part you need, please post back and provide more information, so that I may assist you better. I hope this helps.
Jan 04, 2009 | Emerson Black Microwave Oven
I have an Emerson Microwave Oven MW8997W and cannot change the hour (time) on my clock. How do I change the clock? Debbie
If your keys do not work at all, you probably have a bad keypad, in which case I'd ask you to reply back. In the meantime:
SETTING THE CLOCK
When the microwave oven is plugged into an outlet,
the oven will display " 0:00 "
1. Press the CLOCK button; the hour digit will blink
and the clock indicator will light.
2. Press the number keys to set current hour.
3. Press the number keys to set current minute.
4. Press AM/PM to choose AM or PM.
5. Press the CLOCK button again; the display will
show the present time. After the clock has been set,
the time will appear with blinking colon, unless
the oven is cooking or defrosting.
You can actually download your owner's manual here
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 10, 2008 | Microwave Ovens
Need plate inside
try partstore.com
or
microwaveglasstrays.com
Feb 22, 2008 | Emerson Black Microwave Oven
Frame is sparking and smoking
Re-trade or go buy a new one this unit is not worth repairing. Go buy a new one their cheap nowadays.And for God sakes unplug it, keep fire extinguisher handy and tell the kids not to use it. You could have an electrical short in there.
Dec 09, 2007 | Emerson MW8102SS 1100 Watts Microwave Oven
Emerson Model MW8627W does not heat after changing fuse!
check the magnitron and capacitors one of this is bad
Sep 18, 2007 | Emerson MW8627W Microwave Oven
Emerson MW8987B/W Microwave Oven Logo
373 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
