Question about SimpleTech SimpleDrive Portable USB 2.0 60GB 5400rpm 480Mbps USB 2.0 USB 2.0 External (STIUSB2560FT) Hard Drive
I have a 320GB SimpleDrive that I bought so I could save photo and music files on to. I had to do a complete system restore on my pc because of a nasty virus, thus me getting the external drive. It worked to transfer the files onto the SimpleDrive, but now when I plug it into my pc, it beeps several times and does nothing; no icon, F: drive, or anything. I don't know how to make it work again, and I don't want to lose all those files! Please help!
night71
  • 328 Answers
SOURCE: SimpleDrive external USB Disk Drive
You may not see any icon on desktop but should see "found new hardware" at the bottom right by the time. Right click My Computer and click Manage. Under Storage click Disk Management. You should find your drive here. If its a new drive, no letter may be assigned or it may not be partitioned or formatted yet. Right click on the drive to format it and to assign a drive letter. If its already formatted and works on other computers, let me know because it could be a USB error or faulty cable.
Posted on Nov 07, 2007
TomSolomon
  • 50 Answers
SOURCE: SimpleTech SimpleDrive Pininfarina 320GB Power up problem
It could be that it's internal power supply burnt out,
in which case the drive itself could still be fine.
Try opening up the external case, and removing the drive.
Once you do, plug it in to your computer directly using its SATA cables, and see if that works.
Hope I helped,
Tom
Posted on Jun 21, 2009
Duggie647
  • 106 Answers
SOURCE: I AM TRYING TO FIND THE OPERATION MANUAL FOR MY
The operation manual can be found by clicking here
Posted on Jan 23, 2010
  • 8404 Answers
SOURCE: hi where i can get the dirver for simple tech
If your version of windows dosn't have the driver, there is that possibility that your drive is not supported.
Two things I want you to do ... check the Microsoft Hardware compatability list at http://www.microsoft.com/whdc/hcl/default.mspx
Visit the simpletec web site ... http://www.simpletech.com/support/ and see if they offer something.
If your device is not on the windows compatability list you are probably out of luck unless the manufacturer offers something for it.
I have presumed you are running windows ... since you dont say otherwise.
Posted on May 30, 2010
lock123
  • 6831 Answers
SOURCE: Toshiba 320gb external drive is not detected by any laptop...
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
"How do I transfer individual files archived on my SimpleDrive from old PC to newer HP Windows 7 laptop?"
Connect your simple drive to the computer with the usb and power lead if applicable.
Click start all programs accessories open windows explorer my computer you should see your drives C: usually your hard drive D: your cd dvd drive and your usb drive E: or F: click to open it from there you select the files right click on the file/s right click copy navigate back to the drive right click select paste or hold the mouse cursor the file/s drag them to your usb drive disc then drop them Hope this helps.
Jan 10, 2013 | SimpleTech SimpleDrive Pininfarina 320GB...
Changed hard drive (Mac) How to restore data from SimpleTech
If you are asking how to restore a Time Machine backup, you will need to connect and turn on your drive, then open Time Machine, navigate to the drive, highlite the backup and click on the restore button. It should then restore the files from your backup.
Feb 24, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
Some of the pictures was lost. How to recover it?
You can often successfully recover deleted files from a PC, phone or camera memory card or USB Memory stick, it just depends on what's happened since the files were deleted.
When you delete files the data itself isn't deleted, just the index entry that says where the data for those files is located. The space containing the deleted files is also now marked as free space so it is available to the system for any new files to be written there instead.
If and when that happens, then it becomes too late to recover your deleted files so it is very, very important to not save any new files or data to the device concerned.
If the deleted files are on a memory card or USB memory stick, just don't save any new files to it.
One of the easiest ways to see if you can recover deleted pictures is to try some photo recovery software. Recommended asoftech photo recovery as it saved my life many times.
http://www.asoftech.com/apr/
Jun 13, 2010 | Samsung L100 Digital Camera
SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue: HELP. I have simlple tech 320 external hardirve. M...
Were you using this on a PC? it may be using Fat or NTFS. If it's seeing the drive and you can't use it, it may be the filing system, I believe macs use a different one than PC's. I would copy the files "if possible" to another flash drive or computer and just re format the 320 gig drive, the mac will install the right filing system for the drive and it should be good to go.
May 16, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
I have a 500g external simple drive. i am getting a message that i can only read on my mac.
Copy all the data onto your Mac computer.
Take the external drive to a PC computer, and "reformat" it, using "quick format".
Take the external drive back your Mac computer,
and write all the "saved" files onto the drive.
Nov 16, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Hi. When I try to restore data, ALL the files I
Here are some recovery programs you may rely on. Both programs can recover photos, videos and music.
Photo Music Recovery Software (for Windows)
Mac Photo Music Recovery Software (for Mac OS X)
A Tip: Before your items are recovered, do not attempt to save more files the original files(your photos, music) are overwritten.
Nov 01, 2009 | SimpleTech SimpleDrive Pininfarina 500GB...
For a mistake I deleted some files from my camera Sony Model DCR-SX50E. Can I recover them ?
You may try some recovery software to rescue the files on your recorder, here are some for your option.
Photo Video Music Recovery (for Windows)
Photo Video Music Recovery for Mac
Both programs can also recover video and music files.
Note: Before your files are recovered, do not attempt to save more files to the handy cam in case the original files(your recordings) are overwritten.
Oct 15, 2009 | Sony Handycam DCR-DVD205 DVD Camcorder
Retrieving deleted history from windows Vista?
System Restore can make changes to Windows system files, registry settings, and programs installed on your computer. It also can make changes to scripts, batch files, and other types of executable files on your computer. Personal files, such as documents, e‑mail, photos, and music files, are not changed.
That is from Microsoft. I think History or Passwords and Form Filled items are stored in the registry, but visited sites are not. So a system restore may give you your saved passwords for sites but not the bookmarks to those sites
Apr 03, 2009 | Microsoft Windows? Vista Home Premium...
I lost my simpledrive software
Try restoring you computer to a time when the device was working
Start>All programs>Accessories>System Tools> System Restore
Choose a date when you devices was working and you should be good
Feb 10, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Computers & Internet Logo
51 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
