Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
Yth2448 t replacing drive belt
Mower runs but will not move
  • JERRY ABELL
    JERRY ABELL May 11, 2010
    hello! you took the time to ask question. i took the time to answer your question. could you take the time to rate the answer. thank you.
  • JERRY ABELL
    hello! what kind of tractor do you have,and transmisson.
SOURCE: drive belt
You may find that you have the wrong belt - I bought a belt for the correct model and then found that there are two different sizes depending on the exact model - they are 3 inches different in length for my model CTH160 113" and 110". Got correct belt and fits properly now.
Posted on May 16, 2009
  • 32 Answers
SOURCE: husqvarna yth2448 riding mower
you probably need to adjust the tension. if you look somwhere near the drive belt then you see a spring. tighten the spring to tighten the belt.
Posted on Jun 21, 2009
  • 95 Answers
SOURCE: Husqvarna Mdl YTH2448 Riding Mower - Electric PTO Not Working
It sounds like your charge system is not working. If you jump the battery the engine will run with a weak battery but the pto clutch needs a strong battery to stay engaged.Try this to test it,after you jump it leav the jumper cables hooked up and try to engage the blade clutch,if it runs it is either a battery that wont take a charge or a charge system not working. If you put a volt meter on the battery while the engine is running and the voltage is 13 volts the charge system is working and the battery is bad.
Posted on Jul 31, 2009
SOURCE: Sears ZT 7000 mower, engine runs, mower will not move
Same problem. The drive belt pulley tensioner spring broke. Replaced and everything worked great.
Posted on Apr 05, 2010
  • 252 Answers
SOURCE: Belt that operates my mower
hi there djwolf25
here is web site with deck belt routing diagram to help
http://www.partstree.com/parts/?lc=husqvarna&mn=YTH+2448+(96015000103)+(2005-03)&dn=28_05_0023
here is web site for a copy download of owners manual
http://www.landscapepower.com/pdf/ayp/96015000103-yth2448_e.pdf
it has both deck and pto to deck belt roueting in it
cheers pauly46
hope it helps
Posted on Jul 22, 2011
Replaced drivebelt on troybilt riding mower now the forward pedal moves mower in reverse?
Sounds like you have the belt running in the opposite direction. You need to Change the way the belt is routed around the pulleys
Jun 18, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
Husqvarna riding mower, (Model: YTH2448) won't turn over
turn on device and wait for response inspect every component for malfunction
May 13, 2013 | Husqvarna Garden
Ignore previous message - Belt that operates my mower blades popped off. Looking in my manual it appears diagrams for the belt is missing. Anyone have something to help me get this thing back...
I had one, the deck belt routing diagram was not only in the manual, it was also on a little decal attached to the top of the deck. A google search goes a long way, check for AYP and MTD websites as they make about all the mowers, regardless of the label on them.
Jul 22, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Ihave a yth2448 husqvarna lawn motor. mower stall out as soon as i engage it. i have noticethe battery is discharging even when mower is not engage. any suggestion. i justv replaced the starter and...
check the belt as it bound, if you do not think so then take it off(the belt) and engage the PTO if it does not die then it is: the belt, pulley, or blades are/is the reason why it is stalling Tim
May 29, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I have a cub cadet mower and it has the hydrostat trans drive and I hit a tree root in the yard and the tractor quit moving. The mower deck still runs so is there a belt broken or what could be wrong?
There are two belts - the main drive belt from the engine to the hydrostatic transmission, and the mower belt that runs from the engine to the mower deck. Sounds like the main drive belt broke or came off. It's not an easy job to replace because it's up against the chassis underneath, and you usually have to remove and replace some parts to get at it. Take a look under there, see if the belt's gone, and decide if you want to tackle it or have a shop do it.
Jun 12, 2010 | Cub Cadet Garden
Need manual for 48'' hausqvarna riding mower yth2448, 24 hp ELS for mower deck belt installation.
Hi..my name is Keith...and you can go to an online lawn mower parts site and they will have a parts diagram of the deck and it will show how the belt is installed....one of the sites is.. www.outdoordistributors.com ..i hope this helps
Jul 07, 2009 | Garden
Husqvarna yth2448 riding mower
Jun 20, 2009 | Husqvarna Zero Turn Mower Z5426
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
262 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
