Question about Engel Freezer 22 Qt. Fridge/Freezer
Constant and fairly loud noise
Constant loud noise is coming from the fridge section of our samsung american fridge. the noise is there only when the door is closed. it stops no sooner the fridge door is opened.
  • 909 Answers
Thats typically an air circulating fan thats either faulty or something is touthing the blade. open up and see.
Posted on Feb 01, 2009
Samsung wheezing/ Gasping sound.
It is likely just refrigerant coursing through the coils, or maybe the water valve when it opens to fill the ice maker... Is it constant, or does it come and go at intervals?
May 27, 2016 | Samsung RF4287HABP 28 cu. ft. 4-door...
Samsung refrigerator loud noise
if the fan is still running when you open the door , the I would be leaving that idea as a last resort
try this
get 2 taper door chocks and put one either side at the back of the fridge
push the cabinet sideways and slip one chock in a bit then do the other side
many noises are from the bottom plate that the compressor is mounted on from tapping on the floor and lifting it a bit stops the noise
the same as when you open the door the pressure on that plate is removed and so it stops hitting the floor
Nov 04, 2015 | Samsung RS261MDWP - 26 cu. ft. Side by...
Samsung Refrigerator with bottom freezer model # RB195BSBB freezer will not hold temperature. There is a fan running a loud and constantly, and freezer will work it's way down to 8 degrees but will not get...
Check for ice build-up in and around the freezer fan where the blades are, if you can see ice in there (some times it may look like white foam but dont be fooled, it will be ice), the fan will be hitting it, defrost the freezer and check defrost element, (you will have to dismantle freezer section to get to it but reletively simple job) disconect from mains first. Good luck
Dec 18, 2010 | Samsung Freezers
Hi, i have a whirlpool american style fridge that beeps etc.
its the compresor packed up,,,if this compresor is not pumping freezer gas around the pipe work the freezer wont work sorry but a new compresor is not a cheep thing to have fitted as it will need a re-gas as well
Jun 29, 2010 | Freezers
Whirlpool 20RB D4 Fridge Freezer clicking
Hi the reason for your noise coming from the fridge freezer is the plastic that is used in the design of your product is of a low quailty which reacts to the temp change and then as they get cold again they start to crack inside the frigde! Nothing to worrry about........
Hope this helps.....
Dec 23, 2008 | Freezers
Samsung fridge freezer no power 2 unit
Most of the time when not even the light comes on and there is power to the outlet it's just a simple matter of replacing the cord. good luck
Dec 16, 2008 | Freezers
Malfunctioning American Fridge Freezer
Is it freezing. Sometimes those led's go out.
Dec 21, 2007 | Freezers
Samsung side by side American style fridge/freezer
make sure your fan is running in freezer section. you should hear it
Dec 02, 2007 | Freezers
Engel Freezer 22 Qt. Fridge/Freezer Logo
468 people viewed this question
Top Engel Freezers Experts
John Tripp
John Tripp
Starnley Johnwells
Starnley Johnwells
Victor Nwachukwu
Victor Nwachukwu
Are you an Engel Freezer Expert? Answer questions, earn points and help others
