Question about Sony Ericsson T610
My phone is not working
I have tried several times but i can't switch on my phone although battery of the set is good and it is being charged properly by this phone in switch off condition. only problem is i can't switch on the phone. Every night i switched off the phone.
  • Ujjal Dutta Jun 11, 2007
    My SIM Card is OK. Please tell me other solution.
Is your SIM card all white? If it is, this could be the problem. Some issue with certain SIM cards and this phone. If your SIM card is all white, take the SIM card back to the store.
Posted on Jun 05, 2007
Reset my kindle,
Dead battery. If you haven't charged it for several years it dies.
Unreparable although if you call kindle customer support they may give you a discounted price on a new or refurbished current model Kindle. They'll want your old one for parts.
Jul 02, 2015 | Tablets & eReaders
Phone won't switch on
still can fix it not by you,, in the service center they're going to put cable in your fone, and check your phone if there's no hardware to repair. and if it's all ok and did boot.. the're just going to reflash your fone ... with firmware.. and everything will back to normal... did your power switch bounce? if not that will the problem and they can fix that and less charge...
Apr 20, 2008 | Nokia N70 Cellular Phone
Battery doesn't appear to be charging.
There may be several physical problems. You should make sure that the battery is properly plugged in and no switches that allow it to be removed are in the open position. Checking that the power cord if plugged in proper at the laptop, the power brick, and the power outlet may also solve the problem. If none of these work, try using a different power cord that fits your laptop if you can get your hands on one. You may also want to try a different power outlet, or make sure that power outlet can power another device (eg vacuum, phone) so you know if it's actually a problem with that power outlet and not your computer.
If you battery doesn't charge even with a cable that you know works for another computer, and the outlet is working properly, your battery may be corroded or suffering from over-use over a long period of time. In this case it would be best to buy a replacement battery directly from Dell which you can do here:
http://www.amazon.com/Replacement-Laptop-Battery-Studio-7200mAh/sim/B003FZ33SS/2
Mar 19, 2011 | Dell Studio 17 Laptop
My battery is not charging although the charger works fine
There's a possibility that the battery is bad and it won't hold a charge. Send the phone to the authorized repair center and see if they have a spare battery that you could borrow to test the phone.
Use different battery then try to charge the phone. It the battery hold a charge, then it's the old battery that has the problem.
Thank you and good luck!
Sep 21, 2010 | Sony Ericsson XPERIA X10 Cell Phone
Have a problem with start button
Im telling the solution step by step.It ll work . you dont need to go 4 the firmware v5.05 If ur phone restarted 3 or 4 times and switched off automatically.
Try this Remove the battery and Micro SD card
2] wait about 5 minutes
3] Then switch On the phone WITHOUT the memory card Now ur phone working well without restarting
4] Then you must restore Factory settings frm the Settings Menu [default security code:12345] {i know most of people have done this thing,but remember u have 2 go with the correct order.Unless it will not work.OK}
5] Now apply a theme. The theme's size should be below 100kb
6] Now ur phone working fine without the Micro SD
7] Then wait about 5 minutes and Switch off ur phone
8] Remove the battery and insert the Micro SD
{Don t Format the memory card}
9] Switch On ur Nokia 3110c phone.
10] Now Keep ur free Phone memory space [Not the memory card's free space]between 470kb - 499kb.
Now surely ur 3110c working fine about 5 months. During these time u can1
1] Send/receive any file via bluetooth.
2] Enjoy Music,video, GPRS,Yahoo Go .....etc
3] Also u can Update music library anytime. but remember below
DONTs
1] Don t try to change themes.{u have to stick with a theme}
2] Charge ur phone in ON mode
3] Dont fully discharge the battery
4] Start charging ur phone when there is only a bar on Battery indicator
5] Dont erase calender notes
Make sure about above 5 Donts
Dont worry if ur phone restarted once.{U know the problem is restarting several times and automatically swiched off.}
Jan 14, 2010 | Nokia 3110 Cellular Phone
My phone won't start on!
Nokia sometimes has a glitch where if the battery is too low it will not start properly again. Let it charge for some time when turned off - a couple hours, so it has enough battery power then remove the battery for 5-10 minutes, put the battery back in and try start it. What this does is re-sets the phone so it can start again. Also if there are problems during use that solution usually fixes it as well. What is happening is due to a low battery it tries to resume where it left off and cannot load itself properly to do so. Letting it go completely dead with no battery for a few minutes lets it drop it's old info and reload it's info to work again.
Oct 19, 2009 | Nokia N75
Phone Won't Restart After Charging
This seems that you battery is faulty. just get a new battery and your problem will be solve.
Jan 03, 2009 | LG KU990 Viewty
My battery went dead this morning i charged it this evening and it is just showing a battery and timer wont switch on or charge??
from what I hear, you have either fully charged your battery or your battery is pretty much completely dead.
your options:
1. If it's completely dead and won't hold a charge it's time to purchase another battery, this happens from time to time so don't freak out about it.
2. If it's fully charged, try taking the battery completely out of the phone, and re-inserting it after a few minutes, sometimes cell phones need to be reset.
3. ensure that your charger is working properly, if its not getting juice to it neither is your phone.
4. try to dial your number just to see what happens to the phone.
5. if someone else u know has a charger like yours try to borrow theirs to charge your phone possibly ruling out a bad charger
Nov 13, 2008 | Samsung Cell Phones
NOKIA N73 PROBLEMS
my n73 hand set problem is if i connect the charger on the screen displayed not charging, and i use to charge the battery charger to store power in battery. charger is working fine but hand set troubled me and the other problem is if i listen the music files after 2 minutes phone is off, in a day its happening lot of times give a complete repairing solutions.
Jul 16, 2008 | Nokia N73 Cellular Phone
K800i PHONE DEAD
Try this, for I had the same several times.step 1) Take out the battery completely and bring it back in again. Turn the phone on and if it still doesn't work it might be the case that the phone needs to be charged first. do step 1 again but don't turn the phone on but charge it for about 1 hour and check it again.Good luck, Rebecca
Feb 29, 2008 | Sony Ericsson K800i Cellular Phone
Sony Ericsson T610 Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
