Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Composite and s-video inputs stopped working
First, let me say thank you to everyone who's posted on the convergence issues-- I've replaced the convergence ICs and my TV is working great again, mostly. After putting everything back together (with pictures, all cables and connections labeled, etc.), I cannot get any video to work on the composite or s-video inputs. The AV4 HD input works fine, and all of the audio inputs work fine. But nothing works on AV1, AV2 or AV3 composite or s-video inputs. I've looked around to see if I missed a connection and I don't see any. Does anybody have any ideas? Does anybody know which part of the electronics boards handles the composite and s-video inputs? Thanks!
  • Tony S-one Jun 04, 2007
    techman, that was it! I hate to admit it, but I just needed a kick in the backside to open the TV back up and check everything one more time. I start moving cables around to get a *good* look at everything, and there it was-- a small ribbon cable had pulled sideways halfway out of its connector. Reconnect, everything is good! Thanks!
    President:
  • 3,130 Answers
You may have shifted the input board a little while replaceing the IC's. Double check every plug and connector, not just by visuale inspection, but by going and removing and replacing every connector. I have had problems like this in the pasy and have learned the hard way, everything is not as it looks. Good Luck
Posted on Jun 04, 2007
  • Larry  Dillon
    Larry Dillon Jun 04, 2007
    You did not rate this thread my friend
  • Larry  Dillon
    Oh by the way great job!
SOURCE:
Convergence Issue
If you wish to get some details; visit the site linked here. Pull up older posts.
Aug 14, 2017 | RCA D52W23 52" HDTV CRT TV
Denon 1312 receiver composite video inputs do not work.
I'm having the same problem with my Wii output. The manual for the Denon AVR-1312 says that analog video signals (i.e. component/composite outputs from the Wii) are not converted to digital video signals (i.e. HDMI output from the rcvr). I'm running only HDMI to a projector, so the video signal is essentially lost. The fix appears to be to run an additional composite cable all the way to the projector. Sounds like your fix is the same. No Wii tonight! :(
Jul 07, 2012 | Denon AVR-1312 5.1-Ch A/V Home Theater w/...
HCP4363W - No color from AV1, AV2 or ANT inputs
You might have a problem with the intenal board or the AV connection onto the board. Have a TV repair center check the board and the connection.
Apr 27, 2012 | Samsung HC-P4363W 43 in. TV/DVD Combo
I have a Sharp LC-32D40U LCD TV. All the inputs for Composite (Y,R,W) are bad and only the S-video input on Input 2 functions. ( I have not tested the HDMI inputs as I ahve not HDMI source). I was told...
Unplug S-Video cable from tv then tyr Composite video input as if S-Video jack is hooked, related composite video input will not work.
Let me know if you need further help.
Aug 17, 2010 | Sharp Televison & Video
Sony KP46WT510 picture goes back and fortto horizontal color bars
The pictures show the result of a bad terminal input board. You can verify this by checking the inputs. Connect devices to the board and try different inputs. You will most likely find this problem on the tuner and component input were your DVI and composite video will be ok. If it is the same on all inputs replace the A board
Jun 24, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Toshiba TN55X Convergence problem.
You brought up an issue that we hadn't considered. Shortly after hooking up our TV to the receiver with a composite video, our convergence which wacko. My hubby replaced the 2 ICs, but now our power button just flashes red, with no picture. Not sure if new ICs are faulty or if it's another issue. He will replace old ICs to see if problem still exists with turning on the tube. And he'll try disconnecting the video signal to see if problem exists.
Ouch.. may have to consider another tv thanks to new technology ??????
Good luck solving your problem.
Jul 06, 2008 | Toshiba TN55X81 55" Rear Projection...
Convergence problem - NOT STK ICs / resistors
have you check the electrolytic filters. check the video IC. also check the polyster or disk type capacitor, because they hold the frequency. in on screen mode the half of section is dead, but when you applied a signal it start converting it display mode. every signal is extracted from video signal in TV mode. the best way to check all this properly you need a colour pateran generator. when you used it you will find a fault and the area.
best of luck...
Feb 12, 2008 | Zenith R56W36 56" Rear Projection...
Composite video inputs roll vertically
Sync seperator problem, sounds like. Could be bad cable, but I rather doubt it....accordianman
Jan 31, 2008 | Samsung PCK5315RX TV
RCA F32650 TV-Input 2 -Can I connect both Composite and Component video at same time?
I think you are right about VHS up front.......One more option =
buy a seperate video input switch box..then you wouldn't need
to use front input ........T.
Dec 17, 2007 | RCA F32650 32" TV
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
122 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
