DATA ERROR LEXMARK 3500-4500 ( CYCLIC REDUNDANCY CHECK )
I AM TRYING TO USB PORT MY PRINTER TO MY LAPTOP IT WORKS FINE ON MY DESKTOP. I LOADED UP TO MY CD ENTRY THEM MY COMPUTER COMES UP WITH VISIT WEBSIT OF MANUFACTURER CHECK SUPPORT SECTION FOR DRIVER SOFTWARE. THE ERROR ( CYCLIC REDUNDANCY CHECK ) I HAVE NO IDEA I AM VERY DISAPPOINTED IN THIS. I HAVE HAD MY DESKTOP AND PRINTER FOR OVER A YEAR AND MY LAPTOP THIS IS MY FIRST DAY TO TRY TO MAKE THIS WORK I HAVE THINGS I NEED TO PRINT AND PHOTOS TO SCAN. AND AM GETTING NO WHERE.
    President:
  • 8,637 Answers
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
How do i change the language bak to English? And how do i print from my macbook laptop onto the printer
TO CHANGE THE LANGUAGE:
From the printer control panel, press the 'Spanner' icon.
Press the right arrow button, and then press OK
Press OK again.
Press the arrow buttons until the language that you want appears on the display, and then press OK.
If you are sure, press the right arrow button, and then press OK to change the language.
To print from your macbook laptop you may have to install additional software onto your laptop from the installation CD. Insert the CD and wait for the 'Welcome' screen to appear. (Note if the 'Welcome' screen does not appear after a minute, then click the CD icon on the desktop). Double click 'Install' and follow the screen instructions.
Some additional notes that may apply to your machine(s):
If the printer is connected to a desktop computer through the rear USB port and you decide to connect a laptop computer to the printer through the Quick Connect laptop port, then the Quick Connect laptop port connection overrides the rear USB port connection. The active print jobs on the desktop computer may be cancelled. Pause or cancel active jobs on the desktop computer before switching between ports.
To summerise:
Pause or cancel active jobs on the desktop computer.
Connect a USB cable to the laptop computer and then to the Quick Connect laptop port on the front of the printer.
Warning-Potential Damage: Do not plug in or remove the USB cable from the Quick Connect laptop port while a memory device is being accessed by the printer.
If you have not yet installed the printer software on your laptop then install it now.
Hope this helps
Jul 14, 2011 | Lexmark X6675 All-In-One InkJet Printer
Software Loading / Scanner Recogniton
Several times, I've had issues installing USB devices on Dells.  The problem seems to involve the fact that Dell has trouble recognizing the ports as USB2.  It'll recognize devices, but not all devices, and not all devices will work properly.
I know this doesn't exactly solve your problem, but I thought this tid-bit might bring you a little closer to a solution.
Oct 30, 2007 | HP Officejet Pro L7680 All-In-One Printer
Printer comes up as category: unknown
Disconnect the USB cable..
Open the device manager...
Plug in the USB cable
see if you get the entry USB Printing Support under the menu
Universal serial Bus
if you don't see it replace the USb cable and try
On the Menu click on VIEW >>> Show hidden devices >>> try to find the USB print support
or the printers entry...
if you see it in some other category install the softwares
through the CD or get the drivers online through HP.com/support
it will work
if that does not work install the generic drivers
I.e open Printers&Faxes(XP), Devices&Printers(7)
click on add a printer
install a local printer
select the port as USB port
and follow the instructions
it will definetley recognize your printer
Happy Printing.....
Mar 04, 2011 | HP Officejet 6300
HP3600 USB printer works but won't print on my HP7058 Laptop
Try removing all ports from your laptop, then reboot, and then create just one USB port. Also, go to your hardware devices and make sure your usb ports don't have any question marks or yellow warning symbols. Be sure first that the drivers for your USB ports are installed and working first. This sounds either a faulty USB cord, which does happen, or USB drivers issues in your laptop. The printer is probably not the problem here.
Feb 17, 2010 | HP LaserJet 3600n Printer
The USB ports on my Toshiba A135 S2356 laptop are not working. I tried to use my printer and it says not connected. I bought a new cord but it still doesn't work. What should I do?
1. first check ur USB port using any other USB device, like pen drive, mouse, keyboard,etc.
if system detects that device, then ur USB port is OK!
2. if USB is OK, then the problem is with the 'Printer Driver' not the cord!
3. reinstall the printer driver!
4. update the driver!
5. if USB port is not working, then replace it!
if this helps, tell me.......
Dec 30, 2009 | Computers & Internet
Lost cd for laserjet 1320 cl6 printer. installed
either the usb wire is getting loose in the new laptop port.or the port is faulty.press the usb wire tightly and then try printing keeping it pressed at the laptop side and printer side too.with some bodies help. check out.
Jul 12, 2009 | HP LaserJet 1320 Printer
Have to keep setting up HPLJ 5P on a USB port everytime I print!
1)right click the my computer icon
2)click properties and then click hardware n go to device manager.
3)uninstall all usb ports and then scan for hardware changes
4)ur pc will detect your printer and ask for printer drivers
5)re load drivers and your pc will communicate with your printer
6)for reloding install the cd follow the instructions on the screen and click next
7)restart when the printer is loded.connect the wires and cords properly.
Nov 29, 2008 | HP LaserJet 5p Printer
Printer not recongnized via USB port
Drivers, Software, lost C.D....come this way!
If you have lost you cd or don't know how to install your printer then all you need to do is download the drivers and software from the manufactures website that suits your operating system and printer.
Drivers and software download areas for brands listed below, just click to gain access and then locate driver for your needs.
Nov 19, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Scanner & Software function - cD does not load fully
When trying to reconnect the device, don't expect Windows' plug and play to help you.
To uninstall the hardware itself, locate on your CD "x:\util\ccc\uninstall_l1.bat". Disconnect USB cable as it says before continuing. When finished, restart your computer.
REinsert the CD, and choose "Add a device"... that'll ask you to connect the USB cable so it can configure the scanner portion and not only the printer portion.
Computer won't recognize printer
We know it isn't the printer or the USB cable. We know it isn't the software. You are running Windows XP on both the desktop and laptop, correct? On your desktop, you go to 'Start''Settings''Printers' and is the printer there ?? Try this; go to 'Start' 'Settings''Control Panel'. Double click the 'System' icon. Click on tab 'Hardware', click on 'Device Manager'. Do you see a yellow (!) on any Universal Serial Bus Controller. If not, were good. Check all USB ports with a USB mouse or device to make sure they're active.
Jul 03, 2007 | Lexmark X4270 All-In-One InkJet Printer
120 people viewed this question
k24674
jasbo
jasbo
