Question about Kodak EasyShare C875 Digital Camera
I have a kodak m1033, no matter what memory stick it says "card i
No matter what we do, it tells us the memorycard is locked, both if then. Wtried the card in our son's camera and they work fine. It just keeo saying the card is kicjed.
Please help, had the phone since August.
  • 6,831 Answers
Hello
If the card works in another camera or another card doesn't work in your camera , the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Sep 27, 2010
Can i change my memory card from 2GB to 4GB or 8GB
Yes, the Kodak Easyshare M1033 has a SD/SDHC compatible expansion slot so you can purchase and insert memory cards up to 32GB. You can purchase them almost anywhere like Best Buy, Target, etc.
Mar 31, 2011 | Kodak EasyShare M1033 Digital Camera
Bought this camera from ebay and it came with no manual. it saids memory card is protected reset switch on memory card, how do i do that
Look at the memory card and there should be a little piece of plastic that slides. That switch will lock or unlock the card.
Happy Shooting! Please rate this solution if it has been helpful to you!
Mar 06, 2011 | Kodak EasyShare M1033 Digital Camera
Memory card is protected reset switch on memory card
Take the memory card out of the camera and look at it. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Oct 31, 2010 | Kodak EasyShare M1033 Digital Camera
Memory card is protected Reset switch on memory card
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Oct 09, 2010 | Kodak EasyShare M1033 Digital Camera
How to remove microsd memorycard password
The way is open your memory card from your phone and insert another phone which also support micro sd memory card. when you insert that then you will see memory card lock unlock memory card. first cancel that and Enter the tools option and go to memory card option. try to format memory card. if format memory card then from your memory remove password. thanks
Feb 25, 2010 | Nokia 3230 Cellular Phone
I have a kodak M1033 camara with a SD HC PNY optima 240 HD 16 GB and the camara says internal memory is full and is only 1/2 minute video in the camara please help
Hi!
Sonds like the camera hasn't switched to the memory card. Go to setup and set memory to Auto not Internal. If that doesn't help, it's possible that the camera doesn't support 16GB card, but it should give you a card error then, so check the memory settings first.
Tom
Oct 06, 2009 | Kodak EasyShare M1033 Digital Camera
Memory card not working
If it,s an SD Type memory card. Try formatting it in a Card-reader Connected to a PC. Format it In FAT Or In FAT32. If the card is not formatted. The camera won,t understand what it is.
Thankyou for using Fixya.
Mike @ Compurepair.
Mar 26, 2009 | Kodak EasyShare M1033 Digital Camera
Kodak EasyShare C875 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
