Question about Toshiba Satellite M40-S417TD Notebook
Display has lines on it
I can still see the background and the laptop works, but the screen has several lines on it like bar codes.
  • kkazem Jan 09, 2009
    Thanks for your reply. The lines are all across the screen. Horizontal, with fixed interruptions, and like red colored small bar-codes.
  • Quickfx PC Repair May 11, 2010
    Are the lines all the way across the screen ?
    Are they vertical or horizontal ?
    President:
  • 846 Answers
Well I hate to say it but there is a problem with either the motherboard/video card or the screen itself. Neither of which you can repair yourself.
If it's still under warranty id contact Toshiba (Google there website)
and find out how to send it to them and ask anything else you wanna know and let them repair.
If its not under warranty you can either buy a new laptop, or find the parts if your lucky on Ebay, and repair it yourself but you don't know if its the motherboard/video card or Screen (Hard to find out which without a service tech looking at it). Plus Laptops aren't as easy to work on even with instructions.
Posted on Jan 09, 2009
  • Quickfx PC Repair Jan 09, 2009
    I hope this helps, post back if you have additional information or comments about my post. Feel free to leave positive feedback if this helped out. Thank you for stopping by Fixya!
Sony vaio laptop screen shows vertical lines upon booting then proceeds to windows loading with semi transparent vertical bars on background. Upon logging in, screen displays everything in a large scale...
the screen inverter is on its way out simple to replace unscrew the rim on the outside of the screen pull it off gently at the bottom there is a stip with wire going into it at each end disconnect it remove it do the reverse to put it in i suggest ebay for spares
Feb 11, 2012 | Sony Computers & Internet
The machine is a Gateway NV53 laptop. The display is showing a reddish background with grey to black horizontal bars. Is it the inverter?
No that will be the screen itself. If the inverter is bad you will see a very faint picture.
Hook the laptop to an external monitor, if the picture is fine it is definitely the screen itself. If it still experiencing display problems then it will be the motherboard.
Comment back if you need more help.
Sep 13, 2011 | Computers & Internet
Asus x83v monitor has a red flickering bar across the lower part of the lcd it is as thick as the task bar thats why i have to place the task bar on the top, its like a static flickering red to pink and...
The display hardware is damaged. Most likely you will need to replace your screen. In rare instances, this can be caused by a loose ribbon connector from the display to the display adapter board.
Mar 29, 2010 | ASUS X83Vm-X1 Notebook
Laptop screen purple psychedelic visual and then screen blank
Sorry to hear that you are having problems with the computer display.
Per your description, I believe the display controller was damaged by the power surge. The laptop may need replacement of the display OR use it with an external display.
Nov 06, 2009 | Computers & Internet
White lines and fade desktop icons on screen
The LCD screen is at fault. If your lappy is in warranty try replacing it. It would cost araound $50-$80
Thank you!
Sabharish
Jun 01, 2009 | Toshiba Satellite M30X-S181ST Laptop
How can i watch a dvd from my mac book pro through an hd tv ,
Open up System Preferences in the Apple menu, then go to "Display".
Make sure the monitor is connected, and click the "arrangement" tab. Check "mirror displays" OR drag the menu bar (white bar at the top of one of the monitor representations) from your laptop screen image to the desktop screen image.
Nov 22, 2008 | Apple MacBook Pro Laptop Computer with...
ACER X193 MONITOR DISPLAY ISSUE
Windows doesn't know your display is broken as it see's your display adapter for the laptop. By adding the monitor windows is adding a second display to the one you don't actually have, your icons and start bar are still on display 1
sorry
Sep 28, 2008 | Computers & Internet
IBM Flat Panel Monitor problem - light colored shifting lines (like Bar Codes)
It sounds like it's a problem with the video card, as opposed to a problem with the monitor. If you have another machine, or a laptop, or a friend with a laptop you can find out - just plug it into the other machine, and if the problem goes away, it's the video card. If not, it's the monitor.
While the card may be bad (if it has a dead fan, and has overheated) you will probably need to replace it. But if may just be loose, assuming it is a and on video card and not an onboard one. If it is an onboard video, you can usually disable it and put in an add on video card, which would resolve the issue as well.
Feb 16, 2008 | Computers & Internet
Blue Vertical Line
It is sounding like when the laptop is turned on and heats up a bit, the line appears? Sounds like one of the panels is going bad or atleast has developed a problem. below are some tricks you can try to lessen the annoyance of the line. Dual-Scan STN displays are composed of 2 panels behind a single protective panel or screen. Because you are looking through the protective screen the display appears to be one large panel even though it is not. There is a physical separation line (gap) at the point where the two panels meet. When the computer is on and being viewed it is not unusual to see the visible separation line with the Dual-Scan STN displays. The line, actually the fine gap between the display panels, appears because the color and light pixels cannot run along the very outside edges of the panels. This line (gap) between the panels can be seen as a fine gray line and is most noticeable when viewing on a screen with a white or light background. Note the line may not be as noticeable when the screen is displaying certain colors or darker backgrounds. SUGGESTIONS: It is not possible to completely eliminate the line but there are some things you can try to reduce it's visibility. 1) Lower the display brightness/contrast. The brighter the backlight the more noticeable the line. 2) Use Wallpapers and Screen savers that use darker colors. 3) In the Control Panel/Display applet under appearance try different combinations of color schemes for your Window and Background choice Let me know what happens. Good Luck, Tim
Mar 16, 2007 | Toshiba Satellite P35-S609: Pentium 4-3.2...
I can't get my iLO-2600 to completely work as a monitor.
The TV will always show as screen number 2 because the laptop screen will be found first. I use mine as a monitor for my Desktop.. However, for the picture to show what your laptop does you have to clone your desktop. The button should be where your screen properties are located.
Mar 03, 2007 | iLO 2600 Television
Toshiba Satellite M40-S417TD Notebook Logo
106 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
