Question about GE Superadio III AM/FM
Radio does not turn on
I plug in cord radio does not turn on. i took radio apart check for loose wires everything looked good. no water damaged and nothing smelled burnt.the radio looks in good shape.it looks like it's about no more than 5years old.
  • Anonymous Feb 07, 2009
    llistening to radio just shut off no power
Listening to the radio, just stopped working no power with cord
Posted on Feb 07, 2009
Ironman canister won't turn on. took it apart to look at switch and wires. nothing loose, but checked everything... then it worked. today... no signs of life...?
The switch may be failing. You can check switch continuity and operation while the machine is disassembled but it is likely to wait until you have reassembled the machine to fail again.
Feb 13, 2015 | Oreck Vacuum Ironman Canister Vacuum Bags
My Eee 4g surf netbook won't charge at all. Upon turning it on, it runs for a second, then shuts off due to a lack of battery power. The charge cable's light is also not turning, so that may
I think your DC Power Jack is bad. The DC Power Jack is where the power cord plugs into the laptop. If it is bad, then a good power cord cannot charge the battery, nor can the laptop turn on once the battery is drained.
You say it smelled burnt, that might mean it took a power surge. I always tell people that before your plug the power cord into the electrical outlet on the wall to remove the other end of the cord from the laptop. That way if you get a power surge you will only damage the power cord and not the dc power jack or motherboard.
Anyway, take an ink pen and push it into the dc power jack and see if there is some movement. The little pin or the casing of the jack should not wiggle.
The DC Jack is soldered onto the motherboard. To replace it you will have to take the laptop apart, desolder the old dc jack and solder a new jack onto the board. Sometimes the DC Jack sits in a slot rather than being soldered. The palmrest and bottom case helps to keep it in place. This type of DC Jack usually has a cable harness that plugs into the motherboard.
Apr 02, 2012 | ASUS Eee 4G Notebook
Just bought the used car and radio was working. Came with a Kenwood KDC-148 stereo. 2 days later, radio just was dead. Have checked fuses, wires and everything looks good. Everything else electrical...
Check the power from the harness. The yellow wire which is usually for constant 12v power and the red wire which should only have power when the key is turned on. check those wires and if you have power on both then the radio is fried. Try pushing the pins in the back of the radio harness in and see if maybe there is a loose pin, other than that, like i said , the radio may be bad.
Jun 28, 2011 | Kenwood KDC148
I have a Marshall head mg100hdfx. It was pluged into a outlet that had been wired wrong.The amp came on and worked for about 5 seconds and then went off and will not do anything now.I took it apart and...
Unless the receptacle was wired with 240 volts, NO DAMAGE would be done. First thing to check is to turn amp on and use an ohmmeter to check for some continuity between the blades of the plug. Common problem is that the power input cord doesnt seat fully where the cord attaches to the amp.
Here is your schematic:
http://elektrotanya.com/marshall_mg100dfx_sch.pdf/download.html
Scroll down to "get manual" and click on it. Ignore other download links. A fuse cannot always be visually checked. They sometimes fail mechanically and loose fuse clips are common problems. Do the contiuity check. The transformers rarely fail, so don't let an incompetent tech tell you it is bad.
Jun 25, 2011 | Marshall MG100HDFX 100-Watt Amplifier Head
When I plug oven into outlet the breaker trips.
there is a short somewhere there, you will have to ohm's check it
Jun 21, 2010 | Kenmore 33464 / 33465 / 33469 Gas Single...
Dryer smelled of burning plastic, smoked stopped turning on
check the power cord itself, if you see on the back side of the cord a burnt or blackened spot then the cord is the issue
Apr 12, 2008 | Dryers
UNIT WILL NOT TURN ON
I am having the same problem with mine. It's plugged in and everything looks as it should inside, but i can't get the thing to turn on.
Mar 12, 2008 | Maytag M7DH45B2A Dehumidifier
Power Issue
sounds suspiciosly like your chord fitting is damaged(loose wires at connection)and shorting.if possible try a friends power supply with same connecter type before renewing cos could be faulty(loose)connection at pc(inside)constant pushing and pulling of connections often causes 1. loose split or disconnected wires at male connection or 2.loose pins on motherboard female connection or broken housing (not difficult to repair)more difficult to find out how to get to internal connection.
Mar 04, 2008 | Toshiba Satellite M65-S9092 Notebook
When i plug the heater in it does not work.
its difficult to make a homeowner an expert in troubleshooting his/her equipment if he/she has no technical background - but - I will try. First check the cord to plug connection. Is it tight? Does it look melted? Next, take the unit apart where the cord goes into the unit. Check the wiring path. Look at each connection. Look for burnt off wires at connections. Most connectors are the push on type and are mechanically fastened to the wires. if they are burned off you'll need replacement spade terminals and a crimping tool. (radio shack) has these. one wire will go through a thermostat and out to an element terminal. one wire may go through a thermodisc overload, then to the thermostat and then to the element. the other wire will definitely go straight to the element. there may be some extra connections for lights etc. if you have to take apart the heater make a diagram of which wires go where. use some masking tape with numbers written on it to make sure the wires go back to the same place you took them off.
Nov 21, 2007 | Honeywell HZ614 QuickHeat Baseboard Heater
Kenmore side by side model 596.55662500
have you tried pouring bleach water through the drains in the fridge?
Nov 08, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
GE Superadio III AM/FM Logo
302 people viewed this question
Top GE Audio Players & Recorders Experts
Greg Cann
Greg Cann
Carlos L. Burgos
Carlos L. Burgos
SHARCNET-USA
SHARCNET-USA
Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
