Question about Sansui DTV2760 27" TV
When changing channels----Big black square appears on screen
When changing channels...black square appears...not sure how to rid of it. i turn off TV and back on again ...start again. The model is DTV2798
Don`t have manual...what does ANALOG mean and do I need this to function properly. thanks
  • 108 Answers
Turn off the closed captions or select c1 to view the captions. Right now they are set for text and that is what is causing the black box to appear
Posted on Jan 09, 2009
  • 3 Answers
The box is a TEXT BOX that has become active because you activated it in the CC or Closed Caption settings on your TV set....
LOOK for a CC button located on your remote...you probably pushed it accidently while changing channels...
It may also be labled Capt / CAPT too....
IF you push the button over and over, you will likely CYCLE your choices, and you need to CYCLE it to the OFF MODE...
And you may have about 8 or 9 choices to cycle thru....
Posted on Oct 24, 2011
A BLACK SQUARE APPEARS IN THE MIDDLE OF THE SCREEN HOW DO I GET RID OF IT
Hi Tony
You`ve mentioned that ON CERTAIN CHANNELS THE TV WORKS FINE, so your trying to say that not all channels THE BLACK SQUARE APPEARS IN THE MIDDLE O THE SCREEN... my be that black square is generated from the broadcast center. may be your unit is good. let me ask you how many channels that your tv works fine..?
Jan 16, 2014 | Panasonic CT-34WX52 34" TV
Lost remote. Must do manually on t.v. Two problems:\r\n1) I cannot get channel back on channel 3. It skips from 2 to 4. 2) TV has large black box on screen covering most of screen. I can push buttons...
Try website like Remotes.com to buy the tv original remote to used.U will used the tv original remote to turn to channel 3 with ease.After u have the tv original remote push the menu button go into Closed Captioning functions turn off like TEXT 1,2,3...The big black box will not appear on the screen again.Tv used it manually control buttons up and down channels trying to get to channel 3.U will never get it to tv channel 3 because tv channel 3 was not save on it memory list of on the tv turn manually channels buttons programming memory.Tv have a manual button said MEMU button on it tv front bazel frame?Yes.Might could used the Menu button on the tv frame to get in to turn off TEXT 1,2,3...to stop the big black box to show up on the tv screen again.
Aug 17, 2011 | Toshiba 36A50 36" TV
Black Box appearing on my screen
go into your menu and access the closed caption modes. someone has accidently put your tv in the "text" mode. turning off the closed caption feature will correct this.
Apr 01, 2009 | Televison & Video
Screen problem
That's the text box function of the closed caption decoder. Look for buttons with "CAP", "TEXT","CCD", or "CLOSED CAPTION". Look in menu for same.
Nov 11, 2008 | Broksonic CTSGT9369CTT 19 in. TV/VCR Combo
unplug the set for a while , but this problem will return because of a malfunction in the EPROM CHIP , this controls the menu and a few other functions
Oct 17, 2008 | Philips Magnavox 27MS343S 27" TV
Toshiba TP50G60 Big Black Square Covering the screen?
try the closed caption adjustments. i had a tv that did the same thing and the captiong did it. turn caption off nd try.
Oct 09, 2008 | Toshiba TP50G60 50" Rear Projection...
Big black box in the middle of the screen
The black box is there because your closed captioning is on and set to text mode. Some channels send the signal even when there is no actual text to display. You can get rid of it by either turning off closed captioning or changing it to CC1 or CC2 mode instead of text. If you can't find those settings, then restore factory settings as directed in your user manual.
Jun 04, 2008 | JVC AV-32230 32" TV
Big black screen in picture
You have the CC (closed captioning) turned on and it is set to text mode. Look for a button on your remote labeled "CC" or go into your TV menu and make sure the captioning selection is set to "off".
Sep 19, 2007 | Televison & Video
Shut off the closed captioning and your problem will be gone.
Jun 26, 2007 | JVC AV-27F702 27" TV
Sansui DTV2760 27" TV Logo
132 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
