Question about Brother BRTPT65 PT-65 Label Maker Printer
Print in vertical mode on a brother p-touch 1100ql label maker
How to set vertical print
5 Suggested Answers
  • 5 Answers
SOURCE: brother Model Pt-65
There are two vertical fonts - small and normal. To put the labeler into vertical mode, hold down the [Code] key and tap the [J] key.
When it asks " 1-9 ", let go of the [Code] key.
Press the [8] key if you want small vertical type, OR the [9] key if you want normal size vertical type. Then you have to hit the [ <--' ] enter key.
Now you are stuck in Vertical mode ! :-O
To get back to normal, hold down the [Code] key and tap the [J] key, Let go of the [Code] key.
Then tap the [3] key and the enter [<--'] key. You are back to horizontal labelling.
:-) phew!
Posted on Jul 28, 2008
Democritus
  • 120 Answers
SOURCE: change cartridge Problem - Brother BRTPT65 P-Touch Model PT-65 Home and Hobby Label Maker Printer
Manual is here: http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_PT_65_65SB_65SCCP_65SL_65VP_EN_166.PDF
Your cassette appears empty or otherwise non-functional. Please see page 2 of the above manual.
Posted on Jul 11, 2008
SOURCE: ptouch 1100QL waste of tape issue
It isn't actually "before the actual letter comes out," as you said, but rather after. You have probably noticed that you must do a "feed" first or the cut won't clear the end of the label and you have to do it again. This just reflects the distance between the print head and the cutting bar.
There's no way to avoid this if you must have the one label you just printed right away and you don't have any more labels to make at the moment.
However, if you have several labels to make, you can economize by printing them one right after the other (without any "feeds" or cuts), then once you're all done, do a "feed" and cut. The labels will be close together, with little waste except at the ends, and you can cut them apart with a scissors.
Posted on May 26, 2009
paul7of9
  • 1189 Answers
SOURCE: too much tape
Hi, it seem your label maker is set to the last(amount) of labels printed. Go to: Print Labels, click; Number of Labels; clear to set to (1) Label. That should stop the run off of labels. Thanks paul70f9
Posted on Jan 04, 2010
SOURCE: Brother P touch label maker language settings? how
Tune machine off. Press and hold F and the delete button (2 buttons below the F). Whilst holding these down, turn the unit on by pressing and releasing the power button. Then release the F and delete buttons and the language option will appear.
Posted on Jul 20, 2010
Vertical lines/letters print in a wavy form, Black ink, not Colors and not images, like jpg files
Canon Knowledge Center - Aligning the Printhead - MX922
https://support.usa.canon.com/kb/index?page=content&id...
Dec 9, 2015 - If printed ruled lines are misaligned or print results are otherwise unsatisfactory, adjust the print head position. ... Load a sheet of supplied paper or A4 or Letter-sized Matte Photo Paper .... (A) Least noticeable vertical streaks.
My Canon MX340 printer prints wavy vertical lines. Help!
www.justanswer.com > Printers
Question - My Canon MX340 printer prints wavy vertical lines. Help! - J0. Find the ...You need to prepare: a sheet of A4 or Letter-sized plain paper. 1. .... I tried to open the scanner function on my Pixma MG3520 and 10/24/2015 10/25/2015.
db:: 4.21::printing double, no alignment of lines 9c
www.hivmr.com/db/9cz3a3czjjs8kdpmxcdjj1jccpcjpfks
when Printing Pictures I get Vertical lines and when Printing Letters I get .... Hi: I have a Cannon Pixma 3100 series printer which seems to be printing in a double ...form page in the printer that you are using u can see that in printer settings ...... Printer is MX922. ..... I cleaned thepaper feed rollers and the wavy lines began.
db:: 4.76::Black line prints on copies 8d
www.hivmr.com/db/kassjxzca3kkdf8zjf7p9zzj7pxk9mza
Jan 17, 2016 | Canon Pixma MX922
Stopped printing envelopes in proper direction
What software are you printing from? It sounds more likely to be software causing the issue.
Sep 05, 2007 | Brother HL 1440 Laser Printer
Vertical alignment
Usually this is asked when the printer is using more than one page of paper to print what the word processor shows as 1 page. This is fixed in the word processor program print set up module that opens when you click Print.
If you really want to change the vertical alignment of the print heads, then you need a different printer.
Feb 28, 2015 | HP OfficeJet 6210 All-In-One InkJet...
This started out as error 5200. Now, my Canon MX340 printer isn't connecting to the computer. The computer acts like the printer hasn't been installed. I tried to remove the printhead and restart...
Issue: How do I align the print head?
Solution: Perform a Print Head Alignment (Windows)- MX340
Aligning the Print Head Position Print head alignment corrects the installation positions of the print head and improves deviated colors and lines. The procedure for performing print head alignment is as follows:
alignike.gif Print Head Alignment
  1. Open the printer driver setup window
    • In Windows Vista, select the Start menu -> Control Panel -> Hardware and Sound -> Printers.
    • In Windows XP, select the Start menu -> Control Panel -> Printers and Other Hardware -> Printers and Faxes.
    • In Windows 2000, select the Start menu -> Settings -> Printers.
  2. Right-click your model name icon, and then select Printing Preferences from the displayed menu.
    The printer driver setup window appears.
  3. Click Custom Settings on the Maintenance tab.
    The Custom Settings dialog box opens.
  4. Check the Align heads manually check box.
  5. Click Send, and click OK when the confirmation message appears.
  6. Click Print Head Alignment alignike.gif on the Maintenance tab The Start Print Head Alignment dialog box opens.
  7. Load three sheets of A4 size or Letter size plain paper into the rear tray (3).
  8. Execute head alignment Make sure that the machine is on and click Align Print Head.
    Follow the instruction in the message.
  9. Check the printed pattern
    Enter the numbers of the patterns with the least amount of streaks in the associated boxes.
    Clicking the patterns with the least amount of streaks in the preview window, will automatically set their numbers in the associated boxes.
  10. When you have entered all the necessary values, click OK.
    Note:
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable vertical white streaks.
      (A) Less noticeable vertical white streaks
      (B) More noticeable vertical white streaks
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal white streaks.
      (A) Less noticeable horizontal white streaks
      (B) More noticeable horizontal white streaks
  11. Confirm the displayed message and click OK.
    The second pattern is printed.
    Important: Do not open the Scanning Unit (Cover) while printing is in progress.
  12. Check the printed pattern
  13. When you have entered all the necessary values, click OK.
    Note:
  14. Confirm the displayed message and click OK.
    The third pattern is printed.
  15. Check the printed pattern
    Enter the numbers of the patterns with the least noticeable horizontal stripes in the associated boxes.
    Clicking the patterns with the least noticeable horizontal stripes in the preview window, will automatically set their numbers in the associated boxes.
  16. When you have entered all the necessary values, click OK.
    Note:
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal white stripes.
      (A) Less noticeable horizontal white stripes
      (B) More noticeable horizontal white stripes
Note: To print and check the current setting, open the Start Print Head Alignment dialog box, and click Print Alignment Value.
Aug 11, 2011 | Canon PIXMA MX340 Wireless Office...
How do you print horizontal and vertical
What you need is a font style. By default it will print horizontaly. To print vertically you will need to select Vertical in the font style.
When you select a style, that style applies to all characters. Styles can be used with alphanumeric characters and some symbols.
Normal
Bold
Italic
Outline
Shadow
Vertical
To set the font style
1. Press FORMAT .
2. Use the up or down arrow keys to select STYLE and press OK.
3. Use the up or down arrow keys to select a font style and press OK .
May 31, 2010 | Dymo LetraTAG Thermal Label Printer
Triple vertical printing with Z11
Here's what worked for me: (I'm using a black ink cartridge, but my 'printer properties' were set for a color cartridge, thus basically sending a '3-color signal' to my printer; making it print in triple vertical.)
Go to Settings > Control Panel > Printers. Right click on your printer, and click Properties. Click the Cartridge Maintenance tab, then click Install / Change Cartridge. Select the cartridge you are using in the drop-down list, and click Continue. Print an Alignment Page. If this dosen't work, close everything and try it again: I had to do it twice to get mine to work. Hope this helps!
Kerry
Apr 27, 2009 | Lexmark JetPrinter Z11 InkJet Color...
Epson 2200 - vertical lines
I don't know if this will help as my printer is a different model (the epson stylus photo r280) but I have been battling the vertical line issue for weeks, ever since getting a new imac. I am printing altered photos from photoshop on epson ultra premium matte photo paper. After trying every conceivable setting, and spending an hour with less than helpful tech support from epson (where they insisted I needed to download new drivers) I just resolved it this morning at last by increasing the dpi setting on the print function to beyond what I would normally use(1440x 1440 rather than what I had been using at 720).
The prints came out great at last!
On my older computer with this same printer the prints came out fine at the lower setting. But for some reason it appears that the higher setting is now necessary to eliminate those dreaded lines.
I hope this helps.
Feb 03, 2009 | Epson Stylus 2200 InkJet Photo Printer
HP C5580 print settings
Hey! I found this in a review site (can't remember)
"If you use Nero 7 Essentials to print CD/DVD labels, make sure you print just the page for the disc, and under print setup make sure you have CD/DVD 120mm under size and CD/DVD tray from source, then under Preferences set your calibration to -0.185" horizontal, -0.182" vertical, and you'll be golden."
I hope it helps!!
Nov 07, 2008 | Office Equipment & Supplies
Vertical print residue left about half inch past the longest line printed
inside the front cover, under where the head parks, you will find a vertical wiper. Clean it.
Power off. open front door. push down cutter (blue) and slide head to the left. To the right of the cleaning pad is the wiper. clean with rubbing alcohol on both sides.
Run a normal cleaning.
All set
NOTE: you do not need to put the head back in place. when you power on it will automaticly park itself
Nov 06, 2008 | Epson Stylus Pro 9800 InkJet Printer
Anoterh Vertical Line Problem!
So many questions Vertical lines suggest [you do mean vertical do you - up/and down?] is new one to me try www.fixyourownprinter.com Printing CD's is not a 2200 thing, it is the province of the R series. Printing lables is easy purchase CD labels and suitable CD print software - A kit including labels software and label applicator is available at many computer stores Other labels- download the Avery-Dennison free lable software.
Aug 01, 2007 | Epson Stylus 2200 InkJet Photo Printer
Brother BRTPT65 PT-65 Label Maker Printer Logo
2,983 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
