Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Printing is not clear
I am using MFC- 210C. Just I changed the toner. But printing is not coming properly. Photocopy and Self testing result is OK. Only the printing from the computer is the problem. Can I get some sort of solutions from you?
    President:
  • 8,637 Answers
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
My Brother MFC-210C All-In-One Printer is working as if it's printing, but the paper is blank! Please help!!
in the computer click the printer icon and see if there is any printing Que if there is delete all then close it then click start settings printer then make the printer your default printer then right click the default printer and click print a test page also check the cartridge ink level
Oct 26, 2011 | Brother MFC 210C All-In-One InkJet Printer
Can't turn on mirror printing to print an iron on transfer
You need to make the changes in the drivers. Click on start then control panel, double click the printer icon. Right click the MFC-210c and select printing prefferences. Click on the advanced tab and put a check mark where it says mirror printing.
Apr 21, 2010 | Brother MFC 210C All-In-One InkJet Printer
My printer will no longer scan to my computer
Try updating the print drivers. You can also try doing a repair installation using the printer software or delete the printer and reinstall it using the provided software.
Oct 20, 2009 | Brother MFC-210C All-In-One Printer
My Brothers MFC 210C All-In-One Inket printer is printing blurry. It has been used in a year. I changed the cartridges and ran the cleaner but it still prints light and blurry. What can I do? Thank you.
keep on printing the catridges will satrt function well after few prints if they have ink and heads are ok , if not take out cartridges shake them well chek head are leaving ink on a tissu paper if not place cartridges under runing water tap clean their heads and dry them with tissue paper and place them again nowi think they will work i
let me know your reply sitehr@gmail.com
Aug 16, 2009 | Brother MFC 210C All-In-One InkJet Printer
Printing in double.
Try to clean electric contacts on cartridge and corresponding contacts in printer from toner. Use fabrics with alcogol.
Mar 05, 2009 | Brother MFC 210C All-In-One InkJet Printer
Trouble
WILL NOT SELF CLEAN AND WILL NOT PRINT
Feb 27, 2009 | Brother MFC 210C All-In-One InkJet Printer
My Brother MFC 210 C printer will not print in yellow.
i cannot print the documents that i want ,,the printer cannot recieved the documents but it can copy.
Feb 09, 2009 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C Printing slow
You may have already tried but /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} From page 129 of the manual: http://welcome.solutions.brother.com/BSC/public/files/dlf/doc000222/MFC-210C_UsaEngUsr_B.pdf
Changing the printer driver setting may improve the print speed.
Highest resolution needs longer data processing, transfer and printing
time. Try the other settings of quality in the printer driver ‘Basic’ tab.
Also, click the ‘Settings’ tab, and make sure you uncheck the
True2Life®.
Borderless printing is slower than normal printing. If you want to print
more quickly, set the Borderless feature off.
Aug 30, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-210c prints some lines blurred, letters stacked - alignment ok.
i have the same problem. repeated cleanings seem to help, when i print large fonts they come out pretty clear, but the smaller the font, the worse the blurring. 600 DPI prints mismatching patterns, but 1200 DPI prints perfectly fine. so i have found that printing on "fine" quality instead of "fast" or "normal" quality improves print quality ALOT. it uses more ink, but i am in business and need to be able to read very fine print!
May 14, 2008 | Brother MFC 210C All-In-One InkJet Printer
I keep getting the message unable to print see trouble shooting in manual
If trying to Print in Word 2003 - 2002 - 2002
Click on tools > options > Print tab > Uncheck Back Ground Printing. Click on ok. Try Printing.
If you are trying to Print from Word 2007.
Click on Office button > Word options > Advanced > Locate Print options and uncheck Backgound Printing click on ok. try Printing
Oct 19, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
22 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
