Question about Food Mixers
Re kitchen aid mixer . I was making bread dough with the lock on. Just when i was going to shut it off I hurt a click and then the paddles stopped turning. The motor runs but with a funny nose but it will not turn the paddle. I tried to take it apart to take a look but cannot get the screws out just above the shaft where the paddle goes on.
  • 135 Answers
Hi. Don't try to use the mixer anymore, and don't take the planetary off as the problem isn't there. If your mixer is still under warranty, call Kitchenaid, they are good at responding to mixer failure if it's under warranty.
If you're out of warranty remove the single screw to take off the silver band near the top of the mixer. The screw is at the back of the mixer. Next, remove the 4 screws that hold on the top cover. Remove the top cover and locate the transmission housing (it will be a black/gray plastic humpy looking thing) near the front of the machine. Look for cracks in this housing. you can do this without taking it off. If It's cracked, you have found the first problem, and it's a problem that many Kitchenaid owners, including me have had. This plastic transmission housing has no business being in a machine that you paid top dollar for. Their replacement housing is now made out of metal.
A word of warning, and customer service won't tell you this. As managment at Whirlpool Corp. told me. Even if my mixer was out of warranty. they may have repaired it for free, if only I had not taken it apart. So if you've found a cracked Trans. housing, put the cover back on, put the silver band back on and call Kitchenaid customer service. Tell them about your problem. Don't tell them that you took the cover off. They will tell you that because you are out of warranty, all they can do is refer you to one of their authorized repair centers.
If you take it to the repair center, ask for a quote, they will look at it and see the cracked trans. housing, then they will take the housing off and find that the worm gear has been destroyed and possibly the shaft bearings too, they may also find that the bearing seats have been damaged (as in my case). They will tell you about the damage and give you a quote about how much it will take to fix it. Then is the time to contact Customer Service again and demand to speak with a supervisor and tell him/her about the cheap plastic housing and the damage IT caused. Tell them that you want to be reimbursed for the damage caused by this flimsy part. They will argue with you. Ask to speak with management.
If they refuse, contact me at ricardobelanger@gmail.com and I may be of further help to you.
If you have found this solution helpfull, please rate it. Good luck!...You're going to need it ricardok45
Posted on Jan 09, 2009
Kitchen aid mixer kg25hoxer repair manual
Request the repair manual directly from KitchenAid.
Feb 26, 2018 | Food Mixers
When itry to make bread dough in the mixer, the bowl locking mechanism doesnt work properly and the bowl moves and top of mixer jumps around how can i fix this
You need to make sure that the hinge pin is tight, turn machine completely upside down and tighten the slotted screw up inside the pedestal. If that doesn't fix it you will need to check that the locking lever is properly engaging in the slot. You may need to "SLIGHTLY" file the slot in the pedestal that the lever engages into. If you go mad with the file you could wreck the slot.
Sep 13, 2014 | KitchenAid Kitchen Aid KSM150PSMY -...
Why can't my kitchen aid mixer turn n
Sounds like the worm gear was stripped. This gear is designed to fail when the load on the motor is too great. This protects the motor from overheating and burning out. By the way, the mixer should not be used above the number 2 speed when using the dough hook.
The worm gear is not all that hard to replace although you will have to contend with a lot of grease. See the Service Manual:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
May 20, 2014 | KitchenAid 32685 Mixer
Mixer won't start after mixing dough.
There is a good chance you burned up the electrical Connectors to the motor or you have have blown the FUSE that is located inside the housing. The Motor has a Self Shut Off when it overheats but if you have over taxed the motor more than once, then there is a good change you need to repair/replace it with something that can handle harder work. My sister got a Mix Master the same time I got my Kitchen Aid, My Kitchen Aid is running strong since 2003 and her Mix Master died in 2005 and I bought her a Kitchen Aid. Sorry but I am not fond of the Sunbeam Mixer's.... Quality has gone down hill over the years to keep their prices low.
Mar 01, 2014 | Sunbeam 2386 MixMaster Series Stand Mixer
Mixer arms shake when kneading bread
You have not supplied a model number and the bowl lift models are not all the same. A couple of items you could check, make sure that the bowl retaining clip that engages with the dimple on the pedestal side of the bowl is not broken. Make sure any bolts/screws holding the pedestal to the base or the pedestal to the motor are tight. Even if you supply a model number I can't think of anything else to look at unless the handle is not lifting the bowl up tight enough. I think on some models the arm holds the carrier up with some pressure which would help stop the wobbles.
Jul 13, 2017 | KitchenAid Kitchen Aid KP26M1X 6 Quart...
I cannot remove the flat mixing blade, after mixing cake. It has never happened before, just doesn't move up down or sideways! it seems completely locked.
The blade sounds like it's jammed somehow perhaps simply with some food matter.
Ensure the mixer is not plugged in then try removing the bowl, locking the mixer in the down position and pushing up hard on the blade to try and dislodge it. If it comes free and lifts up then try wiggling and rotating it normally off the mount.
Sometimes with use the attachments can become slightly warped requiring more force to lift them before rotating off the mount.
I once used my own Kitchen Aid mixer with the dough hook attachment to make a whole wheat bread dough. When I was done the hook was a bit bent from the hearty dough. There was also some flour in the mount causing it to jam. Removing the hook attachment proved difficult but not imposable.
Good luck.
Apr 18, 2011 | KitchenAid Food Mixers
Hello. I have a Kitchen Aid mixer made by Hobart between 1975 and 1978. It is a stand mixer with a 5-quart bowl that lifts and locks into place. While it was kneading a bread dough, the motor...
Hello Suzann,
I understand that you are having a problem with your Kitchen Aid 5 Quart mixer. It sounds like you have stripped the gears or the worm gear out. Although, it may not be an expensive parts repair it is not an easy task to complete if you are not mechanical enclined. There are many different little gears in these units.
My suggestion would be to take it a local appliance repair shop that works on mixers. If you can tell me the city that you live in I would be more than happy to give you the location of one or two repair shops. As the unit is so old you want to invest in a new unit and keep that one as a reminder of how long Kitchen Aid has been around.
Thank you for choosing FIxYa.com
Justin Burnett
Mar 16, 2011 | KitchenAid KITCHEN AID 5 Quart Artisan...
No sticker/model number on the bottom of my stand mixer and am missing the paddle attachment and dough hook.
Since you have not given a make...I'll take a stab in the dark and bet you have a kitchen aid...simply because you mentioned the dough hook. Kitchen aid has 14 models of stand mixers. You can match yours up and look at available accessories at www.kitchenaid.com
Sep 01, 2009 | Food Mixers
Is 300 w mixer powerful enough to mix bread dough?
Your mixer is easily able to handle the kneading of bread dough. Please advise:
9 cups of all purpose white flour, maximum.
6 cups of specialty flour, maximum. This is any flour besides all purpose white.
Bread doughs are only to be needed on speed 2, and never for longer than 7 minutes.
This is all stated in the Use and Care guide for the mixer itself. If these guidelines are not followed, it may lead to a product failure.
Jul 02, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Bread dough
IT NEEDS TO PROOF LONGER
Dec 10, 2008 | Hobart N50 Stand Mixer
Food Mixers Logo
226 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
