Question about Onkyo Audio Players & Recorders
Onkyo tx-N906 clipping problems
Onkyo tx-n906 cuts in and out through tunner and through hdpvr cable reciever after 10 or 15 minutes of use but not with ps3. Checked power supply, hdmi cables, different inputs, New calbe reciever and new onkyo....please help
SOURCE: hum niose in my onkyo tx-sr804
Hi there, sounds like you have a ground loop happening there. Check out ground loops in google to get some tips. What you should try is use one wall plug for everything (with an adapter on it) and check that none of your other cables are damaged. try find new cables and put them in place of the old seemingly fine cables.
Posted on Oct 06, 2007
  • 14 Answers
SOURCE: new home theater setup- no signal at tv using onkyo tx=sr605
Could well be the quality of your cables. if you have high end cables the consult a service agent. if you have the cables that came with the products, go and get some better ones.
Posted on Dec 13, 2007
This might somewhat help. Today I went back .. I went HDMI out of the Cable box and DVD player into 2 of the TVs HDMI ins. The digital audio out from each, straight to the receiver and things are working ok. All speakers are working OK. Sound isnt as loud or crisp but unfortunately I found no other solution.
Posted on Jan 06, 2009
taran_2005
  • 10515 Answers
SOURCE: No surround sound from my PS3 through the Onkyo 5100. Video OK
Unfortunately only the higher end Onkyo Reciever pass audio over HDMI for sound. 605,705,805,905 exc. Your reciever will carry Video over HDMI but you will need a digital optical cable for sound.
thanks.
Posted on Jan 24, 2009
  • 5 Answers
SOURCE: Onkyo Reciever TX-SR806 Losing HDMI signal.
I had the same problem with my xbox 360. I was able to fix the problem by disabling the Display Discovery setting on the xbox.
Posted on Feb 12, 2010
Question: is there a usb port on my onkyo srx-507 reciever to connect to my sansa-clip mp3 ?..thanks`
Onkyo SR >> X << 507?? No such animal according to Google.
How about TX-SR507?
http://filedepot.onkyousa.com/Files/own_manuals/SN29344940A_TX-SR507_577_En_web.pdf
No USB.
Anything that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to any audio device with a standard RCA input (except PHONO).
Get a cable like the one described here: http://www.monoprice.com/products/product.asp?
c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
and connect it into any available analog input EXCEPT "Phono".
May 15, 2011 | Onkyo Tx-sr507 A/V Receiver
The system will shut off once the volume reaches a certain level. The system will not get really loud.
CHECK ALL YOUR SPEAKER CABLES YOU MAY HAVE A PINCHED OR PUNTCHURED SPEAKER CABLE. IF ALL YOUR WIRES ARE RAN ALREADY GO INTO SPEAKER SETTING GO TO SPEAKER CONF, WITH RADIO PLAYING, AND START RAISING Hz IF ITS A SPEAKER CABLE PROBLEM IT SHOULD CUT OFF WHEN UR RAISING THAT SPEAKER Hz. IF IT CUTS OFF WHILE RAISING THE Hz TAKE ONE SPEAKER CABLE STRAIT FROM RECIEVER TO THAT SPEAKER THEN TRY RAISING IT AGAIN. GOOD LUCK
Jan 09, 2011 | Onkyo TX-SR608 Receiver
HDMI signal cuts out for a few seconds constantly from receiver to television. It does it when switched to cable box and the roku box. Onkyo TX-SR606 Scientific Atlanta Cable box thru HDMI Roku Box...
Mine did the same thing where the screen would go black for a few seconds and then the picture and sound came back. I would try (1) switch HDMI cables, (2) try a different HDMI input in the back of the receiver, (3) try different input in the back of the TV. None of these seemed to work with mine. I finally ended up running the cable box direct to the TV and only run the audio through the reciever via coax or digital. No more problems. I think the HDMI inputs in the back of the reciever have a problem continuously carrying the signal if it is the leaset bit weak.
Sep 08, 2010 | Onkyo TX-SR606 Receiver
Audio cuts of during graphics, Onkyo TX-SR706
I have a TX-SR505 and the same thing has been happening on mine since I bought it. I am also hooked up to a Panasonic Plasma, using the optical cable to the receiver. It's been perplexing me. I have noticed it typically during commercials, not during normal programming. If I turn up the volume on the Panasonic TV, I can hear the audio, so I know it's not a problem with the over the air signal. It must be something wrong with the reciever. Would love a fix to this!
Oct 06, 2009 | Onkyo TX-SR605 Receiver
No audio from pc connected using hdmi
Are you not getting audio to the television speakers and the onkyo reciever speakers when connected HDMI thru the reciever or just the television. If it is just thru the television then it is because the reciever is grabbing the HDMI audio signal and converting it so it does not reach the TV. If it is both then try changing the HDMI signal output from PCM to DOLBY DIGITAL on the computer. Your reciever may not be able to process the PCM signal of the computer. Does the reciever show a PCM or DOBLY DIGITAL display when HDMI is hooked up to it?
Oct 03, 2009 | Onkyo TX-SR606 Receiver
Sep 10, 2009 | Onkyo TX-SR804 7.1 Channels Receiver
ONKYO TX-SR606 Single output to TV
Hi there. for your receiver, the only time it can upconvert is when you go out as HDMI. In your current hookup (component out to tv) the signal from your cable (using a composite) will not be able to pass through the component cable. This means you either have to hook up your cable box using a component cable as well or add a composite cable (yellow) from monitor out of the receiver to the tv. Page 22 of the manual will show a diagram of the video signal flow. hope this helps.. ^_^
Dec 02, 2008 | Onkyo TX-SR606 Receiver
Zone 2 cut off on onkyo
Your program source may not support a 7.1 format. Try switching to 5.1
May 06, 2008 | Onkyo TX-SR605 Receiver
Onkyo TX-SR605 video problems
Bypass most reviews say video area is still alittle shaky
Feb 08, 2008 | Onkyo TX-SR605 Receiver
119 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
