Question about Meade Polaris 114EQ-D (36 x 114mm) Telescope
Primary reflector became dull with time.
Tried using very fine auto polishing cream. it helped a lot but not near like new. is there a replacement mirror for the 114EQ-D mirror???
  • 21 Answers
The 114EQ-D is not worth fixing. A six inch aperature on a good mount is the minimum for a starter scope.
Posted on Jan 13, 2009
  • 3,186 Answers
The primary mirror is VERY delicate -- first surface mirror. Without a doubt you damaged it using auto polish. Mirror are cleaned very very gently using running water and alcohol-- and a tiny amount of dish soap... here is an article--
http://www.dvaa.org/ATM/MirrorCleaning.html
You can buy mirrors --- but they will be almost as expensive as a new telescope.
Posted on Jan 11, 2009
How to clean the headlight lens
This is a most unusual question as almost everyone knows how to clean one of the earlier glass headlights which like the later polycarbonate lens just needs washing with water and detergent and perhaps a brief polish with a glass cleaner or polish.
I therefore suspect your headlamp lenses are not dirty but have become scratched and sandblasted and in the case of the polycarbonate ones, discoloured.
If this is the case then the only solution is replacement though polycarbonate lenses can be improved and given a longer service life if not too seriously discoloured by polishing with an abrasive compound - the sort of cutting compound used on dull and rough auto paintwork and then finished with a finer compound. It is extremely long and hard work by hand but the careful use of a polishing machine will shorten the task considerably.
I suggest you ask for help and/or advice at your local car sprayshop.
Jun 08, 2016 | Cars & Trucks
I love stainless steel appliances and have a lot of them at home. But, it is trouble cleaning them. They look really bad if they are not kept clean regularly. How can I get rid of the stains and marks on...
get a 'oxygen' based cleaner soak overnight.
normal cleaner works based on surfacetant. oxygen cleaners works by dissolving the stains.
of course, you can use some elbow grease and polish them.
Oct 16, 2013 | Ronco 'Showtime' Rotisserie and BBQ...
Replace headlamp lenses on 99 merc marq
since its a 99 it has a sealed plastic headlamp assembly which means you cannot just replace the lens you have to replace the whole assembly a cheaper option if all that's wrong is they are dull is to polish them and headlight scratch remover/ polish kits are available at any auto parts store just follow the instructions
Jan 05, 2012 | Cars & Trucks
1998 Yukon. Headlamps are dull. How do I change them.
if you are talking about the lenses then you don't have to replace them, get some compound and polisher from a parts store, a few minute (hrs) with it and the lenses will look good as new, and a lot cheaper
Aug 08, 2010 | 1998 GMC Yukon
How do I remove the plastic from the headlight assembly??
These headlamp housings are sealed and not meant to come apart. There is a headlamp polishing kit that is sold in most auto parts stores that is used with a low speed drill to polish the fog and glaze out of the plastic lens using 3 or 4 steps of fine gritted paper with a polishing compound to finish the job. If the housing has water in it or is very dirty inside there isn't a whole lot you can do to get that out of there short of replacing it. Hope this helps a bit!
Jun 25, 2010 | 2000 Chevrolet Impala
How to take of the headlight leans to clean it on a 2004 hyundai elantra
most of the time the dullness in the headlight assembly cannot be due to the lens dirt. this is due to poor reflector which has dulled out in the years of use. open the assembly remove the bulb and use good quality liquid cleaners to clean through the bulb opening. use a dry cloth to polish and finish off.
Jun 25, 2010 | 2004 Hyundai Elantra
Need new stainless steel top.
  • Firstly clean with DeBruce Polish to clarify area.
  • you may have to "re-grain" those finely scratched areas.
  • Blend or "scratch out" the misdirection scratch's with new "controlled" scratching, useing a 3M scotch brite #7447 you get at auto parts store (Nappa). Use medium very firm pressure.
  • -Re-clean with DeBruce Polish. Touch ups are now a breeze
  • DeBruce Polish is Odorless, Non-Toxic and non abrasive and perfect on stainless steel, glass cook tops, polished granite marble and more. DeBruce Polish is Odorless, Non-Toxic and Non Abrasive. DeBruce is perfect on stainless steel, glass cook tops, polished granite marble and more. NO NEED TO REPLACE. We buy DeBruce at debrucepolish.com.
    Feb 16, 2010 | Tappan TGF657 Gas Kitchen Range
    Headlights dulled
    no to both questions. we have had good luck with wet sanding the plastic faces with 1500 sand paper than with polishing compound buff them back to new.
    Mar 29, 2009 | 2001 Lexus RX 300
    Meade Polaris 114EQ-D (36 x 114mm) Telescope Logo
    242 people viewed this question
    Top Meade Optics Experts
    Joe Lalumia aka...
    Joe Lalumia aka...
    Experi
    Level 1 Expert
    Greg Cann
    Greg Cann
    Are you a Meade Optic Expert? Answer questions, earn points and help others
