Question about Sony KP-51HW40 51" Rear Projection Television
Sony 52inch projection nothing happens,timer light blinks all the
No picture,timer light blinks continuously.(over night)
  • www_kristasm Jan 09, 2009
    thanks daniel719.need schematic to locate these parts. i'm a master certified technician for cars and can follow a trouble shooting flow chart, tvs are new to me. like mixing 100 different puzzles together without any pictures to by!!!!!!!!!!!!!!!!!!!!!
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    There would be an interval of 3 seconds between light blinks, please count blinks and let me know to see what area of TV is in trouble.
    Champion:
  • 240 Answers
Check powr suply for a sony wite ceramic fuse 0.01 ohm
if open rebuild or replace power suply befor turning on the unit check the H.O.T high v transistor if shorted replace and also replace vdr610 602 and 603, depending on set flyback should be changed also due to a know internal arking problem with sony fly backs.
25% of the time its just the power suply that goes bad.
Posted on Jan 09, 2009
Sony KDS-R60XBR1 No picture
Sounds like your light engine might have broken. Its around a $400 fix and I noticed Tri-State is having a sell on there about 341 its easy to replace it here is the link
http://www.tristatemodule.com/casearch.aspx?SearchTerm=kds-r60xbr1&asug=&view=grid&lang=en
May 14, 2013 | Sony KDS-R60XBR1 60" Projection HDTV
Sony kp53xbr200
You will need technical experience to fix. First what do you remember happening to set before it went out? Did you have color problems, or alignment problems? There are many things that could be wrong. Open startup resistors, R600-612, IC 601, C667,607,608 etc .
Dec 07, 2007 | Sony KP-53XBR200 53" Rear Projection...
STANDBY TIMER IS A CONSTANT FLASHING
This older model the light should blink at turn on for 10-15 seconds before picture appears.
The set is checking for certain voltages and other things---if any are missing it will not come up.
This is like saying car will not start--the Battery? Or?
Someone would have to go inside and check voltages first and then check to see if horz or vertical drive etc.
May be too old a set as some parts for it no longer available.
Mar 19, 2012 | Sony KP-41T65 41" Rear Projection...
Sony KP-41T65
is there a cadence to the blinking timer light?
Jul 17, 2009 | Sony KP-41T65 41" Rear Projection...
No picture (fan& bulb do not come on) but there is sound
I have a RCA 52inch D52w136D, the power button blinks three times, but nothing happens no picture or sound
Nov 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Power comes on, red light flashes on timer/standby but no picture
Need the model number of your set and also how many times is the led blinking? Please respond to this same post
Jul 25, 2008 | Televison & Video
Timer Standby light flashing No pitcher
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Apr 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Tv went blank
Does the timer/stand-by light blink at all? If so, count how many times it does. It will usually be in intervals. If it isn't blinking, and you have nothing on the screen, you might have a problem with the "G" Board, part # A1316499A.
C-Dog
Dec 16, 2007 | Sony KP-61V90 61" Rear Projection...
Picture went off still had sound then i turned off at panel now only red timer/standy stays lit sony 61" projection
First plug in again and look at led light, the amount it blinks tells what is wrong. Then if it stays lite it tells something also. You can try Display-channel 5-volume +- Power(service mode). Then Channel 8-enter(test reset). If this doesn't work then you will have to replace somethings like F601, R607, Q601, IC601, R612, VDR601.
Oct 05, 2007 | Sony KP-61V85 61" Rear Projection...
Will not turn on
how many times does the light blink? There is a diagnostic set-up built into these Sony TV sets.
Apr 01, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
90 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
