Question about Garmin Nuvi 760 Handheld GPS Receiver
My Garmin 775t nuvi keeps on looping at boot screen
What i did for the 775t to work again I took the battery out, wait a while but the 775t nuvi is doing the same thing. It keeps trying to boot load the maps and then it goes blank (it turns its self off). Everything started when i tried to load one more map on the Garmin directory, included the keys ofcource in the unl file. I really need to hard reset the garmin 775t to its factory default erasing even every extra maps added in it. Thanks Dimitris
5 Suggested Answers
  • 1738 Answers
SOURCE: Nuvi 775t will not charge
Your battery is bad.
Posted on Nov 23, 2009
  • 378 Answers
SOURCE: Garmin 760 will not power on
reset by turning on and keeping finger on the screen then clicking 'yes' to 'reset all user data".
try hooking it with computer connecting usb wire several times as sometimes if it is not getting connected this happens.also try to check out in any other socket of usb in your computer.
for more details check out this link
http://www.poi-factory.com/node/13662
thanks.
Posted on Jan 09, 2009
  • 916 Answers
Is the battery charged? What does the battery indicator say? If you are using it in the car, is the power cord connected and working properly? If it is working correctly, you should see a lightning bolt symbol over the battery bar graph showing that it is connected to an external power source and that it is charging.
Try plugging it into your PC and looking at the battery indicator. Do you see the lightning bolt? Does it shut off when your using it on the PC? If not, there is something not right with the car adapter. Also, just because it was plugged into the car adapter does not mean it was charging. Many cars will turn off the cigarette/accessory jack when the ignition is off or shut off after a short while to protect the car's battery from being run down. Try hooking it up the the PC overnight and leave the PC on. In the morning try using it. Does it still shut off? If so, the internal battey may be bad. If it works and doesn't shut down, you have a problem with it not charging in the car and the adapter may be bad.
  • 30 Answers
SOURCE: Garmin nuvi 250
Testing by FixYa Staff
Please do not rate this post!
We apologize for any inconvenience.
Posted on Jul 14, 2009
gemmy23
  • 346 Answers
SOURCE: Have a Garmin nuvi 200 with North America maps.
It will depend on how much memory you have in your Garmin. If you have maps that you want to keep then I would download those first and then add in the Ireland maps. Or wait until you leave to add in Ireland. I believe the Garmin will tell you if there isn't enough room to add in Ireland.
Posted on Aug 17, 2009
Testimonial: "Thanks again Gemmy23"
Gamin nuvi 1450 wonot start and the gamin express cannot recognize it
Your Nuvi has to boot past the Garmin logo to the main screen before it can be recognized by your PC. Is the unit dead? The Nuvi 14xx series is well known for its problem with the rear USB port coming loose. This will prevent the unit from receiving power from the external charger and will prevent the battery from being charged. If the unit goes into a boot-up loop, displaying the Garmin logo then shuts down, this is often caused by corrupted files, such as a map or bad firmware update. See these two links for more info:
SHARCNET USA Out of Warranty GPS Digital Camera Repair SHARCNET USA Out of Warranty GPS Digital Camera Repair Center
Nov 01, 2014 | Garmin nuvi GPS
My Garmin Nuvi 1490 LMT returning to normal functionality after doing a map update.
Common problem caused by a failed map or firmware update...or both.
Corrupted map or firmware files prevents the unit from booting normally. More info on boot-up problems here:
http://www.sharc.net/gps_bootup_repair.htm
Apr 07, 2013 | Garmin Nuvi 1490LMT Nuvi 1490 w/ Lifetime...
Cannot turn on Garmin Nuvi 775T
In service update firmware and now it work OK.
Apr 11, 2010 | Garmin nuvi 750 GPS Receiver
Garmin Nuvi 205 screen freezes
When a Garmin Nuvi 205 stops working or behaves strangely, there are two steps you can take yourself to try and get it going again:
  1. Perform a Hard Reset,
  2. Run WebUpdater to reinstall that firmware.
I hope that helps.
Feb 16, 2010 | Garmin nuvi 205 GPS Receiver
Nuvi Blackout
This is a known problem that Garmin is fixing. Look at:
http://www.garmin.com/garmin/cms/site/us/support
Under "TOP FAQ" there is an entry for "My nuvi 755T, 765T, 775T or 785T will no longer turn on."
You will need to return your unit to Garmin for them to fix it.
Jun 25, 2009 | Garmin nuvi 750 GPS Receiver
Garmin Nuvi 660 touch screen freezes up. Soft
I sat on the phone for 30 minutes waiting for Garmin support when my Nuvi suddenly had no touch screen response. They had me delete a file on the device (with it hooked to my computer) then reboot and it went thru a touch screen alignment and it worked.
Sadly, it has frozen again and I don't recall the file (it had been a GCD file in all caps, that is all I know and I don't see a file in all caps any more). I will be calling support tomorrow.
My take is that it *is* a firmware thing *and* there is some way to reset the firmware.
May 01, 2009 | Garmin Nuvi 660 GPS Receiver
Nuvi 775T constantly says that it is updating the GPS Firmware
Go to Garmin and update it too.
Garmin.com/webupdater
This will keep it Spick and span for you.
Regards
Richard.
Mar 16, 2009 | Garmin (010-00583-00) for nuvi 750/760/770
Charging doesn't display map when charging
I learned that with the unit off - hold the on button down - don't release it. A PRE-BOOT MODE message will appear at the bottom and may flash. Continue holding down the start button. The first time I did it a series of dots came on the screen and I was instructed to touch each one. After that it started as normal. I plugged into a wall charger and but git the pc and nuvi icons again. I repeated the process - holding the on button on and let the PRE-BOOT MODE appear and kept holding but this time a different message came on and then the PRE-BOOT MODE appeared again. I let it go and took the unit to my car and plugged it into the Garmin car charger and it worked as it used to - normal. However, when I plugged it back in the house to the wall charged I got the pc and nuvi icon again. It appears that I am using the wrong wall charger as a previous writes stated. But the nuvi still worked in the car plugged into the nuvi charger. I hope this helps.
Jan 24, 2009 | Garmin Nuvi 660 GPS Receiver
Jan 09, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Garmin Nuvi 760 Handheld GPS Receiver Logo
918 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
