Question about Kenmore Refrigerators
Kenmore 253 freezer will not stop running. Replaced the thermostat but it still runs all the time. Model 2539206281
  • rikirchn Jan 26, 2009
    REPLACED THERMOSTAT AND RELAY AND STILL NEVER CUTS OFF.
    Genius:
  • 1,239 Answers
Hi
What's the frost pattern of the Evaporator Coils look like ?  evenly frosted ?
How long does the Compressor run ?  forever ?    or 1 hour ON, 1 hour OFF ?
Posted on Jan 09, 2009
    President:
  • 373 Answers
Can you please be more specific on this?..if the freezer is continuously running, then there might be a problem with the condenser coils. have you tried changing the temperature control?..does it make the difference in the temperature of the refrigerator (excluding the freezer)?
  • Suresh Thrithandam Venkata Lakshmi Narayana
    if while changing the temperature setting doesnt make a change, then there might be a problem with the temperature controls too.will wait for your comments.
    Top Expert:
  • Kenmore Master
  • 79,189 Answers
I am sure there is a relay that the thermostat controls, it is most likely stuck closed, consult a appliance repair about the part and the location.
Kenmore 253 refrigerator/freezer won't stop running on any setting. The food in the top of the refrigerator would freeze unless I partially blocked the vent. I am wondering what the problem could be. i...
I have a Kenmore model 253 freezer/refridgerator upright model. I am getting cold spots in the refridgeration in and near the vegetable drawers on the bottom of the refridgerator. The icemaker works but the water dispensor has stopped working too.
Nov 28, 2010 | Refrigerators
Have 8550510 Kenmore Refrig that stopped running.
Sounds like the thermostat is bad . Without the complete model number , including the first 3 numbers , such as 110. , 106. , 253. etc , I can't tell you how to access it . If you can get access on your own , jump the 2 wires connected to the thermostat , and see if the compressor cuts on . If so , replace the thermostat .
Oct 20, 2009 | Refrigerators
Kenmore 253 9280413 freezer keeps running
The coils are embedded in the outer walls and will make the cabinet feel warm outside when the compressor is running. It needs about 4 inches of clear air space around all the outer case walls to properly get rid of its heat. If you have items stored too close to the outer walls they will act as insulation to keep heat from being dissipated. This can cause long run times.
A unit that has lost freon gas due to leakage, while unlikely, can also extend run times. Normal temperature should be about Zero when the dial is set to halfway.
Good Luck
Sep 15, 2009 | Freezers
Kenmore model No. 253 11312100
Hi, No this freezer is not a self defrosting model. If it is defrosting while the compressor is running, you have a major problem.
If the compressor is not running, check the outlet for 120V and then check the thermostat to see if it is in the on position. If the control is on but the compressor os not running, check it for continuity. It must show closed while in the on position.
I hope this helps. Please let me know if I can assist you further.
Vic
Jun 19, 2009 | Kenmore Freezers
1991 Kenmore 16 model 253 in storage for 7 years. Plugged it in and turned it nn last night and seemd to run fine, nice and quiet just like before. Today it is not cold and the comressor seems to be r
If the freezer was stored and not running for 7 years it may have lost coolant.  Since the compressor is running recharging the coolant may fix the problem.  Hot compressor might indicate low coolant since its motor is immersed in it.
May 30, 2009 | Kenmore 19.7 cu. ft. / 558 liter Chest...
Fridge and freezer not cooling
this should be under warranty... check to see because you have a big problem. you know how to get the back of obviously let it run take the back panel off the freezer and pay real close attention to where the frost ends on the coils i bet you are low on freon and or the compressor is bad....
Apr 24, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Freezer compressor runs steady & getting -30F
You probably have a defective thermostat or sensor for reading the temperature.
Mar 23, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore Frost Free Comm. Model #253-23425100 - will not stay cold
Two things:
Either the thermostat has inadvertently been turned up, (too warm) or the gas in the compressor tank is low. If it isn't #1, call a repair tech to replentish the has in your compressor. If that isn't it he will tell you what he thinks it is. Good luck!
Mar 15, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer won't run
There is no reset switch. There is a thermal overload protector mounted on the compressor. Does the compressor hum and then give a click sound. If so your compressor has failed. If the compressor is cold (Room Temperature) and it does not try to run your thermostat may be bad. If so remove the temperature control and jumper the two main wires that connect to the control. Unit should be unplugged to do this operation. Insulated the wires so they do not contact any metal surface. Plug the freezer back in. If it runs and cools replace the thermostat.
Jul 01, 2008 | Freezers
Refrigerators Logo
23 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
