Question about Brother DR-400 Replacement Drum - 20000 pages Printer
I have a brother fax machine, and i changed out the drum. it is the dr400 drum, and it reads replace drum. what do i have to do to reset my printer so it does not read this? thank you
    Genius:
  • 2,120 Answers
Leave the cover open and press CLEAR
Posted on Jan 10, 2009
How do I reset my MFC8480DN after I have replaced the laser unit?
With the unit turned on and in ready state, press #'s 3 and 9 together and hold them down untill display changes to reset menu. Then scroll down to drum reset and follow prompts on display.
Feb 10, 2015 | Brother MFC-8480DN MFC8480DN...
Continue to get a message to change drum soon. Changed drum already. Print quality is still not good.
hi
This message would continue to appear if the drum counter was not reset when you replaced the drum. To reset the drum counter, follow the instructions listed below.
  1. Open the front cover.
  2. Press the Options key on the control panel.
    The display will show "REPLACE DRUM - 1.YES 2.NO".
  3. Press 1 to reset the drum count.
  4. Close the front cover.
Oct 07, 2008 | Brother Office Equipment & Supplies
Tip
Brother MFC laser printer facsimile machine replace drum or change drum soon...
OK so you have replaced the drum unit on your Brother, or you have not replaced it but your copies are fine and you want to extend the life of your drum unit.
Simply open the front cover.
This procedure wil work on the majority of the Brother MFC series of laser based Printer Scanner Fax Facsimile machines.
Good Luck and Thank You for using Fixya.
on Jun 03, 2010 | Office Equipment & Supplies
Just installed a new drum unit in my Brother DCP1000, and it's still reading "Replace Drum soon"
heya!
this stands for brother mfc-8440 as in the title.
you need to reset the "drum counter" of your printer..
to do so try one of those
Brother Laser Printers:
After replacing the drum unit, keep the front cover open (make sure the power is on). Press and hold the "GO" button until all four LED's are lit. Once the four LED's light up, close the front cover. Make sure the drum LED is off. The counter is reset!
Brother Fax Machines:
Open the front cover. Press the CLEAR/BACK button. Press 1, when the display shows accepted.
Sep 19, 2011 | Brother MFC-8440 All-In-One Laser Printer
How to change drum to a Brother Super G3 Fax Machine instruction state to change drum, and with door open, hit the clear button until "Replace Drum?" appears, then hit 1,,,,,,well there is no...
With door open, press "Options." Screen reads, "Change Drum?" Press 1 for yes. Screen reads "Accepted." Place drum/toner in, close door. Done!
Feb 03, 2011 | Brother IntelliFax-2920 Fax
The fax recieved is real light all the way down in the center of the page, can bareley read it.
More than likely this is a problem with the DR400 drum. As a technician I could easy find out by using a used replacement drum. Unfortunately, this would be expensive for you to always carry a spare drum. However, if you do have one used, keep it for checking. I suspect the drum only if this machine has lots of use, it just isn't up to it.
Oct 04, 2010 | Brother IntelliFax-4100e Fax
New Drum and Toner and faxes sent are black
You have a bad SCANNER BLOCK. Expensive to repair.
May 05, 2010 | Brother IntelliFAX 4100 Laser Fax
Brother Intellifax 2920 / How to reset Drum Life ?
1.Open the front cover.
2.Press the options key on the control panel. The display will show
#REPLACE DRUM - 1.YES 2.NO#.
3.Press 1 to reset the drum count.
4.Close the front cover.
Aug 18, 2008 | Brother FAX-2920 Plain Paper Laser
141 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
