I have a 47 inch hdtv projection tv I really like the tv it has great color but it is turning on and off by its self. I bnought it new from sams club in the box aug 12 2005. Can you advise as to what could be wrong and is it a fixable problem.
  • 28 Answers
Try replacing the lamp if it uses one it should be blinkinkg a error, but maybe lamp just startig to fail I would replace it anyway because it will go bad in the future. Normal lamp time is about 5,000 -7,000 HRS. Also not sure if your TV is Tube type,LCD or Plazma. If it is a tube type TV there won't be a lamp. Then you have a shutdown problem. Hope this helps, Mike C.E.T.
Mike C.E.T.
Posted on Jan 09, 2009
Hitachi 51F59A has 3 'lamps', blue, red, & green. No light coming from the blue, both others are lit
don't waste your money go and buy a new smart tv a 50 inch is around 400 and up. Wal-mart, Sam's Club. etc...
Mar 23, 2011 | Hitachi 51F59 51" HDTV Projection...
Sams club warranty problem
The bulbs aren't normally covered after the first year. Some extended warranty companies used to cover the bulbs after that, but now since the economy is bad... a lot of companies are trying to save money by not covering the lamps anymore. And the ones that did are handing the warranties over to other companies. You probably will just have to buy one yourself or you will just be chasing your tail.
Jun 19, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
The color converter
Seems to me you maybe experiencing a convergence issue rather than the color converter. (Don't know what he means by that for that I am an a tv repair technician).
If it is what I beleive it to be, you need and experience tech to do the work for you. It usually contains replacing two convergence IC packs along with some resistors and sometimes power supply parts. All wich requires good soldering work.
Jan 09, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Lg 47 inch tv sound
We had the same problem of pathetic sound quality and volume with a sony brava. Thats just the way they make tv's these days because most people buy a surround sound system as well. We bought logitec computer surround sound speakers for about $140 and plugged into the ear jack, problem solved, we have heaps of volume and stacks of bass.
Dec 21, 2008 | LG 47LC7DF 47 in. LCD HDTV
Sylvania 37-Inch LCD/DVD combo HDTV remote code for Scientific Atlanta 8003
You can find the sylvania 37" LCD/DVD COMBO at Sam's club for 597.00 it is a special item for sams club. If you go to sams club on line you cna locate what sams club has this tv in stock but hurry they are going fast and there model number is LD370SC8. I am not sure where you are located but please start your search now and if you do not have a sams culb card you can get the lowest priced membership possible and due to the low cost the price of a membership is worth it.
I hope I have helped?
Noreen
Sep 09, 2008 | Televison & Video
Childproofing tv
At Sam's club you can buy what is called a "Plasma" floater for about $77 that lets you mount your LCD or Plasma on the back of the unit, raise it up and keep it much more out of the way of kids:
http://graphics.samsclub.com/images/products/0076405342828_L4.jpg
(search under "Urban Loft 60" Entertainment Console" at Sam's club to find it)
The floater can be purchased seperate from the console table. AND it will work with the Whalen console I bought at Costco (I called Whalen and they confirmed it will work, it has all the right mounting brackets installed already).
http://graphics.samsclub.com/images/products/0076405342957_LG.jpg
(search under "Whalen Furniture Plasma Floating Mounting Bracket" at Sam's club).
Could drill some holes into the base of the stand and secure it to what ever you have it sitting on.
tie down strap that prevents tipping. You have to secure the strap someplace with a self tapping wood screw and the other end of the strap connects to the base of the TV.
Dec 15, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
Power problem
would require some troubleshooting, common problems would be convergence amp ic and high volt transformer transistors
If you are really brave tackle this TV FAQ.
http://repairfaq.ece.drexel.edu/sam/tvfaq.htm
Dec 04, 2007 | Panasonic PT-47WX42 47" Rear Projection...
Panasonic PT-47WX53 47 in
ck mosfet and hori output also look for burnted capacitors [2] of them 1200pf 2k volts.
Oct 09, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Sansung HC-P4752w 52 in. Rear Projection
you require a deflection board replacement the board cost around $150/
Aug 02, 2007 | Samsung HC-P4752W 47" Rear Projection...
RCA P52830BL picture is bowed and colors separated.
There is a convergence printed circuit board that likely has a few bad components. If you decide to get it repaired, the technican will probably check for fluid leaks from the picture tubes coolant area which has given problems on this model also. If the picture quality leaves a bit to be desired, it may be a wise move to upgrade to HDTV. A Sony KDS-55A20 model has a great picture and should be less than $2300. I just saw one at a local Sams Club store.
Mar 12, 2007 | RCA P52830BL 52" Rear Projection...
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
