Question about Maytag Washing Machines
Suddenly off during filling
I washed a load normally, unloaded it, then set the dial to permapress wash, to fill, and it began to put water in, then I put the lid up and the top of it hit the cabinet above, and it was as though a switch went off, no water, nothing. I have reset, turned off and on, checked the power, tried setting on another setting, etc. I wanted to lift the top but could not figure out how to get it off. Can there be a switch or a wire that jarred loose?
I called a friend who used to have a Maytag store and is an electrician, who said it was probably the lid switch assembly, and we checked it, inside the panel back, could not get it to work, so today he replaced it and it works fine! That little plastic part controls all the electrical and operating actions of the whole machine.
Thanks,
Cathy
Posted on Jan 11, 2009
Why wont my amana washer start at all?
My washer will notwork it will not let the lid lock are fill with water
Jan 20, 2013 | Amana NTW4501XQ Top Load Washer
My new electrolux front loader is not filling with water during the wash cycle. The clothes are soaked, but there is NO extra water in the bottom of the tub. It does have extra water in there during the...
front loader washers fill accourding to how big the load size is on all front load washers.There should be no water above the center with a full load.If it is spinnig out and draining then it is working properly:)
Apr 21, 2010 | Electrolux EIFLW55HIW Front Load Washer...
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Washer fills slow only in the rinse cycle
ck and clean screens first both sides be sure hoses are not reversed timer has no affect on fill rate if screens are clean replace valve
Sep 19, 2008 | Kenmore 24032\24036 Top Load Washer
Water inlet not filling
check it has drained completely after the last cycle.
if that is ok, take top off and check continuity thro the inlet valve coils
Aug 21, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Asko 12605 overheating the wash water
(even not taking in hot water when filling before the wash stage which seems good)
The washer fills with cold water then heats it up 3 degrees a min. Your problem does sound like a faulty thermostat. Especailly if the glass door does get hot even if it is on 85f.
May 29, 2008 | Asko Washing Machines
Kenmore washer fill problem
make sure you have it on the right settings, or inspect fill hoses cold for clogg
Apr 17, 2008 | Kenmore 44042 Front Load Washer
Roper Washer
Most likely to be something in the water pump but could be anything in the mechanical assembly. PLease rate my help
Oct 02, 2007 | Frigidaire GLWS1233A Top Load Washer
Washing Machines Logo
54 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
