Nordyne 220 volt furnace is heating up the power wire
  • 5,568 Answers
This calculator can tell you if the gauge of wire you are using for load current & distance is supposed to be adequate.
Wiring parameters calculator
It isn't serious to have a run get 'warm' but never hot.
If the calculator doesn't make sense to you holler back and I'll see if I can help you.
Posted on Jan 09, 2009
I need the wiring diagram for the blower on a nordyne furnace
For a wiring diagram, contact Nordyne directly.
Apr 23, 2017 | Heating & Cooling
Intertherm/nordyne furnace (24 years old)
Shut off power, get a small wrench, remove orifice spuds and clean them with toothpick. Take burners out and clean rust from them. Check and see if you are getting 24 volts to gas valve. If not replace it.
Feb 15, 2014 | Intertherm P3RA-048K Air Conditioner
Heat pump squeal
It sounds like a bearing going in the motor. Most likely the front and probably not oil-able. If it is, 10 drops, non detergent, 10 weight. No penetrating oil. Work the shaft in and out as well as back and forth on-till loose. Be sure to kill all power first!!!!!!
Dec 09, 2013 | AO Smith Miller / LSI / Home / Nordyne...
Nordyne furnace FEH017HA-04 the fan runs full force when the ac is on but half speed when the furnace kicks in
That is probably normal if it is electric heat to slow the air over the heating elements. Even some gas units do this. Check to see if the unit blower motor has wires for multiple speeds.
Oct 24, 2013 | Coleman Intertherm Nordyne Miller Furnace...
BLOWER NOT KICKININ ON A NORDYNE FURNACE
Do you have 120 volts applied to the motor? Try spinning the blower wheel by hand, if this getsbthe motor running the capacitor must be replaced. If there is power to the motor and does not start up, the motor will have to be replaced.
Dec 12, 2012 | AO Smith Nordyne Furnace Motor 1/8hp 1050...
Trying to wire a 220 volt furnace in a three phase breaker box
normally in three phase applications all three wires have a 120 volts each on them and normally the electrician will lable either by tape or put in the middle slot whats called a high delta leg which has a little more power going to it... if no tape then the two outside wires in the 3 phase pane can be connected to the furnace. just check across them at 3 phase panel prior to connecting to make sure your getting 220-242 volts hope this helps you out ...good luck
Jan 08, 2011 | Emerson Heating & Cooling
Nordyne FEH017HA-04 furnace wiring
This should be 110v so you will have black wires, white wires and ground wires. The grounds wires both go to the ground bar, the whites wires both go to the nuetral bar, or can be wire nutted together, the black incoming (feed) wire goes to the buss bar that the breaker plugs into and the black going to the furnace goes into the breaker lug.
Nov 12, 2009 | Electric Circuit Breaker Kit for Furnace
Wiring NO, NC relay on Nordyne furnace
NORDYNE , GOODMAN, AND NUTONE ARE ALL BUILT BY SAME MFG SO IF YOU TRY ALL THESE MAYBE YOU CAN FIND THE HELP YOU NEED
Jan 12, 2009 | Electric Circuit Breaker Kit for Furnace
Heating & Cooling Logo
69 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
